Question about Vacuums
I have a hoover windtunnel upright vacuum, It will not shut off and I have to unplug it to do so. If I take apart the upper handle and manually flip the internal switch it works just fine, only when using the external switch on the handle, wont shut off.
  • 240 Answers
This is a common problem with this machine. The switch has too much resistance to be turned on and off with the switch button and rod. If you put in a new switch, ( # 28161075 ), your problem should be fixed.
Posted on Mar 23, 2011
Replace on off switch on u5458-900 hoover vaccum cleaner
Remove the screws that hold the upper handle assembly onto the body of the vacuum. The upper handle assembly will slide off the back to reveal the power switch
Dec 28, 2013 | Hoover U6616-900 WindTunnel Bagless...
My new Hoover Wind Tunnel Upright UH50000 will not turn off unless I unplug it.
First I would be sure the handle was properly installed. Remove the two screws holding the upper handle in place and tap it bacwards to remove it. Set the switch inside to the OFF position. Next set both buttons on the handle to the OFF position and re-install the upper handle. If the switch still does not turn the vacuum on and off, the switch will need replacement.
Apr 01, 2011 | Hoover U6630-900 WindTunnel Bagless...
Forward/back cable broke
The cable is user replaceable, but you will need to contact Hoover, or a parts center, to purchase the cable. You will remove the Upper Handle by removing the black screws at the base of the upper handle fit to lower handle (on back).
You will also have to remove the hood to loosen the one screw that holds the cable to the powerdrive gearbox.
Oct 12, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Tuned off and won't turn on again
This is a great product. Do not pitch. I've own this same unit for years. Take off the handle. There are four screww located half way down the hanlde. Once the handle is off, you will see the red swtich button. Flip the swtich on/off with handle off and unit plugged. The unit should come on. Put the handle back on and it should operate fine. If it doen't you mjay need a new switch
May 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
On-off switch is stuck on
on the back of the handle down below the grip you will see 4 screws take them out.then slide the handle out towards the back.on the sides of the handle you will see small notches those are the snaps the hold it together.the handle will come apart.feel free to call me if you need help i don't charge just like to help people save money.if there is a cord cradle there you may have to take that off also,held onby 2 screws.314-628-9153
Apr 23, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
The shut off switch is stuck to the on position
This sounds like you have an internal problem with the electrical switch. I would recommend you take it to a vacuum dealer who has experience with this model. This is a relatively simple reapir for a pro shop to handle.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 13, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
How to remove handle from Hoover 5445-900 upright wind tunnel vacuum
Hoover.com doesn't have a manual specific to your model but there is one similar which will show how to remove the upper handle from the body.
http://www.hoover.com/pdfs/manuals/U5467900.pdf
Do you have a replacement switch? If not I believe you can buy one from Hoover (the switch and/or the upper handle assembly). Unfortunately your model isn't listed on the website, is this a new vacuum? I recommend giving them a call, that would be the easiest way.
Also remember when working with electronics to unplug the vacuum. Even when there is no power residual electricity can remain in the wires. If you feel unsure, take it to a repairman.
Hope this helps!
Dec 22, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
43 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
