Maytag Neptune MDG5500AW Gas Dryer Logo
A
Anonymous Posted on Mar 23, 2011
Power went out. now is restored. However trying to use the dryer the panel lights and allows me to choose temp and time dry however the start button flashes and won't let me start the dry cycle. Does the dryer need to be reset? how do i do that? I have unplugged it and replugged it. What impact would a power outage or restoration have on the dryer?
jerry earick
Level 2:
New Friend:
  • Expert 96 Answers
  • Posted on Mar 24, 2011
jerry earick
Expert
Level 2:
New Friend:
Answers
96
Questions
Helped
17072
Points
191
1helpful
Dryer chirping along with the following: start button flashing, dry temp on high light lit, 56 on timer timed dry lit and dry time selector lit was on sensor dry when we left and turned off
Disconnect power or turn breaker off for about 5 minutes. This may reset the unit. Otherwise you have an eror showing and need to retrieve the error code. Google your make and model followed by error codes a d you should get a link to retrieve the codes.
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 • Dryers
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 • Dryers
5helpful
2answers
Washer will not start. "Clean"
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 20, 2011 • Dishwashers
5helpful
The problem started with it not draining correctly and leaving water in the bottom - my husband took it apart and found a bolt in the drain. He removed it and now it won't start. It appears to not have...
Hello, Welcome to FixYa. The reset on your dishwasher is as follows, ( I can't locate your particular model number...but its madw be whirlpool so there are only a couple of possible sequences ) however depending on the error which caused the reason for wanting to reset it, it may be futile and the error will return. Depending on what was done trying to service the unit. On the control panel push these buttons in a back and forth sequence within 3-5 seconds. With the unit in the "off" status ( no lights on ) Hi temp scrub - energy save dry ( air dry ) Hi temp scrub - energy save dry Hi temp scrub - energy save dry Close the door if not already closed, all the "leds" should light and it will advance through an abbreviated test cycle. Allow it to complete and you should be good to go. There is also an extended service diagnostic which can entered that requires approx. 20 mins. to complete. Let me know how you make out with this one and we`ll move forward if necessary. Thanks for choosing FixYa and good luck. Regards, Macmarkus :)
18helpful
2answers
Clean button is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
6helpful
3answers
Maytag dishwasher Model MDB9150AWQ won't unlock
try this keystroke..."high temp wash" "heated dry" "high temp wash" "heated dry"
Clean light flashing 7 times. Can't start the machine
The cleam light blinking means that the unit was not able to reach a proper heated wash cycle. Either your heating element failed orthe actual sump/pump motor system has failed. Check the element in the botton and see if it looks broken anywhere. If you can see a broken spot, you will k now that is the trouble.
Good Luck!
1helpful
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
3helpful
8answers
Need help with dishwasher
I misplaced my diagnostics paperwork, but I found you here and you saved my life!  The wife is much appretiative!
~Teddy Bear
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
