Question about Cobra DC4200 Digital Camera
I have a standard 2.0 GB SD card, not an HC. The camera has never used it even when inserted properly. Insert the memory card and nothing happens- nothing is displayed on the screen indicating it is in use. Camera display inly shows 2 minutes woth of video or 26 picture capacity available from internal memory.
    Master:
  • 346 Answers
Hi - First off, did you try formatting the card through the camera's menu system? Did you have a smaller SD card that you used before that worked? According to the manual, which may be out of date, the camera uses up to 512 MB SD cards.
It could be that the manual was released before the larger SD cards were available or it could be a real limitation of the camera. It's hard to know, as there is little real useful information about this camera or company.
You could email their support at support@cobradigital.com and inquire about the camera's SD card limitations or call them at Technical Support: (847) 966-9590.
Good Luck,
Mikeywaf
Posted on Mar 23, 2011
  • 35 Answers
According to the manual for this camera, the largest SD/MMC that can be used by this camera is 512MB. It may simply not recognise anything larger.
Source:
http://www.cobradigital.com/manuals/1/DC4200.pdf
Hope this helps!
My lg does not read 2gb sd card.it tell me to insert a new one.Bt it can read 128 mb sd card
Your 2 Gb is not just an SD card, it is a SDHC card. The first 2Gb SD cards, still were SD, but 2Gb was the limit for the FAT 16 and 32 format and for the normal SD cards. The same happened with the hard disks. They developed the SDHC card, and made the new hardware downward compatible with the old SD cards. So in a new camera, you can insert SDXC, SDHC, SD and even MMC cards. But the cameras, card readers and phones, who were made for SD, can't use the SDHC or SDXC cards.
SDHC can work with memories up to 32 Gb and from that on, it is SDXC.
There still should be some 2Gb SD cards around, but not sure you still can fine one. The producers of memory cards now only make SDHC cards and up. Perhaps you only can get some 1Gb cards as SD card, but perhaps nobody will ever make these cards anymore.
I mannaged to buy a 4 GB SD card a few years ago, but that was the last I ever saw in the capacity. 25264488-uil2tdgcy05knvgzh4oup5lj-2-0.png
Nov 01, 2014 | Cameras
Tip
Computer Cannot read my SD Card
STOP SD MEMORY CARDS ARE NOT ALL THE SAME !This is a very common issue as of late because of the fairly recent addition to the market place with the "HC" and "XD" Cards. I have found most computer older than 2008 wont read HC and XD cards however I'm sure there are USB card readers that can fill this gap available at your local pc shop. Please look Carefully at these different formats Standard SD: 1 MB to 4 GB readable by almost all computers most often up to 2GB rarely up to 4GB 6468175.jpg
SDHC: 4 GB to 32 GB Most older Computers Cannot read the the HC format, good however for NEWER devices such as camera's, video cameras and recent phones (my cannon powershot S80 will NOT read HC format, nor will my 2007 laptop.)
SDXC: 32 GB to 2 TiB same limitations as above, Great cards for Digital Video Camera though!
here is a wikipedia note "Changes to the interface of the established format have made some older devices designed for standard SD cards (≤4 GB) unable to handle newer formats such as SDHC (≥4 GB). All SD cards have the same physical shape, which causes confusion for many consumers"
So.. in closing MAKE SURE your device supports HC and or XC before your purchase one! Also be aware that most of these cards have a lock switch on them to write protect the data, located on the side of the card. It MUST be in the Unlocked position to operate normally. Hope this helps someone out there. please use the thumbs up if it clears up anything for you! Gurvy
on Aug 31, 2010 | Computers & Internet
Micro sd card too big for garmin gps nuvi 1450
A micro SD card is the correct memory card for the 14xx series. A 2 GB should be just fine. Some units can not handle a large memory SD card. This has nothing to do with the physical size however.
Are you sure it isn't a micro SD card that is inserted into a standard SD card adapter? A standard SD card is much larger and will not fit into the 14xx series. Look at the end of the SD card that does not have the gold pins and see if there is a ridge where the micro SD card may be inserted into the larger standard SD adapter. Using a fingernail, you can slide the micro SD card out from the SD card adapter. Also, the micro SD card will only insert one way. Try flipping it over and inserting it again, always with the gold pins facing the Nuvi.
Apr 06, 2013 | Garmin nuvi GPS
I cannot insert my Transcend SD 2 GB memory card in the camera. Is there only 1 type of memory card that can be inserted?
Make sure there's nothing in the slot, and you've got the card oriented properly. The i1237 works with SD and SDHC cards. The Transcend 2GB SD card should work fine.
Jul 20, 2011 | Polaroid i1237 Digital Camera
When pictures are taken they are being stored on the camera. They do not go to the SD card.
You need to get rid of the pictures in the internal memory. If you want to save any of them, go into the menu and find "copy". You will find the option to copy them to a memory card. Then, with no card in the camera, go into the menu and find "format"....follow the on-screen instructions to erase the internal memory. Then your card should work properly.
Dec 28, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Why can't you use 8GB memory card in Z710
I have a kodak z710 camera with a 2 gig card in it. I was wanting to get a 4 gig sdhc and i wasn't sure if the HC would work with this camera. HC stands for high capacity which means it allows the camera to load files on to the card faster. this may be the problem the kodak may not be HC compatable. but as i have said i have a 2 gig and it works fine with that. and i have a friend that has a 4 gig in thiers but once again i don't think it is HC so i would exchange the card if you can for just a regular SD/MMC card or SD card
Jan 20, 2010 | Cameras
New digital memory card inserted and camara reads memory card error
1. Try to format your memory card using a PC/Laptop.
2. Now, insert it in camera and check whether its working!
please rate this advice if it helps....tc! :)
Jan 02, 2010 | Canon PowerShot A530 Digital Camera
A530 has message "memory card full". tried 2 cards same results.
1. First, try to format both the memory cards using a PC/Laptop.
Dec 21, 2009 | Canon PowerShot A530 Digital Camera
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cobra DC4200 Digital Camera Logo
129 people viewed this question
Top Cobra Cameras Experts
Jim Goldsmith
Jim Goldsmith
DROPNDEAL
DROPNDEAL
ray gallant
Are you a Cobra Camera Expert? Answer questions, earn points and help others
