Question about Miller Trailblazer 302 Welder Generator 907217 907216
What does the code on my miller trailblazer 302,004 mean?
  • 407 Answers
Hi:
That's not a code, 004 means the working hours left before the next oil change.
The display always start at 100 and count down all the way to zero.
If you don't change the oil and reset the count down you will start seeing negative numbers, meaning that oil change is due.
To reset the counter once you change the oil do the following:
Cycle engine control switch from the Run/Idle to Run position 3 times.
If this was useful to you, please vote. Thank you..
Posted on Mar 23, 2011
Miller trailblazer 302 it has 110 volts but no 220 volts
Both sets of the 120? If both of those are there (all 4 outlets), then the machine is producing 220v. So get a flashlight and look into the holes on the 220 receptacle, or check the wires on the backside of the receptacle. All that 220 is, is two 120 volts out of phase.
Feb 19, 2015 | Miller Trailblazer 302 Welder Generator...
Operation manual for a miller trailblazer 302 stock number 907217
www.millerwelds.com have the serial number handy. Click on service, then owners manuals and follow the directions.
Oct 07, 2014 | Miller Trailblazer 302 Welder Generator...
My 302 diesel trailblazer runs for a few minutes then shuts down and flashes HI H20 code ,the manual says its a coolant issue but even with the proper amount of coolant it still does this
You need to "burp" you're coolant system. To do this find the upper Radiator Elbow where it goes into the engine, then, use an allen head to unscrew bleeding screw (for lack of better term). place Rags under so as the spilling coolant is caught as best you can (it's basically a fill bolt style, fill radiator until coolant seeps from that hole, lock her back up, repeat testing.
- Logan P. Clayton
Miller Authorized Service Technician
Feb 08, 2012 | Diesel Miller 907218 Trailblazer 302...
I have a miller trailblazer 301 G . my problem is that i turn the start switch to run and it doesnt run in high speed. this welder only has 24 hours on it.
i have the same machine, had same problem, changed broken springs on carburator and choke, problem gone. air gas ( authorized service tec. showed me how)
Jul 19, 2011 | Miller Trailblazer 302 Welder Generator...
Engine dies when start switch is released on miller trailblazer pro350d
TRY REPLACING KEY SWITCH.
MAKES CONTACT ON START POSITION BUT NOT IN RUN POSITION.
Oct 30, 2010 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Miller Pro 350D and the exhaust flex pipe needed
you can buy flex hose at auto parts stores and fashion your own bends to replace the bad one
Feb 23, 2010 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Miller Trailblazer 302 Welder Generator 907217 907216 Logo
1,298 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
