Question about Sony Cyber-shot Dsc- W350
Lens keeps going in and out will not focus. Then screen says "Turn ower off and on again", and this doesn't do anything. Camera remains unusable.
    New Friend:
  • 3 Answers
Nout do with what the guy above said mines doing the same!! As soon as you turn it ont he lens just goes in and out saying turn power off and on again, which as you say does nout. Not impressed with me sony camera at all! Canon it is next time! 3 months out of warrenty too! Post again if you figured the issue out im hoping i can or hammer time :@)
Posted on Dec 27, 2012
  • 2,574 Answers
Follow the steps below to troubleshoot if the camera will not focus correctly:
  1. Ensure the camera is set to the Auto Focus (AF) mode.
  2. Set the zoom all the way to the WIDE position.
  3. If the camera has a Conversion mode in the menu, ensure it is set to ON .
  4. If the camera has a MACRO mode, ensure it is turned off or disabled.
Posted on Mar 23, 2011
I can't get rid of 'Lens Error' message and keep my camera switched on for more than a minute.
You don't need to drop a camera to get a lens error. Could be anything, from holding the camera in a wrong way (touching the lens barrel) or a bit of dust in the barrel or a gear, or a gear that breaks off. If the lens retracts correct when the camera is switched of, and comes out to the full extend when it is switched on, you should think everything is in working order. But when you say, the screen looks ver blurry that could be an indication, the lens is not coming out correct, or the focus mechanics does not work correct. I'm afraid you have to bring the camera in to a service centre (or buy a new one) if you can't solve this, by again take out the battery, charge the battery and reinsert the battery.
Jan 26, 2014 | Nikon COOLPIX S3300
There is something wrong with my Nikon D3000. It turns on but doesn't show anything on the screen and when I look through the lens it's shows a grainy dark film. It can't be the lense because I...
There seems to be two separate issues here. I'm going to assume you have a charged battery pack in the camera.
First, the screen. Turn the camera on. Do you see the menu when you press the MENU button? Does the shooting info show when you press the Info button? Can you see previously taken photos when you press the Playback button? If none of those show up then something is wrong with the screen (or the battery is dead).
Second, the viewfinder. First, make sure the viewfinder in the back is clean. Now turn the camera on and look through the viewfinder. Do you see the eleven focus marks? Do you see the info at the bottom? Now turn the camera off and remove the lens. Don't touch anything inside the camera! Do you see a mirror at a 45-degree angle? Is it clean? Look at the focusing screen above the mirror. Is it clean? Now look through the viewfinder and point the camera out a window. Do you see a more-or-less white blob, or the same grainy dark film?
Apr 11, 2013 | Cameras
Lumix DMC-ZR1
This is a lens mechanism fault. USe can of air and spray on surrounding the lens For cleaning the dust. and then try.
Aug 05, 2012 | Panasonic Lumix DMC-FZ28 Digital Camera
When I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's...
When I turn on sony cyber-shot camera I get a Problem with the Sony Cyber-shot DSC-W35 Digital Camera when I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's wrong??
Oct 12, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Our Canon EOS Rebel XSi no longer works on auto focus. The flash works but the camera just makes clicking noises and the screen says "busy". Any suggestions? The camera works fine in manual...
Optical focus relies on a gear driven motorized system to focus the lens. It sounds like the drive is either frozen by a foreign object (it doesn't take much) has gotten into the system, or a tooth has worn/broken on the gearing.
Try taking the lens off and blowing the camera out with some canned air. If that doesn't do it, it's a trip to the repair center.
Jul 04, 2011 | Canon EOS Rebel XSi Digital Camera
When I turn the power on, the screen shows "turn
This type of problem can be caused by either a lens issue, or power problem. The following web blogs delineates things you can try to get the camera working again. They say about 50% of the time they can be fixed trying their suggestions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If none of those things helps, try these steps:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If the camera still doesn't work, you can take it in to a local repair shop, but get an estimate first. Repair can be high, and justify just going ahead and buying a new one.
Good luck, and hope this helps.
May 27, 2011 | Sony Cyber-shot DSC-N1 Digital Camera
My Cyber Shot DSC W55 when i open it the lens keeps moving forward and backward and then something shows on the screen which says First "ACCESS" then the next one is "Turn The power off and...
Error: TURN THE POWER OFF AND ON AGAIN or Access is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks for contacting FixYa.
Feb 24, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
My camera cant focus on anything
It seems as if the lens isn't installed properly, make sure it's screwed in right in its mount.
Tom
Jun 20, 2009 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Will not focus
First Send me your camera's model (Brand Name)
Some digital and analog camera in these days has features to manualy set the focus in our wish.
Try to disable this feature. And try not to poke or push the lens of the camera. By doing this you may destroy the lens.
And try to reformet the mem stick + try to reset the camera.
(Everything will be resetted, "it will be as if you have a new camera")
Feb 03, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
Sony Cyber-shot Dsc- W350 Logo
163 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
