Question about Ricoh Aficio 180 Laser Printer
I have a functional problems SC401, Waht can I do
Ricoh 25513 error sc401
transfer roller area leaking current. clean the area around it of devlp powder causing it to short to ground and change transfer roller and bushings. hope this helps
May 14, 2014 | Ricoh Office Equipment & Supplies
Error codes sc401
try changing the transfer or cleaning it very well
Dec 03, 2013 | Gestetner DSc460 Copier
What error sc401?
Transfer roller positive error problem
Sep 09, 2012 | Ricoh Aficio MP 2000 Black and White...
Wha tis the error code sc401 in ricoh 2400 plotter
there could be following three possibilities
SC401 Transfer Output Abnormal SC401- Transfer Roller Leak Detected SC401- Transfer Roller Leak
for more detail click http://www.smilecopy.com/download/greske.pdf
hope it helps
if so, do rate the solution
Nov 28, 2010 | Ricoh Office Equipment & Supplies
My Ricoh 2232c copier has displayed error SC374 can you tell me what this means?
SC322 Laser synchronization error SC324 LD drive current over SC390 TD sensor error 1 SC374 Development bias leak SC393 TD sensor error 2 SC401 Transfer roller leak error 1
Jan 14, 2010 | Ricoh Aficio 2232C Color Copier
Whirlpool adp 6600 will not function start light is just flashing
Whirlpool adp 6600 will not function start light is just flashing. Waht di I do?
Sep 17, 2009 | Whirlpool 24 in. ADP6940 Dishwasher
My Rico Aficio 200
Please open the front door and turn the blue lever in the middle,
remove the Transfer and Separation unit and check if the bushings of the transfer roller are damaged.
If OK, please give some oil on the shaft/bushings of the transfer roller. This unit may be replaced as a whole unit.
If SC401 re-occurs, please check the Photoconductor unit (drum).
Aug 27, 2008 | Ricoh Aficio 180 Laser Printer
Gestetner 3225
SC401: Transfer roller leak error 1
SC402: Transfer roller leak error 2
-Definition- [B]
A transfer roller current leak signal is detected.
The current feedback signal for the transfer roller is not detected.
- Possible causes -
· High voltage supply board defective
· Poor connection of the PCU
· Transfer/separation unit set incorrectly
Jul 23, 2008 | Gestetner DSm618 All-In-One Printer
Ricoh Aficio 180 Laser Printer Logo
67 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
