Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
My Kenmore 71182100 refrigerator/freezer is not working properly. I just took off the back cardboard and the fan is not running - is this something I can do on my own or do I need a repairman?
    Guru:
  • 1,524 Answers
Change the motor. Call Bi Coastal Appliance Parts @ 1-800-673-1262
Posted on Mar 23, 2011
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Feb 24, 2011 | Kenmore 18.9 cu. ft. Top Mount...
KENMORE Refrigerator, Model #253.74192400, Serial #LA41814168, I inherited this refrigerator from my late uncle Kenneth Herring. The problem is not freezing/making ice-is blowing cold air in the...
Clean the coils under the ref or on the back. If there i a fan under the ref make sure it runs when the ref is on. Also since it got moved around if it does have a fan make sure there is a black cardboad panel in place on the lower bottom back of the fridge. If its missing you can cover t with a piece of cardboard cut to fit just leave an opening at the fan. This piece of cardboard directs air from the front of the fridge across the coils and exits by the fan out the back. good luck
Aug 11, 2010 | Kenmore Refrigerators
The part between the freezer and the fridge is hot to the touch. The freezer is not working by the fridge is.
This is usually because the condenser fan isn't running. It's underneath the unit accessed from the rear behind the cardboard backing. It should run when the compressor runs.
Aug 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore side by side refrigerator is cold inside, but bar in the middle separating the frezzer from the fridge is hot to the touch
I had the same problem. I had just brush cleaned my coils and then it began. When I took the back off the fridge, I saw the fan was not spinning. I unplugged the fridge and then tried to spin the fan blades. Ihad inadvertantly bent a blade so it would not spin. I bent the blade back into shape and turned it on. The fan worked and very quickly the middle was no longer hot.
Aug 25, 2009 | Refrigerators
Kenmore 71182100 refrigerator will not cool after clearing drain
Hey Donna! It normally takes 24 hours for your system to go back into it's "normal" mode after it's been off. I would wait until tomorrow and see if it's cooling down properly before you worry. You may call me if you like after you wait the 24 hour period. Hope this helps you! Ella
Aug 17, 2009 | Refrigerators
Freezer dripping water down to fridge, drain hole freezing up
check your tubing for auto ice maker if you have one. It my be clogged. This happened to us with a $100.00 repair for tec to blow through it to fix.
Aug 07, 2009 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator not cold
first check your damper door from the freezer to the refrigerator compartment make sure its in the proper position. Then turn off the refrigerator for a few hours until the heavy frost melts away. turn on the refrigerator check the refrigeration cycle, is it working properly, is it going into defrost are the defrost heaters working.
Feb 21, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator.
If you have determined that the evaporator fan in back of the freezer compartment is running, then you might have a stuck or broken air diffuser. The diffuser acts like a damper to divert air into the refrigerator compartment. Sometimes they jam or break due to frost buildup.
Jul 23, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerator problem
3 most common things that cause this are a defrost problem (will notice frost build up on back freezer panel), bad evaporator fan motor (should hear fan running in the freezer), or bad damper (vent to the fridge section). If no frost and fan is running check for air flow out of the vent. It should be at the top of the fridge section.
Oct 01, 2007 | Kenmore 93361
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
148 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
