Question about Toro 52" 27hp Z Master Zero Turn Lawn Mower
Have a toroZ5035 mower 90 turn) with kawasaki engine. **** smoke appears on start up, but goes away when warmed up. choke must be kept on at least halfway or motor dies. changed plugs and cleaned air filter. it was a little high on the oil dipstick, but that was resolved. cant find any carb adjustments.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 344 Answers
**** smoke sounds bad, If what you meant was white smoke then I know what is going on with the mower. The white smoke is from the extra oil in the cylinder head. There are tow causes for this. #1 the engine rings are worn and will not prevent the oil from running into the combustion chamber as the engine sits. #2 the carburetor is leaking fuel into the oil and thinning it out. This thin oil bypasses the rings easier and drives the oil level up too. I would recommend a carburetor rebuild. You can get parts from a local dealer like www.arcolawn,com Good luck have a toroZ5035 mower 90 - barterjoe_64.png
Posted on Mar 28, 2011
Kawasaki lawn mower engine
You probably may have valve seals leaking, or an internally vented carb which is now flooding and sending fuel into the oil, this needs addressing straight away as it will cause damage to the engine as it thins out the oil.
Aug 25, 2013 | Garden
1996 Kawasaki VN 800 Vulcan Classic hard to start when cold
Hi, Pete before you start it in the morning, pull the spark plugs and sniff them. Do they smell like gasoline? Are they wet? If so, you may have fuel leaking past the needle and seat in the carburetor and flooding the cylinders.
Use a voltmeter on the battery an hour after you shut the bike off. It should be at least 12.6 volts. Check it again in the morning. It should still be 12.6 volts or more. If not, something could be drawing current when the key is off.
If it's a carbureted bike and the ambient temperature is warm, you may be over-using your choke/enrichner. Try cranking it with the choke turned off first and then try half-choke, and then full choke. If you start with too much choke it will flood. After it starts, shut the choke off after 15 - 30 seconds and then use the throttle to keep the bike running until it warms up. Over-using the choke will soot up your spark plugs.
A fresh set of properly gapped spark plugs can make a lot of difference in how easily a bike starts.
Engines need a richer fuel mixture when they're cold. An intake leak can also cause hard starting because it leans out the air/fuel mixture.
After you get the bike started, spray some WD-40 or carb cleaner around the carburetor intake manifold seals. If the RPMs change, you have an intake leak.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
cold start issues Kawasaki Vulcan Forum Vulcan Forums
10 Tips To Handle Cold Starting Trouble
Kawasaki vn 800 classic Service Manual
OEM Parts for Kawasaki
Kawasaki VN800 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 07, 2011 | 1996 kawasaki VN 800 Vulcan Classic
The mower was putting out white smoke and then it was choking out. Now it won't turn over/ start.
There may have been too much petrol going into the engine, possibly caused by having the choke on. Ensure the choke is not engaged, and then try to start the mower again
Aug 27, 2011 | Garden
Kawasaki KLR 250 takes about 12 goes on kickstarter to start engine from cold. it seems to make maters worse when you use the choke. so i start it without choke but it takes a lot of kicks to start it
I have a riding mower that is similarly stubborn; try this which works for me: - Full choke for one cycle - No choke but full throttle for the next try; it works for me/it.
May 04, 2011 | 2003 kawasaki KLR 250
I have a Craftsman Yard Man 6.5hp push mower with a Briggs & Stratton engine. The engine starts and runs fine for about 30 seconds or so then slowly dies out. It turns over slower and slower until it...
Have you checked the choke that it is off after you get the engine started,the black smoke is definitely from the choke, if you take the carb off and check that the needle closes when it should,as one can easily do an adjustment by bending the float/tab,rgds
Sep 25, 2010 | Briggs & Stratton Garden
19 hp kawasaki mower motor that dies after operating 45 minutes
well its back to the fule flow,,,i thing the fule lines and carb are blocked up and needs a strip down and a good clean up of all the jets and flote bole this sounds like fule shortage,,,if the engine is only just turning and you try to put it in gear so the cutters start to turn it loads the engine up and it stops!
you say pulling the choke out get it going!!!!! then its short of fule ,,,right!
Jul 15, 2010 | kawasaki Garden
Bike wont kick start or idle , it will coast
first drain the carby, then set your air mixture screw 2 turns out, from the fully turned in position. The starting proceedure is as follows, when the engine is COLD, turn on fuel, pull on the choke fully, and kick the engine over. DO NOT use any throttle, when the engine is cold, and the choke is on. Remember Choke on, NO throttle.
When warm, no choke, and a little throttle when kicking.
May 12, 2010 | 2003 kawasaki KX 125
2006 kawasaki 750 vulcan will not idle , will idle with choke
ok buddy on the carb will be some sort of screw and idle screw turn this in 1/4 of a turn with the machine running until it idles at 1000rpm also the choke will stall the engine when warm the choke is only for cold starts get back to me more info or problems f4d68ca.jpg
Sep 24, 2009 | 1992 kawasaki VN 750 Vulcan
Engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
May 29, 2009 | Garden
Toro 52" 27hp Z Master Zero Turn Lawn Mower Logo
475 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
