Question about Panasonic Lumix DMC-FZ18 Digital Camera
My zoom in/out isn't working and my camera is less than a year old. Really need it fixed by this w-end. I am hoping there is something I can try on my settings to try to fix it myself before having to send it in for repair. Thanks a bunch
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 23, 2011
HF10 zoom goes without any explicit request
My HF10 started to mysteriously autozoom as well, and I had made no setup changes. I don't have exactly the same symptoms as you describe except that it would begin to zoom when I didn't want it to. I noticed the [I.AF] (Instant AutoFocus) icon, so I went into the menu (Camera Setup - AF Mode) and turned the "Instant AF" to "Normal AF". After that, the autozoom seemed to have stopped. I set it back to "Instant AF" and it did not autozoom again. I wouldn't know how to turn the autozoom back on again even if I wanted to, but thankfully it appears to be gone now. Hopefully it will stay in manual zoom mode. Hope that helps.
Dec 22, 2009 | Canon VIXIA HF10 HDV Camcorder
System error zoom
i changed the memory chip and it worked just fine. something had happened to the chip causing my camera not to be able to function properly. no hammer required! :)
Mar 23, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Kodak ds dc120 zoom digital camera
Ooh, that's a sticky one, and unusual. You're talking about technologies at the opposite ends of the spectrum. Kodak DC120 is a windows 98 orientated 1999 digital camera which needs the kodak viewer software to convert the images (a very regretful step from Kodak). You want to put this software on a 64bit Vista OS.
I really can not see it happening. You can try, but in the most unlikely to work.
The Kodak camera had a resolution of 1.2megapixels, less than mobile phones now a days. Although it is a very robust and reliable camera, a childs camera from a supermarket for $20 will produce better results.
Albeit, I do have the software, old original CD from 1999, 'Kodak Picture Postcard Software'.
I need some direction on this - I don't know if I can post contacts here to get this to you. Can a moderator assist????
**.The best way to acknowledge a response is to rate it.**
Jan 29, 2009 | Kodak Digital Science DC120 Zoom Digital...
Camera won't focus when using optical zoom
I had same problem. Found that doing a complete reset fixed it. Go into setup and at end there is a factory reset. If not working after that would suspect your ccd sensor is on way out. They should last 5-7 yrs. Be cheaper to get another cam with way prices have come down
Jan 08, 2009 | Fuji FinePix S5000 Digital Camera
I just found my husbands old Minolta maxxum 5 AF Zoom lens camera. I don't know how to zoom in. I am trying to take close ups of my infant and it appears that I can only zoom in on objects 4 feet away....
It's not the fault of the camera itself, it's a lens issue. Zoom lenses can only get so close before the min focus is obtained. Unless you have a macro lens (not suited for portraits, which can focus down to mere inches. Most zooms aren't really designed for close focusing though there are higher end lenses that can be less than 1.5 feet.
Hope this helps!
Aug 31, 2008 | Cameras
Fuji Zoom Error Message
drop it on the floor from a few feet I did this and now mine works
Aug 02, 2008 | Fuji FinePix A820 Digital Camera
Fuji Finepix Z1 Zoom Error
I saw another post in this forum were someone suggest banging it on a table a couple times, not to hard that you'd dent it but a good enough bang. Worked like a charm! I tried the trigger and slide method but while the error message went away the zoom wouldn't focus. Try banging it, it sounds bad but it worked wonders!
Mar 06, 2008 | Fuji FinePix Z1 Digital Camera
Zoom not working at all
You have a one year warranty with Canon, you should have all the information about shipping it to them in your original box.
Dec 17, 2007 | Canon PowerShot S3 IS Digital Camera
Zoom error
Knocking the bottom of the lens end of the camera 3 times on a wood table, medium gentle, fixed a zoom error (where it would not focus in zoom)
The camera had been dropped whilst skiing holiday and this method fixed it. Very Happy!.
Nov 19, 2007 | Fuji FinePix Z2 Digital Camera
Zoom Problem with Kodak V603 PLEASE HELP
ok i fixed mine by spitting on the battery contacts and wiping it off on the inside of my shirt...so it basically just needs to be cleaned-but make sure you dry it afterwards or the battery might break or leak
Jun 12, 2007 | Kodak EasyShare V603 Digital Camera
Panasonic Lumix DMC-FZ18 Digital Camera Logo
233 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
