Question about Acomdata BIO500UE Enigma Ruggedized with 128-bit AES Encryption - 500GB - External - Blac... USB 2.0 Hard Drive
My bio500ue enigma 500g acomdata hardrive, works just fine on my computer with windows vista, but my new computer with windows 7 doesn't recognize it and gives me messages saying it hasn't installed properly so I cannot use it.
  • 158 Answers
Your windows 7 is trying to use the native driver for usb hard drive, but its having a hard time installing it so thats why you are getting it hasnt installed properly, you may want to install a driver specifically from your HDD manufacturer try to look for the driver on the website. you can also use the driver for vista on 7. hope that helps
Posted on Mar 23, 2011
Acer Aspire one 722 windows 7 netbook. "Check cable connection" and "no bootable device--insert boot disk and press any key" are two common things appearing. The computer recognized hardrive, hardr
Hello, it looks like somehow the master boot record was erased from the hard drive, maybe viral? You mentioned the hard drive was recognized in the bios correct? If you need data from the hard drive the easiest way would be to pull the hard drive out and use an external hard drive enclosure to remove the data before you erase everything from the hard drive. If you dont need anything thing you can proceed to do a new install of Windows 7. Turn the computer on then hold alt and the f10 key to perform a factory recovery. This will erase everything and reinstall Windows 7. If this doesnt work then you will need a new hard drive and a bootable usb drive with Windows 7 on it. Hope this helps.
Feb 22, 2013 | Computers & Internet
My windows 7 (x64) will not Acknowledge My AcomData HD250FAPE5-72 External Hard Drive, What do I do.
Having looked at the review of this device, it doesn't sound good. There is a problem with these but if it shows up in explorer you can use it. The other problem is that it is not windows 7 recommended. Have you tried to use it with the firewire connection? You may have better luck, but Windows 7 has to have "Signed Drivers" for all hardware (they have to be vetted by Microsoft) Good luck.
Mar 20, 2012 | Acomdata Computers & Internet
Hi my blue light for the external hardrive turns on all the time but my computer just wont detect it \r\ndoes this mean that my hardrive doesn' work anymore? is there anyway i can all my files bac? thank...
If it used to read it, but doesnt anymore, could be a sign of a hardware failure. If another computer reads it, then it is probably a driver issue. Try to turn the power on, then insert the USB cable into the computer.
May 03, 2011 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
I have a Acomdata 500 Gb external hard drive. Model #: BIO500UE Ser#: B1001756. After typing in my password, I get the following msg. The secure device might be abruply removed or unplugged. Please...
Unplug, restart, plugin.
If that does not work restart your system with a life linux cd (does not install) and connect drive.
http://www.linuxmint.com/download.php
Feb 13, 2011 | Acomdata Samurai PRO 500GB USB 2.0 / IEEE...
Windows xp will not restart with usb plugged in. I am running windows xp sp2 with a Hitachi 500g external hardrive that is designed to turn on and off with the computer. The same hard drive works fine on a...
Sir, your PC might have been checking for external devices which plugged in to boot from. Thats wrong. So get into the bios of your computer while startup and change the 1st boot device to your computer's hard disk. And its a bad idea, starting your computer with a usb device plugged in.
Jun 29, 2010 | Hitachi 500GB External USB 2.0 Hard Drive
Acomdata HD120U2FE-72 120 GB external Hard Drive
OK, 2 things to check. First and foremost, when you plug it into the PC does it make that nifty noise to let you know it sees a new piece of hardware?
Second, if it does, you probably need to initialize the disk. Hit the windows button, right click on computer, and select manage. Under the storage category highlight Disk management. If you see the drive there, you can right click and select initialize, or format. From there the system should see the drive.
Feb 06, 2010 | Acomdata HD120U2FE-72 120 GB Hard Drive
Acomdata external harddrive is not recognize on vista
I had a similar issue with windows 2008 and windows 7. the drive lost all its info and had to be reinitialized under both of those O.S.'s..
You can try that as long as it doesn't have any data you need.. Once you do that the drive will work and you can start using it. The file system under vista and above is slightly different than xp.
Sep 12, 2008 | Acomdata 500GB External Firewire HD 500 GB...
Acomdata PHD160 didnt work for Window VISTA
My probleme is who to get drivers to install it on my PC.
Thank you.
May 09, 2008 | Acomdata PHD060U2E-54 60 GB USB 2.0 Hard...
Acomdata BIO500UE Enigma Ruggedized with 128-bit AES Encryption - 500GB - External - Blac... USB 2.0 Hard Drive Logo
269 people viewed this question
Top Acomdata Computers & Internet Experts
Donna Sander
Tom
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
