Question about Dell 9M905 Storage Controller
Need help deciphiring red led error codes on Dell 9m905 scsci controller
  • Dell Master
  • 27,725 Answers
Click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
uninstall the program, reboot your computer, and then install the latest version again from scratch.
until you know what the problem is you cant fix it or you might try
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive this should schedule to happen when you restart your computer then defragment your hard drive
do not do anything while chkdsk is in process any input may damage your computer
or you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
hope this helps
Posted on Mar 23, 2011
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Tip
XBox360 error codes (Three Red Lights of Death, Red Ring of Death, X-Clamp)
Hi.
XBox 360 error codes are displayed with flashing lights in the ring of bi-color LEDs located around the start button, like in the picture below:
They are often called lights of death. The technical name from Microsoft is Light codes.
LEDs located around the start button can be green or red. When they get red it means that there is a problem.
When the XBox is operating normally The leds will be green. The number of green segments indicates the number of controllers connected to the Xbox.
Here a working Xbox with one and four controllers connected to the console:
If the lights are red instead of green, then there is a problem. Here the four common error codes:
A: The code in picture A, with only one red segment on and flashing on the fourth quadrant, means that there had been an hardware failure. The internal component failing is often not specified.
The light code is accompained by an error message on display, telling a numeric code that can better address the cause of the fault. The best thing to do is contacting Microsoft to find out the reason for the code. Depending on the code you may also be asked to perform a secondary error code retrieval procedure.
In the Example above E74 means that there is an hardware fault on video connections or GPU.
B: If the first and fourth quadrant LEDs are on, that means that there had been overheating. Internal fans, CPU and board must be tested.
C: General hardware failure. This means that the console detected an internal failure, but no error code is displayed on screen. Call Microsoft to get instructions on detecting secondary code or sending the console for repair.This error code is commonly called Three Lights of Death.
D: The last error means that there is a problem with the AV connection to the monitor or TV. The code is not displayed if you use HDMI connection, in that case you get an on-screen error code. Test using different cables. If that does not fix the problem, this error means that the XBox Gpu is fried. This error code is commonly called Red Ring of Death or RROD.
In the near future I plan to publish a new article explaining how to troubleshoot secondary error codes. In the meanwhile, if you need more support, you can ask a question to our experts or contact Microsoft.
Regards.
on Apr 08, 2010 | Microsoft Xbox 360 Console
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Code #flrg581-595b dell 9300
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
or click start type in event viewer press ENTER
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
Nov 12, 2012 | Dell Inspiron 9300 PC Notebook
I NEED T.V CODES FOR A ADMIRAL T.V AND NEED STEPS ON HOW TO SET UP CODE FOR A INNOVAGE REMOTE
Hello
Code for Admiral TV with Innovage remote control are:
001,173
CODE INPUT SETTING:
You will need the list of codes to manually select and input the correct codes to your
specific device.
1. Turn on the device that you want to set.
2. Look for the brand name under the specific device listing provided.
3. Aim the remote control at the device and press down and hold CODE SEARCH button for
at least 3 seconds until the red LED lights up solid red.
4. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
LED light will blink once and then remain solid red.
5. Using the number keys, enter the 1 st set of 3-digit codes from the list. You will notice
that each number that you press, the LED will blink once. After you have entered the
3rd digit, the red LED will turn off indicating that the code was recognized for the device.
(NOTE: If the code entered was not compatible, the red LED will flash several times.
You will then need to repeat Step 3. You have 30 seconds to enter a code.)
6. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying
to program powers off, then you have found the correct code. If the device does not
power off, then you will need to repeat the process again from Step 3, using another
3-digit code.
7. Make a note of the 3-digit code for future use.
CODE SEARCH SETTING:
This is an alternative method to programming your device without using the code list. The
remote control will scroll through the list of codes to identify the correct code for your
device.
2. Aim the remote control at the device and press and hold down the CODE SEARCH button
for at least 3 seconds until the red LED lights up solid red.
3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to
program shuts off. (Note LED will blink once each time you press ON/OFF button)
5. Once this occurs, press ENTER button to store the code and the LED light will turn off
Mar 27, 2011 | Innovage Jumbo Remote Control
Which scsi connection do I use to connect internal
Normally you SCSCI cable has 4 to 7 connectors the ribbon cable normally the last or next to last for a terminator is installed on the end of cable most DAT drive are self terminating so you may need to remove the terminator off the end cable.
The power from the power supply 4 pins to tape drive I assume you are talking about the DAT drive
When dealing with servers with SCSCI you have 7 devices per channel on the back side of the hard drive backplane you will be able to add the DAT drive cable or a standalone controller 68 pin ‘
Let me know if you need more help I can post some photos where two of my servers have DAT drive installed one for a Adaptec control and the other using controller of the back plane of hard drive array.
Dealing with SCSCI maters not what contoler you use
Dec 04, 2009 | Dell PowerEdge 2600 Server
I need the codes for myInnovage Jumbo remote
To find the codes to program your dvd into the Innovage Jumbo Remote, you can look your brand of DVD up in a list, or you can use the automatic Code Search function.
Here are the Code Search instructions:
  1. Turn on your DVD.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the DVD button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the DVD turns off. The LED will blink once each time you press ON/OFF.
  5. Once the DVD turns off, press the ENTER button to store the code. The LED light will turn off and your remote control is now programmed for that DVD player.
Hope that helps.
Oct 03, 2009 | Innovage Jumbo Remote Control
Innovage universal remote need code ssv2000 dvd
The codes to control a Funai SV2000 dvd player are 231 and 233.
To program your remote follow these steps:
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the DVD button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the DVD and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Aug 31, 2009 | Innovage Jumbo Remote Control
I need codes
Codes for direct TV are 200,201,202,203,204,205,206,207,208,209,210,211,212,213,214,215,216,217, CODE INPUT SETTING:
specific device.
(Note: You will notice that some brands will have more than one 3-digit code. During the
code input process, you may have to try more than one 3-digit code that will match your
device brand and model.)
3-digit code.
device.
5. Once this occurs, press ENTER button to store the code and the LED light will turn off I hope this information helps you with you remote controls problem. Thank you for using FixYa and have a nice day!
May 31, 2009 | RCA DIRECTV Satellite Remote Control
I need codes
specific device.
3-digit code.
device.
5. Once this occurs, press ENTER button to store the code and the LED light will turn of I hope this information helps you with you remote controls problem. Thank you for using FixYa and have a nice day!
May 26, 2009 | RCA DIRECTV Satellite Remote Control
Dell 9M905 Storage Controller Logo
Alun Cox
