My HP Pavilion A1210n doesn't power up anymore after I upgraded the memory. It doesn't start when I press the power button on the bottom front.
  • frenchbiker Mar 24, 2011
    The computer doesn't power up without the added memory either. I tried both ways. I checked HP's website and there's a page for troubleshooting power problems. The symptoms I have point to a defective Power Supply.
    The memory I bought is PNY 2x1GB 184-Pin DDR SDRAM DDR 400 which is what HP recommends. I'll call PNY this morning but the fact that the computer doesn't power up in the pre-memory upgrade configuration leads me to believe it's the Power Supply, not the memory.
    Master:
  • 515 Answers
Looks like the memory is not supported by your computer or the memory is not working. Switch back to original memory works? Sometimes your computer only support a certain amount of memory by each slot. Smaller memory may work. Use only one memory at a time and see whether that works. Basically you might need to contact the memory manufacture and see whether their memory are supported by your computer for your specific make and model. Sometimes they use incompatible technologies which cause the issue. Basically the memory manufacture will know which computer it does not work with although the main category of memory looks OK. I checked your model of computer with the link below. Make sure you get PC3200 DDR SDRAM, not the common DDR DRAM. And according to the operating system a certain amount of memory should be installed for your operating system to start.
Specification link of your computer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00471049&lc=en&dlc=en&cc=us&product=1118241&key=null&site=null
Posted on Mar 23, 2011
Service Manua
Get the motherboard model use that.
Apr 07, 2014 | HP Pavilion a1210n (ED895AA) PC Desktop
Need Win 7 x64 Sound Driver for Pavilion a1210n
go straight to realtek,com and download the drivers you may need to download several if you do not have the exact model
Feb 24, 2012 | HP Pavilion a1210n (ED895AA) PC Desktop
HP a1210n power LED on back flashes and unable to boot up computer. Recently installed memory upgrade and had to unplug 20+4 plug from motherboard and plug back in once the sink was charged up. Worked...
Try disconnecting the plug form the motherboard. If the LED stays lit, you may have a problem with something you touched inside. But, if the LED does not come on at all with nothing connected, the power supply is dead. 300W should be enough to run your computer, unless you have multiple graphics processors or too many peripherals, but just upgrading memory shouldn't make a difference. Make sure the memory is seated correctly, maybe try taking them out and putting back in, or check to see if maybe you loosened something inside while you were in there.
Jan 08, 2011 | HP Pavilion a1210n (ED895AA) PC Desktop
My "hp pavilion a220n" won't power on. ... I was
Pull the power cord out and press the power button on the PC to drain the power for 10 seconds. Then plug the power cord back in and turn the computer on. If still does not work, then the power supply may be blown out and needs replacement.
Dec 23, 2010 | HP Pavilion a220n (DK218A#ABA) PC Desktop
Check all wires for loose connections--- if the memory was wrong or something, it would still attempt to boot but stop during the POST and start to beep
I am attempting to put 2 gigabytes of memory into Hp Pavilion a12
What is the Brand name and the model #? on most computers, you should be able to pull the panel on the side of the tower off. it is usually on the left side. Sometimes there is a tab in the back to pull or two screws in the back you remove in order to remove this panel. Once the panel is off, You should see one or more slots where the memory chip will fit in. On each slot, there will be a tab on each end. push the tabs away from the slot so that the memory chip will fit in the slot. After inserting the memory chip, the tabs should automatically close to lock the chip in. If they dont, make sure the memory chips are pushed in all the way and push the tabs in manually. Then put the panel back on the side and start the computer. Never do this while the computer is running! Also, If you have to use a screwdriver, DO NOT USE ONE THAT IS MAGNETIC!! this can really screw your computer up.
Feb 20, 2010 | HP Pavilion a1210n (ED895AA) PC Desktop
Computer beep problem
Try taking out all RAM modules and reseating them again, as it appears that one may not be slotted correctly. Be sure not to touch any of the Gold leads with your fingers, and of course make sure the power is off, the plug is removed, and then press the power button for 10 secs. to drain and charge in the board before proceeding.
Jan 10, 2010 | HP Pavilion a1210n (ED895AA) PC Desktop
Hp Pavilion dv2116wm doesn't start. I've tried removing the battery, removing the hard drive and memory cards. After I remove the battery I hel down the power button fot a while but the pc didn't start. I...
hi frnd...
just remove the battery and ac adaptre from the sys and then press and hold the power button for 30 second... then try powering on the sys with battery and adapter... k..
Take Care..
Sep 21, 2009 | HP Pavilion dv2000t Notebook
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
