Question about Whirlpool LER4634J Electric Dryer
LER4634PQ0 dryer turns but will not heat pulles heating elemnt out and half of it is black does that mean it burnt out?
No put a ohm meter on it to make sure its not open, it could be your thermostat.
Posted on Aug 05, 2008
Clothes dryer doesn't heat
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
Nov 26, 2011 | KitchenAid Dryers
Dryer runs but will not heat. i just replaced the heating element but it still is not heating up.
you probably didnt need a heating elemnt you need another much cheaper part call me and i can tell you how to find it and get it fixed
steve
210 313 7844
Nov 16, 2010 | Maytag MED5700TQ Electric Dryer
I have a whirlpool dryer does not heat up but everything else seems to work. i repaced a fuse an the heating elemnt an still don't heat what do i do?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Whirlpool Dryers
I have a Whirlpool electric dryer Model #LER4634PQ0 and for the life of me cannot figure out what heating element that I need to buy for it. Please help before I lose my mind.
Call your parts house and give them the model number. They can tell you exactly which one to buy. Are you sure its the heating element? I ask because there are several things that can prevent it from heating. I dont want you to waste money changing parts.
Jun 24, 2010 | Dryers
Dryer wont heat up the elemnt tested good
Make sure BOTH hot legs of your 220 are active. Sometimes, one half of your circuit breaker will trip. When this happens, you will have 120 volts to your drum motor, but an open circuit to the heating coils. Just re-set your breaker by cycling it off and on again. Otherwise, check for continuity of the thermal switch (in line to coils).
Oct 30, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlepool electric dryer stopped heating.
This could definitely cause a dryer no heat problem and a potential house fire. Purchase a new dryer cord and replace it. The following link explains how:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Follow the 3-prong wire color code provided. If the new dryer cord does not have any colors (all gray) simply make sure the center conductor gets connected to neutral (WHITE) at the terminal block on the back of the dryer. There should also be a grounding strap or ground wire (GREEN) attached to the neutral at the temrinal block. Each outer wire will then get connected to either of the two hot (RED and BLACK) terminals.
The reason your dryer still may tumble in spite of a bad dryer cord is because the drive motor only uses 110-120VAC while the heating circuits require the full 220 service. If one of the dryer cord conducters is burned in half, you may only be getting half your input voltage to the dryer. A voltage reading across the two hot terminals (left and right slots) at the wall receptacle should read 220-240VAC. You should also read this same voltage across the red and black wires at the terminal block. If not, you have a bad cord.
If you have any questions, please let me know. I hope this helps you.
Jul 29, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore Dryer not heating
thermal fuse kit.it is blowing due to improper ventilation.their is a clog somewhere from dryer to where dryer vents outside.thermal fuse is located at top of your elemnt cage.you will replace the thermal fuse and your high limit fuse at the bottom of the elemnt cage.but have your venting checked or swept out.
Mar 09, 2009 | Dryers
Runs but does not heat
Sounds like the timer may have failed if the dryer continues to run for hours and hours. And this may be what keeps the heating elemnts from coming on.
Reply your findings and I can help you more.
Jan 18, 2009 | Whirlpool LER5636P Electric Dryer
Dryer not heating
is this a gas or electric
Mar 27, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
291 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
