Question about HP (153147-001) Sound Card
My laptop does not produce any sounds and i do not know what to do it's hp pavillian
  • HP Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 23, 2011
DOSE THE hp pavillian dv7 have a burner for cd or dvd
Hello and Welcome to FixYa!
Hp DV7 comes with both, COMBO as well as Super drive. It depends. Most of the models, are usually equipped with Super drive that means, it came with DVD writer..
Have a Nice day,
Concerned.
Jun 28, 2011 | Computers & Internet
My hp laptop pavillian dv6000 shows "operating
The impact wasted your HDD. The reason your recovery DVD's will not work is that there is no OS on the HDD to recover.
You will need to do a fresh install of your OS.
Jan 07, 2011 | HP Pavilion dv6000z Notebook
I am recently upgrade win7 hp nx9110 audio output device not installed msg getting how to resolve
Ok this is kind of common with Windows 7. Although everyone thinks its new its really not just a fairly bug free OS. The HP models running Win7 actually are using the Vista or XP driver for audio. I just ran into that issue a few months ago when upgrading a Pavillian model.
Aug 13, 2010 | HP Compaq Business NX9110 Notebook
Hp lap top will not reboot, restart nor retore
No power or computer does not turn on. Issue: No power or computer does not turn on.
Cause: No power from the computer can be caused by any of the below possibilities.
  1. Connections not connected properly.
  2. Third-party hardware.
  3. Bad power cable.
  4. Incorrect power supply.
  5. Bad battery.
  6. Bad power supply, power button, and/or power board or inverter.
Solution: Connections not connected properly Verify that the power connection is connected properly to the wall and the back of the computer. If the connections appear to be connected properly, attempt to disconnect and reconnection both ends of the cable. If you have a power strip (surge protector) or switch used to turn everything on at once, temporarily disconnect the computer from that switch and connect that cable directly to the wall. This will help verify that the strip or switch is not bad. Verify that the outlet works by connecting a different component to that switch.
Third-party hardware If additional hardware has been recently added to the computer it is recommend that you temporarily disconnect that device or devices from the computer to verify they are not preventing your computer from turning on. Note: If the computer was working fine before you added the new hardware, removing the third-party hardware did not resolve the issue, and the computer is not beeping but is turning on, please see our POST troubleshooting document CH000607.
Bad Power cable Verify that the cable supplying your computer is not bad or damaged by using another power cable. If you have a standard CRT monitor, this cable can be used in place of the computer power cable. If you have a portable computer or laptop, when the cables are plugged into the laptop you should see a power light or battery charge light. If this light is seen, this is a good indication that the power cable is good.
Incorrect power supply If you are building your own computer or if the computer has never turned on since you purchased it, it is possible you are using a power supply that does not supply enough power and/or the incorrect type of power supply. Verify your power supply meets the requirements of your motherboard and processor.
Bad battery If your computer is a laptop or portable computer that utilizes a battery for mobility it is possible that the battery may be causing your issue.
  • If your computer powers on when the cable is connected to the portable computer but not when it is disconnected, we recommend you purchase a new battery.
  • If your computer does not power on when the battery is connected and when the power cable / charger cable is connected, try removing the battery and seeing if the computer can power on with only the power cable connected. If no power is still received, skip to the final section.
Bad Power Supply, power button, and/or power board or inverter If, after following the above sections, your computer still receives no power, it is likely that a hardware component in the computer has failed. It is most likely that the power supply has failed. If you do not plan on replacing the power supply yourself or if you have a portable computer, we recommend having the computer serviced by your computer manufacturer or a local computer repair shop. If you have a desktop computer and plan on trying to repair the computer yourself, we recommend you replace the components in your computer in the below order.
  1. First open the computer and verify the power connections. You may also wish to consider disconnecting the main power cable and reconnecting the power cable to make sure it has not become loose. Also verify the power button cable is correctly connected to the Motherboard.
  2. Replace the power supply with a new power supply.
  3. Replace the motherboard.
Index
Resolved
Dec 06, 2007 | HP Pavilion dv4000 Notebook
Webcam Problems
hi i have the dv2000, same problem you will be able to find an driver at www.hp.com once you have downloaded it and installed
press the quickplay launch button > video music picture icon ,then> hp webcam
Oct 13, 2007 | HP Pavilion DV6295us Notebook
HP (153147-001) Sound Card Logo
19 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
