Question about Armitron Watches
Lost my directions i need to set time and day of week.
    President:
  • 2,501 Answers
You can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine
and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
Posted on Mar 23, 2011
My DZ4067 functions in the non-English day of the week for 21 hours a day now. How do I change it back so the the day of the week is in English for 21 hours a day?
The "day of the week" wheel on your watch actually has 2 settings on it--one for English, one for another language (often French, but could also be Russian, Japanese, Korean, or any other language, depending on the intended distribution of the watch). You'll need to shift the day track over by "half a notch," so to speak, to get things back in alignment.
The crown you use to set your watch can be pulled out into 2 positions. If you pull it all the way out, you set the time. If you pull it half-way out, you can set the day and date. If you turn the crown clockwise, you advance the date. If you turn the crown counter-clockwise, you should be able to change the day of the week. However, instead of turning the day back a full day, stop when you get a day with the correct language on it. At this point, pull the crown out all the way and manually advance the time 12 or 24 hours until the day and date advance as they would when the watch is running. This is to check that you've correctly gotten the day track correctly oriented. You may have to repeat this process a second time to get it right.
Once you have the day back on track, adjust the date and time, and you should be good to go.
Diesel's own directions, which can be found here: http://store.dieseltimeframes.com/common/images/customercare/instructions/ENGLISH/Diesel_Core-Inst_ENG.pdf are pretty cryptic, but they do have a diagram that might help a little bit. You'll want to look at the section for "Day/Date Watch IS02, 507.2-3, 517.2, 2105, 2305, 2405"
May 26, 2011 | Diesel Watch Style # DZ4067
How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Jul 21, 2010 | Watches
Need help adjusting the day to english
Usually pulling out the crown to the second position sets the time by turning in one direction and the day by turning it in the other direction. I some you will need to advance the time through 24 hour cycles till you get the proper day displayed and then set the date.
Jun 19, 2010 | Watches
Lost my instruction manual
need to set day,because it's shows from the day before, date is ok...thanks
Jul 02, 2009 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Lost directions for ProSpirit Fast Wrap
press the mode button untill you get to the setting where the seconds are flashing.hit the reset button to menuver through the hours, minutes, days, and months.
Jun 16, 2009 | Watches
Change the day of the week
Most watches have a stem that you pull out to set the time. The little knob on the end of the stem is called a crown. For a day/date watch, there are two clicks. The first click when you pull out the stem is the day / date setting, the second click sets the time.
When you are on the first click, twisting the crown one direction changes the day of the week; twisting the other direction changes the date. If yours has only the date, it could be either direction depending on the manufacturer.
Jun 15, 2009 | Guess Collection Textured Dial Watch
Date setting of Frederique constant
hi
never change week or date when day is on "sun" or "mon" also never change date or week or day when time is between 9 pm and 5 am.
to change day, move time back and forth between 10 pm and 2 am.
moon will change only after 24 hr round (not during quick day change)
hope this helps
eli
Oct 17, 2008 | Watches
I have a CASIO C-K33R1-1 sports watch and we have tried for hours to follow the direction booklet as to how to set the day, date, and time. Do you have any easy directions? Joe nsjd1@comcast.net
I just took out my new Casio C-K33R1-1 (module 1636) watch. It's no wonder you're having a problem. The directions are incorrect! Instead of pressing Button C (bottom left button) to increase the value of the flashing item (seconds/hour/minutes/day of week/day of month/month of year) try pressing Button B (top left button). Press button C only to return to timekeeping mode after setting the time, etc. Button C aslo alternates among the following modes with each push: Alarm, Stopwatch, Time Setting, Timekeeping.
Hope this helps.
Jul 11, 2008 | Casio Watches
Prospirit watch
in order to SHUT OFF THE ALARM:
go to the normal time setting, where nothing is flashing. then press and hold reset. then the time you want the alarm on shows up. in order to turn the alarm off press start...press start again to turn it on
May 15, 2008 | Watches
Watches Logo
Top Armitron Watches Experts
Ansel Alberto
Ansel Alberto
Bill Boyd
Are you an Armitron Watch Expert? Answer questions, earn points and help others
