Question about Optics
I have a set of Clearvu (by Marathon) night vision goggles BI 184001 they have worked perfectly until I dropped them last night. No apparent damage but the only thing that comes on is the laser dot. No night vision at all. Help, they are brand new.
Did you ever fix these? If it's a standard repair, I'll do it for free. If you pay for 2 way shipping. I've repaired NVD's for almost 30 years and I'm an old combat veteran with impeccable credentials. Since I'm long since retired, I occasionally just help out others in need for free. There's a lot of scalpers out there! Either way, good luck!Did you ever fix these? If it's a standard repair, I'll do it for free. If you pay for 2 way shipping. I've repaired NVD's for almost 30 years and I'm an old combat veteran with inpeccable credentials. Since I'm long since retired, I occasionally just help out others in need for free. There's a lot of scalpers out there! Either way, good luck!
Posted on May 30, 2013
  • 13,433 Answers
Hi
Binoculars of any kind are damaged when dropped, they are out a alingment, I do not think that this will be covered by any kind of warranty, nor repaired for free. You will have to take them to a professional optics / binocular repairer, they need to be alinged again, not something that you can do at home.
Posted on Mar 23, 2011
Is VFR with night vision goggles at night dangerous for civilian pilots?
14 CFR 61.1 (b) (12) and (13) Definitions-Night vision goggles and operations. 14 CFR 61.31 (k) Additional training required for night vision goggle operations. 14 CFR 61.51 (k) Logging night vision goggle time. 14 CFR 61.57 (f) Night vision goggle operating experience. 14 CFR 61.57 (g) Night vision goggle proficiency check. 14 CFR 61.195 (k) Training for night vision goggle operations. 14 CFR 91.205 (h) Instrument and equipment requirements for night vision goggle operations.
Jan 04, 2017 | Aircrafts
Works sometimes
It could be a lot of things; such as, faulty wire connection, cold solder joint, HV voltage arcing, corroded battery terminals. intermittent short in the switches. If it stop work, try gently shaking it several times, push the on/off button several times. make sure the battery makes a good connection in the battery compartment. Wrap it up and put it in your freezer for a few hours. There are electronic components that might get hot/warm and by cooling them down they will start working again. I don't know who manufactured Night Owl NOTG1 Goggles or who manufacture the components. Rissia manufactures make a lot of night vision devises and components. Also, there are a lot of countries in world that manufacture NV devises, and their parts. GB...stewbison
Aug 30, 2011 | Night Owl Optics NOTG1 Goggles
My pvs7 wont stay on thay shut of after 30 seconds and then start to shut of ever few seconds
Hello, have you or someone else pointed this night vision devise at bright lights, street lights, head lights. If so, maybe the damage has/hasn't alread been done. STOP. This PVS-7 goggles with ITT image tube with generation 2 or 2+ or possibly generation 3 tube. The devise is an American made unit, and the best in the world. Nobody can compete with the USA on NV. They sat the standards on Night Vision.
Have you replace the 6 volt battery? Get the goggle in a darken room then turn the switch on.
see if the 25mm plate will turn green and stay on. But first replace that battery.
Therefore, if this test works, then never and I mean never shine NV devises into bright lights, it will destroy them every time.
PS. send me another message and let see what happen. stewbison
Feb 26, 2011 | US Night Vision Ultra PVS-7B Goggles
I recently accuired a pair of an/pvs-7b night vision goggles. When trying them out they didnt work. I checked the batteries already in them, there was no old crusty battery acid. I replaced them and still...
Hello, there two things that can bad. One is the oscilator with voltage multiplier or the image intensifier tube. Send to Morrison Optics Co. GB....stewbison
Nov 22, 2010 | US Night Vision Ultra PVS-7B Goggles
Anycool T828 - Screen
There are three reasons. The LCD got damaged, change it. The connectors got loose/disconnected due to fall, have them fixed again and the display IC got damaged (hope not) as no one can repair it. The phone is scrapped if the IC goes.
Aug 25, 2009 | Cell Phones
1 gogle on my an/avs 9 night vision dosn't work
check wiring from tube to contacts on battery pack, normally the issue. There is a soft circuit board in the PAS shelf check the solder joints, they can come off if you have the dual adjustable PAS shelf
Mar 17, 2009 | Optics
I need fix night vision goggles
Check l that the HV is present at tube. If it is, suspect tube. If not, check the HV circuit - these vary, but most competent electronics trained technicans should be able to fault find on these.
Nov 27, 2008 | Optics
Night Owl Optics Tactical... Problem
you have to focus the blury sides lens and eyepiece
wayne
Apr 15, 2008 | Night Owl Optics Tactical NOBG1 Goggles
Optics Logo
434 people viewed this question
Top Optics Experts
james laughton
james laughton
ray gallant
Are you an Optic Expert? Answer questions, earn points and help others
