Question about Ovens
Power to oven lights but not to cook top or oven. checked pigtail and breaker, both ok. Thermal cutout?
    Sergeant:
    Champion:
  • 202 Answers
Yeah sounds like a Thermal cutout to me ... do you have 120V on both sides??
Posted on Mar 23, 2011
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
My stoves 720ef oven keeps cutting out after 20 minutes and will not turn back on, the grill continues to work ok. I know the timer is set to manual so I guess it must be a thermal trip. As I do not have a...
There are seperate thermal (overheat) cutout devices for both the top and bottom ovens. First check to see if the lower oven fan is running ok and is not restricted by grease or fat (there are 4 self tapping screws that hold the fan cover on) and the thermostat is switching off and on as it should. You should also check that the main background cooling fan is running and switches off a few mins after the ovens have turned off. If these check out ok, then it is possibly the lower oven thermal cutout.
Aug 04, 2010 | Stoves 720EF Electric Double Oven
Our display panel light went out on our model w30400p jenn-air single wall oven.
Make sure there's power getting to your range, oven or cook-top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. I would also advise to inspect the junction point on the backside of the unit for a possible separation of the power cord as well. If all checks out ok, The main control board will be the culprit.
NOTE_ If your unit is equipped with a relay board, this will be the likely culprit, if all checks out ok. If there is no relay board present inside the unit, replace the main control board.
Jan 02, 2010 | Jenn-Air Ovens
My oven want come on
Make sure there's power getting to your range, oven or cook-top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. I would also advise to inspect the junction point on the backside of the unit for a possible separation of the power cord as well. If all checks out ok, Then, the main control board will be the culprit. It must be replaced, in this case.
Dec 10, 2009 | Stoves Ovens
The oven model EOB 966X has turned off, no power
Make sure there's power getting to your range, oven or cook-top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. I would also advise to inspect the junction point on the backside of the unit for a possible separation of the power cord as well. If all checks out ok, control board(main)l will be the culprit.
Nov 03, 2009 | Electrolux Ovens
My zanussi cooker has just lost all power to it any help please
Make sure there's power getting to your range, oven or cook-top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. I would also advise to inspect the junction point on the backside of the unit for a possible separation of the power cord as well. If all checks out Ok, control will be the culprit.
Sep 15, 2009 | Ovens
Wall oven controls do not light-up or function.
i cant call you but iv seen this a few times the display part of the board went out (you can still probably get it to cook but cant see the temperature) you are gonna have to replace the board.
Dec 12, 2008 | KitchenAid Architect Series KEBC107KSS...
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Stoves 720ef electric double oven not working
According to the circuit diagram on page 31 of the handbook, power for the ovens passes through the clock. The power feed is direct for the actual clock but via a seperate Thermal Cutout for both the top and bottom ovens. I think it is highly unlikely that both Thermal Cutouts have failed at the same time. I would try turning the power off totally to the oven for a while and then turning it back on, set the time and ensure the oven is in manual mode. As the top and bottom ovens have seperate controls after the Programmer and both are not working, it has to be the programmer that is not extending the power through to the rest of the oven.
Nov 11, 2008 | Stoves 720EF Electric Double Oven
Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Jan 30, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
Ovens Logo
41 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
