There is a bad odour coming from my washing machine
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults', including bad odours, are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Now- if all is OK with the washer, turn your attention to the u-bend and pipes/hoses into and through which the washer water is drained. Check to make sure the odours are not coming from there just in case!
Hope the filter is the problem and good luck!
John C
Posted on Mar 23, 2011
Offensive odour
Have you tried cleaning out the filters? these get clogged up sometimes and if not maintained properly they can build up and release a pungent odour
Here is a video on youtube that wll help you if you do not know how to do this
http://www.youtube.com/watch?v=Q0TiugqnGbk
Aug 16, 2012 | Bosch Washing Machines
A bad odour smell after each wash
check that the gray flexible waste oulet goes as high as it can b4 dropping back down onto waste connection. if the flex comes off your sink trap and drops straight down, food waste from your sink can back up into machine causing smell.
Nov 21, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
When I open the door of my wash machine it smells bad. What would cause this? Is there a lent trap with lent in it, causing this? If so were is the lent trap? Matag Neptune Washer.
Hi dear.I'm bit foreign to this model of Maytag.There for I do not know exactly where is the lint filter on it (Refer it's user manual)but I can help with the Bad Odour.If you are doing COLD WASH most of the time with your washer bad odour happens because of body oil & some other deposits(residue) left or sticks the drum after each wash.Cold wash cause that & if it gets worst mould problem going to start up.That's why you have to run the machine empty on Hottest Cotton wash cycle with some bleach every 6-8 weeks to get rid off residue.You'll see the difference.I hope that helps.Thanks.
Sep 02, 2010 | Maytag EPIC MFW9700S Front Load Washer
Smelly washing machine and washed clothes
This is usually because of a bacteria build up on the machine. Suggested actions: Remove and thoroughly clean the soap tray. Remove the waste pipe from the drain pipe you have it poked into and ensure that all is clean and emptied. If your machine has a filter (Usually behind a 4 inch square door on the front towards the bottom of the machine if one is fitted - this depends on the machine and I'm sorry, I'm not familiar with your madel). Finally, take 2 or 3 DISHWASHER TABLETS put them in the machine's drum and wash at the highest temperature that your machine will allow. Modern biological washing powder uses bacteria to break down and "eat" stains. Bacteria creates unpleasant odours. Dish Washer tablets and powder is designed to kill bacteria. Hope this helps
May 12, 2010 | Washing Machines
Odour
Throw a dish towel and a cup full of baking soda in to a 'small load'. Run it through the first wash cycle but turn off before it hits 'Spin' or 'Rinse'.
Repeat several times.
This should get rid of most odours. If no joy, repeat the process using bleach or vinegar instead of (NOT combined with) the baking soda.
Sep 05, 2009 | Kenmore Washing Machines
Samsung Front Load washer has odour
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Sep 01, 2009 | Samsung WF203ANW Front Load Washer
WT540 Washing machine has a smell coming from it
Based on the front load picture you included with you description...
This usually comes from a build up of soap and dirt that you cannot get to to clean. It is in the inner wall of the outer tub.
You should run a thorough cleaning with a product called Washing Machine Magic. It is designed to reduce this build up over time.
Another way to reduce it is use a very hot wash and put 1 cup of powder dish detergent in the tub before starting it. (yes I know this is a clothes washer). The dish detergent has ingredients to help reduce the odour.
These methods may have to be repeated several times to be 100% effective, but a large part of the odour should be reduced after the first cycle. If more are needed repeat once every couple of weeks until the odour is not noticeable.
The rubber door seal on this model should not accumulate smell but it may have depending upon the machine's age. This will have to be replaced if it has.
Aug 05, 2008 | Hotpoint First Edition FEW10P Front Load...
Zanussi Front Loader washing machine - FLE1216W Bad odour coming from inside the drum. Smells like stagnant water or could be sludge. Tried everything, filter is clean, ran a clear boil wash, and bleach...
I had the same prob -
This was resolved by flushing sump tubes after disconnecting them. the small one was silted up and stank like sewage.
Now have a bleebing which could be related to water levels...
doh!
Jan 05, 2008 | Washing Machines
Bad Odour from Drum
The smell that you are getting is stale soap build up between the inner drum and outer tub caused by frequent use of low temp progs. to remedy this problem do a 90 degree prog with some old towels this will melt the old soap, if you still have the problem add some soda crystals and do the 90 degree wash again failing this your drain hose may be to low causing dirty water from the sink to back drain in to the w/m, raise level of drain hose. hope this is of some help murdozzz
Apr 13, 2007 | Zanussi F1045W Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
