Question about GE WBVH6240F Front Load Washer
My GE WBVH6240FWW is still pausing even after I have cleaned out the front filter which had 2 aaa batteries and some coins plus a lot of lint built up. So now what?! I ran it through a cycle and it is still pausing (4X). Also my softener dispenser is clogged I guess because it won't empty the liquid. I have cleaned out the drawer really well and used a pipe cleaner to clean the hole the best I could inside of the machine. HELP, please I have laundry stacking up:(
    Brigadier General:
  • 6,277 Answers
I'm wondering if you had the opportunity to see and check the condition of the drain pump/motor?
Here are my guidance notes for checking both the drain filter and the drain motor and for ensuring the softener tray siphon tube is checked and clear ;-0)
Sorry- I've left them both pretty much complete- from start to finish and you already know about most!
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Softener tray
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
Good luck on both!
John C
Posted on Mar 23, 2011
Find lint filter for a GE washer WBVH6240FWW
Remove the front lower kick panel and you will see the filter.
Nov 08, 2012 | GE Washing Machines
GE front loading washing machine model # 4 wbvh6240fww It won't drain. Don't know where the pump filter is, that everyone is recommending to check and clean. Where is the access panel for the...
The filter is hidden below the lower front panel (3 screws hold this in place) Turn the pump cleanout knob counterclockwise about 2 turns and be ready to mop up any water that leaks out as you remove it. To avoid spillage, you can pull the machine out and tip it backwards 45 degrees.
Jul 12, 2011 | GE WBVH6240F Front Load Washer
Washer will pause in mid cycle, once you push the pause cycle it will run for a while then will pause again, after about 5 to 6 times a load it will complete.
Hi
Thanks for using FixYa. You’ll need to clean the filter which is located on the front bottom of the washing machine right below the washer window. It is held up by three screws. Take out the screws and clean the lint. You’ll find in the lint some small clothing, coins and other small things.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 15, 2009 | GE WSXH208A Front Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Won't rinse, won't spin, now not responding with start/pause button
Similar problem fixed in less than 5 minutes. Here's a post that was very helpful. http://www.foobert.com/blog/2007/04/02/ge-adora-front-loading-washer-does-not-drain/
There's a trap located under the front panel (3 screws) I undid the filter and pulled out 21 coins, 2 buttons, a 'letter h', zipper parts, a broach, and a whole lot of lint.
My wife said that the unit never got the clothes so dry afterwords, she said the almost didnt need to throw the clothes in the dryer.
NOTE: Have a ton of towels ready, and if you can fit a bucket or dish under the filter, go slow and steady. I opened it up and had several gallons all over the floor!
May 19, 2009 | GE Washing Machines
Remove lint holder on ge front loader dryer
I have the exact same problem. I am amazed at had been the engineering is for such a simple process. The user guide just says to clean the lint filter. Even when doing so, there is still an excessive build up of lint beyond reach. There are no instructions that mention how to clean this part. It is obvious that GE did not test this part of the machine.
Jan 30, 2009 | Zanussi ZWF1440 Front Load Washer
WSXH208V1WW front load washer won't drain - faulty pump?
remove lower panel behind panel will be pump after removing as much water as possible in tub remove access port on pump and clean also ckd as far into pump as possible ..pump can be removed and taken apart if necessary ..if pump is clean may be issue with pump impeller they will sometimes break or come loose on motor shaft if impeller free wheels replace pump
Oct 25, 2008 | GE WSXH208A Front Load Washer
GE Front load washer WCHVH 6260F
I had the same problem.....The start/pause button would flash during a cycle and the washer would not finish the cycle. After reading on this forum that there is a filter/strainer inline with the drain, I tried this solution.
Remove the (3) screws that hold the lower front panel (Just below the door)
Once the panel is removed, you should see a white plastic strainer hooked to the washer drain.
Please a large bowl under the opening and unscrew the knob/handle, pull the filter/strainer out and clean all of the lint/trash out of this area.
My filter/strainer was clogged with a baby sock, 2 doilies, a fewe pennies, 2 dimes and lot's of lint.
I believe all of this debris was causing musty odors in the machine as the lint would stink due to dampness.
Once I cleared out this filter/strainer the problem and my odors went away
I wish GE would add this "EASY" step into the owners manual for proper care and maintenace.
Thank you for letting me know about this filter/strainer as it did resolve my problem
Sep 13, 2008 | GE Energy Star WCVH6260F Front Load Washer
Soaking wet clothes
Harm, remove the lower panel and you will see the filter right in front. Unscrew the filter strainer and clean all the lint and debris. This machine has a pressure switch that won't allow a high spin if it detects water in the tub. Therefore you get these pauses and slow tumlbe. Try this and see if it's normal after cleaning the filter...Catriver...post back
Oct 10, 2006 | GE WBVH6240F Front Load Washer
GE WBVH6240F Front Load Washer Logo
179 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
