The heater does not always come on when called for.I hear it clicking like it wants to .When I open the top door it comes on.
    Brigadier General:
  • 4,736 Answers
What type of heater is it (Manufacturer and Model Number)?
Posted on Mar 23, 2011
NO HEAT STUCK ON AC HEAR CLICKING IN CENTER CONSOLE
Air Temperature Control Blend Door Failure No Heat or no AC (dependes on where door sticks)
In all modern cars there is a tiny DC electric motor driven gear drive that moves a plastic door that blends heated and cooled air from the AC and the heater core, this is called (interestedly enough) the air temperature control blend door actuator. The motor that moves this door fails because the door starts sticking from warping, most common complaint is no heat but it can be no AC as well. To replace these parts (blend door and blend door actuator) you must remove the entire dash from the car. Always have this problem confirmed by a dealer or qualified repair shop as it is a very expensive repair.
Other causes of no heat in the cabin are engine thermostats that are stuck open (engine runs cold) or air bubbles in the cooling system.
Nov 05, 2012 | Cars & Trucks
Freezer developing frost while the fridge is warm
The frost build up is causing airflow blockage to fresh food compartment. Frost build up is either a sign of poor door seals, door left open, or bad defrost circuit. If after manually defrosting and after a few days the frost reappears, problem most likely is with the defrost circuit.
If you have some background of electrical circuits you may attempt repair yourself or call in a tech.
Defrost timer on your unit is near the light in the refrigerator. Recessed in a hole, turn with a flat blade screwdriver and advance timer until you hear a click and refrigerator turns off. After a few minutes the heater should come on and should hear moisture hitting heater in freezer compartment in back panel.
If heater is not coming on, could be a bad heater or defrost thermostat is bad. Both of the parts are accessed through the back panel inside of heater. Unplug and ohm check for continuity of heater & defrost thermostat. Heater is a cal rod unit, thermostat more likely to be the problem. part #5303918202
Jan 30, 2011 | Frigidaire FRT21P5A Top Freezer...
The water dispenser wont dispense water. Line is open and on. I
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Dec 23, 2010 | Whirlpool ET1FTTXK Top Freezer...
I have a top loading whirlpool washer. For some reason it stopped spinning. The water is coming in and draining I can hear the motor running but it wont spin. Any suggestions of how I can fix it without...
it sounds like the drive cupler or also known as motor cupler,,,tilt unit back and look underneath washer,,recomendid to have someone hold it so it wont fall forward on you,,then look for a plastic and rubber oreo cookie that is the cupler,,located between motor and transmission,,,second issue and a bit easyer door lid switch or safty switch,,lift cover and slowly close if you hear a click it is ok no click means no good,,,it shold click at the closed point,,if not unit beleaves door lid is always open and will not spin,,,also if unit aditates but no spin it is normally the door swich as well www.myabcspace.com/washerwizzards
May 17, 2010 | Washing Machines
Water won't come out of door dispencer. Can hear it clicking and a buzz but no water. Ice maker has water in the tray.
Apr 08, 2010 | Refrigerators
TOp Oven Light ..
if its a brand new unit (still in waranty) make the service call
Aug 30, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Kenore elite bottom freezer, top fridge stopped cooling
first check that you can hear a fan in the freezer..if the fan is running you have a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Aug 24, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frigidaire electrolux model # FRT1865AW6
218169802 HEATER-DEFROST
5303917954 THERMOSTAT-DEFROST
5303917954 TIMER-DEFROST
Start with the timer. it in the refer middle top . there is a knob you can turn it slowly with a screwdriver .until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
Aug 23, 2008 | Refrigerators
Frigidaire Gallery FRS26ZGEB - 12 years old
you have a defrost problem or damper problem or evapator fan
1) Check the fan in the freezer is running
2) defrost the freezer (leave unpluged with door open for 24 to 48 hrs or untill it stops leaking water...
3) check the damper make sure it is opening and cold air is blowing
How you need to repair what defrost part failed
Jul 03, 2008 | Frigidaire FRS26R4A Side by Side...
Odd sound
whoa gonna call - GHOSTBUSTERS !! I would start by replacing the light bulbs first. Has it always done this ? It dones seem odd. Maybe the switches are sticking. Do you hear a buzzing sound when you open the door? Where do you think the sound is coming from, the front or the back of one side?
Jul 11, 2007 | GE PSC25PSS Side by Side Refrigerator
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
