Question about Fujitsu M2010 Notebook
I was using my pc and later on i found that the scroll function on my touch pad wasnt work how can i activate the scroll function on my touchpad
  • idoobi Mar 23, 2011
    the problem is the configuration of horizontal and vertical scroll function were not work any idea about this problem
  • 368 Answers
Glad to HELP YOU!
All you have to do is to go
START > CONTROL PANEL > MOUSE
and there to ENABLE (just check this option) this feature and you can also setup the SENSITIVITY by sliding right (more sensitive) or left (less sensitive) the cursor.
My best wishes!
Posted on Mar 23, 2011
The touch mouse will scroll and move but won't click.
you might have to reset it
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
b>
Feb 15, 2013 | HEWLETT-PACKARD Hewlett Packard HP 6730b...
Scroll bar
Feb 03, 2013 | Acer Aspire Computers & Internet
I have an compaq evo n600c with a problem its touch pad not working and its arrow stopped in the middle..what can i do to activate it?
Hi
you could try pressing the FN+F7 key once i believe this will enable or disable the touchpad
jusst have a look at the F7 key and see if it has a picture something like a small hand or finger pointing at it some laptops use the F9 key i believe
if this does not work
you could go to device manager
scroll down to find mouse/pointing devices
un install it then restart the laptop
hopefully when windows restarts it will find new hard ware
and install the touchpad correctly for you
many thaks
Mar 25, 2011 | Compaq Presario PCCOM2232US Notebook
My dell inspiron 6400 touchpad scroll not warking with window 7 ultimate
Try going to Control Panel - Hardware and sound - mouse. Once you have the menu for the mouse open, go to device settings. Click settings, and all of the advanced controls for the functions of your mouse pad can be found there.
Mar 12, 2011 | Dell Inspiron 6400 Notebook
I cannot scroll using my touchpad. i have checked the 'function' and 'scroll lock' keys. It is maaking no diffrenece. Can you help?
Please reinstall the Touch Pad driver once and make sure that that the Touch pad is enabled in the Startup.Also, kindly provide the model # of the Computer. Some Computers will have the special Application to maintain devices such as Wireless, Touchpad etc
Jun 21, 2010 | Computers & Internet
Touch pad scrolling problem
Use alps one as well as check weather your touch pad is lock or not
Mar 14, 2009 | HP Pavilion dv4000 Notebook
Touch pad
If you have the drivers for the touchpad installed then you should be able to run your finger up or down the right hand side of the touch pad and have it scroll the page you are one.
If it doesn't work then you may need to either reinstall the drivers or find the program that handles the touch pad settings (usually found in program files) and turn the scrolling feature back on.
Hope that helps :)
Mar 13, 2009 | HP Compaq Presario 2200 Notebook
Scoll bar action on touchpad works outside the scroll area
Seems like the synaptic touch pad has lost its configuration or got a little whacky.
Go to the control panel, and find the program for the touch pad.
There, try to redefine the areas for the scroll bar action.
Oct 18, 2008 | Computers & Internet
Touch pad's function of scrolling vertically and horizontally is not working. All the other functions are fine.
The touch pad drive needs to be installed. XP will provide basic function support for a touchpad,. Advanced features require the specific discrete driver from the manufacturer
Sep 03, 2008 | Computers & Internet
Fujitsu M2010 Notebook Logo
208 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
