Question about Sport & Outdoor - Others
Need to know what the gap setting should be for B02592
Gap setting for 173cc mower
If you know the make and model of either the mower or the engine you will be able to search the online application catalogue of the brand of spark plug that is installed. Such catalogues list the recommended gap.
If you don't know these details, a rule of thumb setting that will be close enough to make most engines run is 0.025".
A few early magneto engines needed a closer gap of around 0.020"
Apr 15, 2018 | Garden
Need to know what the gap is for a sparkplug in a 1997 Thunderbird
Setting is on the federal label under the hood
Jul 17, 2012 | Cars & Trucks
Breaker point setting/gap on briggs&stratton model#100292
set them when they open the most to .020
Apr 10, 2012 | Garden
Need to know the spark plug gap for Homelite 25cc Model UT-20779
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
Aug 04, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
Need do know the spark plugs gap
If you're replacing the spark plugs in your car engine, you'll need to set the gap before reseating the spark plug. The gap is the distance electricity arcs between the ground electrode and center electrode. The gap must be set correctly to ensure maximum performance. Here's how to set the gap of a spark plug.
  1. Remove the spark plug wires. Use a socket wrench to remove the spark plugs from their chambers.
  2. Clean the spark plug if you are not replacing it with a new one. Remove all dirt and debris from the spark plug.
  3. Check the owner's manual for your car (or any appliance with spark plugs) to find out the recommended gap setting.
  4. Use a gap tool to check the gap of the spark plug. Slip the tool between the ground electrode and center electrode. The gap tool should fit snugly at the recommended gap width indicated on the tool.
  5. Push the tool between the electrodes a few times to ensure proper gap. If the gap is too wide, push the ground electrode firmly against a flat surface to narrow the gap and then check again with the gap tool.
  6. Repeat Step 5 as necessary until you reach the correct gap. Reseat the spark plug and reattach the spark plug wires
Good Luck
Dec 10, 2010 | 1997 Pontiac Grand Am
Model TB320BV 2-cycle blower.
there is no set gap realy what i do is put a thin bit of carbord inbetween the coil and fly wheel so there is say 25th of an inch of gap dont set it so tight that the fly wheel hit's the coil or it will distroy it there needs to be a very small gap and it will work just fine,,ok?
Jul 27, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
What is the proper spark plug gap setting for a 2002 Kia Rio
Hello mfriesner71; my name is Roger and I will answer for you. The correct plug gap is 0.027 to 0.031.in. Any gap between these will work fine. Just make sure they all gap the same. Should you need further help please just ask. Please rate the answer. This way I know it was helpful. Thank You for using Fix Ya. Roger
Apr 30, 2010 | 2002 Kia Rio
What is the gap setting on my 70 hp chysler
The gap is .013-.015. You can find info by using the search window and type in chrysler 70hp point gap.
Jun 08, 2009 | Boating
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
