Question about GE Washing Machines
I have a top load GE washer only about 18 months old, model WDRR2500K3WW. Problem is the water just trickles in and takes forever to feel and begin the wash cycle. I disconnected both hot and cold hoses and checked the screens and they were okay. I noticed that there are white plastic restrictors or filters of some sort inside the inlets where the hoses connect to the machine. Can these be removed to permit better water flow, or are they a necessary safeguard? I didn't try removing them, as I'm not sure if they would break in the attempt. Any advice would be greatly appreciated. My electric bill was unusually high last month and I believe the extended operation of the machine may be the culprit. Thank you. Don
    Brigadier General:
  • 6,277 Answers
The fine filters should not be removed from the inlet pipes; they are there to protect the workings and, providing they are checked/cleared occasionally, will not restrict water flow.
I think your problem is being caused by a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill and the cold rinses are OK, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Sometimes washers take much longer for the wash cycle because the heating element is caked with limescale and is inefficient (with electricity). A good thing to do (anyway), with the machine empty and switched off, is to pour the contents of a couple of sachets of limescale remover into the tub together with a couple of kettles of hot water and leave overnight. In the morning run a spin cycle which will take the mix through the drain filter and motor, doing absolutely no harm whatsoever!
Good luck,
John C
Posted on Mar 23, 2011
  • dstouthamer Mar 24, 2011
    Thanks John. After my posting I removed the hot and cold water hoses and although the screens did not appear dirty, the cold water screen had a slight bit of orange (probably iron) on it. I cleaned them and checked to see if there were ant blockages inside the hoses by running water through tem. I reconnected the hoses not really expecting any difference, but low and behold, the water is flowing like a waterfall. Thanks again for your reply.
    Don in NJ, USA
Cold water runs slow
Turn the cold water off and remove the hose at the machine. You will find a screen located there and you will need to clean it out.
Apr 27, 2012 | Washing Machines
I have a GE Harmony Profile top load washer. It is stuck on filling during the rinse cycle. It usually stays at 18 minutes for about 15-20 minutes. I usually start adding buckets of water to get it going....
when washers go into rinse cycle they use cold water so the clothes don't rinkle,i would say that you have a bad water valve located on the washer,you can try to run the wash at the beginning just with cold water,if the water comes in slow you have a bad valve,you can then run it on just hot water and see if there's a difference in how fast it fills.the strange thing is that it should pop up with an error code after 6 or 8 minutes because the washer is filling to slow,have you seen any codes come up?if it is the valve the part number is WH13X10017 and that valve is under the top console
Nov 10, 2017 | GE WPGT9360EPL Top Load Washer
Slow to fill the washer
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 10, 2010 | Crosley CAWC529JQ Top Load Washer
Can I reprogram a front load GE washer so I can add a drain and spin cycle that this machine does not have?.Sometimes my clothes come out too wet and it would be nice to spin and drain them again without...
just add another drain and spin cycle and start it up again with the completion of the first cycle. Washing some items like sleeping bags takes forever because they are so darned absorbent and hold more water than a tiger's sieve of a bladder. Another drain and spin cycle should solve the problem.
Apr 20, 2010 | GE WBVH6240F Front Load Washer
My GE Model # WBB4500E1WW washer not spinning
the washer is on but not spining and the machine is about 6 month old
Dec 19, 2009 | GE WBB4500EWW Top Load Washer
Won't turn on - press the start button and nothing. hold it down and it will light up, however water will not start nor does the cycle start. Unplugged it and replugged back in, tripped the circuit and...
Husband came home from work - looked at what was happening. It appears service is needed due to circuit board issue; technician will be at house this am.
Sep 16, 2009 | GE Profile WPRE6100G Top Load Washer
Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Apr 18, 2009 | Kenmore 23822 Top Load Washer
Low hot water pressure in old whirlpool washer forever to fill
If you have verified that it takes longer than 120 seconds to fill with water then you need to replace your inlet valve. You might be able to get away with just cleaning the screen but you should probably replace it. pn 8531670.
However it more likely you have a defective heater and the dishwasher is trying to obtain its optimum operating water temperature unsuccessfuly and thus stalling to heat water longer than it used to.
Mar 31, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Washing Machines Logo
173 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
