The monitor shows only No signal - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 23, 2011
VH232H monitor showing no signal....
If it is showing No signal, check the computer that is connected to it.
Insure that it boot.
Oct 21, 2012 | ASUS VH232H 23" Monitor
Reasons of y signals not going to the monitor
Is the monitor showing a blank screen or is it showing the message NO SIGNAL??
If you have a Desktop try the steps below:
If it is showing the message NO SIGNAL, then the video card in the computer is bad, because when the monitor is bad, it will show nothing at all. To isolate the problem plug another monitor on the computer and see if it displays. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original Monitor is bad. If the Borrowed monitor displays the same as your original, then the video card in the computer is bad.
If it is a laptop try the steps below:
May 24, 2012 | Intel Motherboard
Monitor showing no signal and button not working
The monitor needs a signal ( source), i.e., DVD, TV, to show a picture. If your monitor shows no signal then either the source is not connected or not functioning. Check the connections from the monitor to the source. Also, check that the source is functioning properly and is receiving power.
May 24, 2011 | Sony XVM-H65 6.5 in. Car Monitor
MY MONITOR SHOWS: VGA No signal DVI No signal then shows: Check Video Cable Then: Monitor going to sleep
Try another cable, borrow one, then try monitor in another PC / laptop, if it works then either the software settings for the sleep mode are on or it may be a faulty video card.
Oct 15, 2010 | HP Compaq WF1907 Monitor
Screen monitor self diagnostics show
that means no incoming signal, but some problem i encountered related in vga cable and lost connection on ckt board. as long that the cpu is working and the monitor show (no signal) focus trouble shooting on that parts. replace cable if possible( same port configuration)
Apr 20, 2010 | Princeton Digital VL2018W Monitor
"no signal"
"no signal" means that the monitor is not receiving a video signal from your computer or laptop. This is normal if the compouter is OFF and the monitor is ON. Is the computer still on and connected to the monitor?
Mar 27, 2010 | Princeton Digital VL1514 Monitor
My computer is not working shows keyboard erro and stop
Hi...
When you monitor saying which is no signal this is a monitor port problem. Check your monitor connector if it is properly connceted to the motherboard. That is the only way of monitor saying no signal.
Regards
PCmania
Aug 22, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Monitor shows ''NO SIGNAL''
This is normal. The monitor is telling you it is not getting a signal from the computer, which is true because you've turned off the computer. The monitor power is still on, however. The monitor power is not controlled by the computer power switch. Just turn it off with its power switch after you shut off the computer.
Nov 23, 2008 | Computers & Internet
My monitor not turn on when the computar turn on to . and when you try to turn on the monitor its like flash for 1 sec and tune off to black . to turn the monitor on i need to prees the botten 30 time on...
First you sec your monitor power cable is not loos or power in properly if ok then you sec your monitor VGA cable is properly conect to your pc if ok then you disconnect your VGA cable in your pc then you power on your monitor and sec that youre monetor screen. show a masege or not masage like tiis : CHEEK SIGNAL CABLE or NO SIGNAL : if show this signal then you men your display card is not responding or monitor shows nothing then you meen your monitor is faulty then contact any monitor techenican and solve your monitor problem.
Jul 19, 2008 | Computers & Internet
Monitor shows no signal
ur monitor is "not" the problem... you have problem in ur PC..
solutions:
check loose graphic card
remove ram. put them back again/...
Feb 11, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
80 people viewed this question
Alun Cox
David Payne
David Payne
