Question about Frigidaire Electric Dryer
Only timed dry works, the auto settings dry but doesn't turn off
  • wdn1944 Mar 23, 2011
    The last time this happened the service technician replaced the control board and timer, then he had to come back and replaced the lint trap cover. This all took place a year ago. Shouldn't these items last longer than that?
  • wdn1944 Mar 24, 2011
    We will be checking out the thermostat. Thank you for your help.
  • 4,323 Answers
Hi
I believe that everything else is fine rather it is the thermostat that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then check the dryer belt and idler pulley...Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 23, 2011
  • Daniel Scott
    Daniel Scott Mar 24, 2011
    Yeah they should and thats why I believe it is the thermostat that should be replaced.
  • Frigidaire Master
  • 3,740 Answers
Hi and welcome to FxYa, I am Kelly.
Without your model number this is a generic response. This is caused most of the time by a cycle thermostat but can also be caused by a moisture sensor depending upon your model number.
The cycle thermostat will have one of the following numbers on the label"
L130 - 10F
L130 - 15F
L135 - 10F
L135 - 15F
L140 - 10F
L140 - 15F
Examples of thermostats can be seen here:
http://www.repairclinic.com/Frigidaire-Dryer-Thermostat-Parts
Again without a model number this the best I can do for you at the moment as the thermostats are different sizes and in different locations depending on the model number.
Thanks for choosing FixYa,
Kelly
Posted on Mar 24, 2011
3 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: maytag dryer model LDE512 will not turn off when
The timer may be faulty.
Servicing the Timer
Most dryer timers are digital or mechanical. The timer controls most of the operations of the dryer. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the dryer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the dryer. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
Posted on Aug 25, 2009
jumptrout51
  • 3361 Answers
SOURCE: Dryer will only run on auto sense
Your timer is bad.
Posted on May 24, 2010
My roper dryer works fine, it heats and the timer advances, it just wont shut off at the the end of a timed dry or auto dry. What do you think?
A timed drying cycle uses the timer alone to stop the drying cycle. Once it times out like an egg timer a set of contacts open up shutting off the dryer. Or a set of contacts closes to activate a relay which in turn shuts off the power.
Auto dry usually uses a moisture sensor which would do the same thing as the timer. Once it doesnt sense moisture in the load for a predetermined time it in turn triggers a relay which shuts the power off. Some auto dry cycles just use the timer alone and guess-timate the drying time by the selection.
If yours does not use a moisture sensor then most likely it is your timer/cycle switch. There may or may not be a relay involved.
Most dryers have a basic wiring diagram on the inside somewhere on one of the panels which will help.
Since yours is acting up on both cycles Im guessing you have a bad relay or connection to that relay somewhere IF it uses a moisture sensor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john_32f4b76dad4781c4
Dec 17, 2014 | Roper Dryers
Barrel isn't turning.
I believe you will find the belt is broken.
There is a motor which is supposed to turn a belt, which in turn drives the drum.
If you wish to repair ir yourself, a letter to "Fixya" could cause someone to walk you through the steps.
Be blessed.
Mar 04, 2013 | Frigidaire FGR641FS Gas Dryer, White, 5.7...
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
Dryer works, auto dry doesn't advance
Does it advance in timed dry? If not the timer moter is bad, if yes the cycling theromstat will have 4 wires on it and it needs to be changed
Oct 19, 2011 | Amana DLE330RAW Electric Dryer
The drum on my dryer will turn when I set the timer to any setting, but the timer does not work, nor does it heat up. Any suggestions?
See if the timer advances in the timed dry or the auto dry cycles. If the timer advances in timed dry but not in auto dry, then you could have a wire connection failure in the orange wire from the heating element to the timer.
If the timer will not advance in either type of cycle, then I recommend checking the timer part number that you are using.
Jan 07, 2011 | Estate EED4300TQ Electric Dryer
What is the best setting to dry jeans on a kenmore 9000 electric
Use Auto Dry for most things and vary the "dryness" level to more or less depending on the thickness of the material you are drying. Auto is most efficient and will adjust itself for finish time.
Auto dry and select "more dry" before hitting start, for jeans or towels.
Aug 28, 2009 | Kenmore Dryers
UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Nov 10, 2008 | Dryers
Electric dryer timer
the auto temp sensor is bad / Larry
Nov 01, 2008 | Kenmore 62602 Electric Dryer
My Amana Model NDG5800AWW dryer has ceased to dry clothes dependably. The Only setting that still sort of works is HIGH timed drying, and this heats up to what used to be the "delicate" setting....
if you are using the auto dry setting and the dryer is still running after 5 hours you either have a timer issue or a thermostat problem.
The timer is driven by a motor, if the timer motor is bad the timer wont time out.
in the auto dry cycle the thermostat has to cycle off and on which then sends power to the timer again advancing the timer.
set the timer in a timed dry cycle for say ten minutes, if the timer advances and turns off then you know the timer works. if it doesnt advance you have a timer motor issue,
if the problem is the auto cycle, you could replace the thermostat, about $20 american. however a clock timer would be cheaper.
Based on how old is your machine and do you want to stick a timer in it after already paying the service man is up to you.
A basic bath towel load should be dry in about 50 minutes, this varies on how good your seals are and how long a vent you are running, if the dryer vent was plugged you already have shortened the life of your heating element.
Sep 22, 2008 | Amana Dryers
Error code on dryer display
Check your breakers. Mine was doing the same thing, all of the 120v parts of the machine were working. (blower/drum motor/ lights) However the element wasn't coming on. Went to the breaker and found that one side of the 2 pole breaker was tripped. Turned both off and back on. Heater started working again.
When you set the dryer on settings such as normal or permanent press, it engages the various sensors that help the dryer to make the most efficient use of energy. Moisture sensor, heat sensor etc. (THAT IS WHAT TURNS ON YOUR AD SETTING) Normally it selects a time based on factory settings that it believes your load should be dried by. Say 50 minutes at Normal (high heat, normal) Every so often during the cycle, the machine will check the humidity sensor and the other sensors and try to see if the dryer is still on schedule. Sometimes it will determine that more time is needed, occasionally less time. While it calculates, it displays the Ad meaning that the machine is on auto dry. TO TURN OFF AUTO DRY, set it to a time setting instead of a DESCRIPTION setting.
Oct 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire  Electric Dryer Logo
217 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
