Question about Panasonic KX-T7431 Corded Phone
We have a KX-TD816 system and I have a KX-T7431 phone. We have no operator so whoever picks up transfers. No one can transfer to me anymore. One other thing all the phones the FWD/DND button blink slowly. Mine doesn't anymore and no matter what I try it won't blink including changing the phone out has been tried.
  • Panasonic Master
  • 2,460 Answers
So what happens when they press TRANSFER and dial your extension? What happens when you call someone with a display phone and your extension comes up on the display?
The FWD/DND button shows that you have a FWD or DND condition set on your phone. Try pressing it one or 2 times and see if the display says FWD to xxxx. Now, if it is cleared, from the intercom dial 7104 (busy) or 7105 (no answer) 165 # That sets the CF on your phone.
If the others have lost your DSS button on their busy lamp fields, and truly nobody can "transfer" calls to you, you can reprogram those with PROGRAM 99 (don't pick up the handset) press the button assigned to your extension and dialing 1 + your extension and STORE.
Carl
Posted on Mar 24, 2011
  • Carl Navarro
    Carl Navarro Mar 29, 2011
    Apologies. I guess I was supposed to come to your place and do the work for you.
    The only reward we get from the free forum in FixYa is your rating. I went to TD training in 1994. Even though the system was discontinued about 7 years ago, I still have several systems in my customer base. In an idle phone, every time you press the FWD/DND button in a TD series box, the forward status changes. 7100 on the intercom clears everything, the 710x codes set it up. Once FWD/DND is set, the button becomes a toggle. That is absolute.
    The display guides you through the functions by telling you on the display and visually displaying under the button what status it is in. When someone calls you, their display will also show a status. You may have turned on messaging (750x codes) but the FWD/DND button still controls the phone.
    So that we don't have to ask for clarification and go back and forth, it's easier to answer your question and point out the possibilities. "they can't transfer to me". Well, is your phone in DND or forwarded? Did they lose thier buttons? I don't know and I'm not coming there to find out. Help yourself. Answer the questions asked if what is suggested doesn't work instead of giving the solution a bad rating. This is not rocket science. It's a phone system with finite solutions.
    Carl
Will a panasonic KX-TG2257 cordless phone work with a KX-T6160 system?
I'm not familiar with a KX-T6160 system, so do you mean SIX-SIXTEEN-DEE(616d) or SIX-SIXTEEN-TEN (61610)? Either way, the cordless phone works. You need access codes, like 9 for an outside line, FLASH and dial an extension for transfer, 40 for ringing call pickup (on the 61610), and 58x (61610) to pick a line from hold. Your phone system manual has a single line telephone user guide in it.
Carl
Apr 30, 2011 | Panasonic KX-TG2257 Cordless Phone
Does the panasonic kx-t7431 phone work with caller id waiting feature?
No. CW CID is a function of the system the phone is plugged into. A TD system doesn't have it.
Carl
Apr 18, 2011 | Panasonic KX-T7431 Corded Phone
Hi, I have a Panasonic KX T7431 and have just attached a headset. I have changed the programming and i can pick up lines and hear people but they cannot hear me! i have tried another headset from the same...
Headsets on the 74xx series phones come in different flavors than the universal headsets of the 76xx and 77xx phones. The old Plantronics M bases and P headsets used to have a couple of adjustment dials on the bottom of the interface box that you had to play with in order to match the microphone to the phone system. If yours has those dials, try turning them until you can hear yourself in the earpiece.
Carl
Feb 15, 2011 | Panasonic KX-T7431 Corded Phone
How do I set the display to show the date/time?
I believe in a TD series system you just press the * key on an idle phone until what you want appears. If not, try the TRANSFER key.
Carl
Feb 01, 2011 | Panasonic KX-T7431 Corded Phone
Where is the CLEAR Key?
In an entry, it's the TRANSFER button. You clear a set by PROGRAM 99 # STORE.
Carl
Aug 20, 2010 | Panasonic KX-T7431 Corded Phone
How do I change the Name of the person at an extension on the Panasonic KX T7431
press the Program Button, then (**1234), and scroll counter-clockwise through the options with the volume circle. the option should say, "004 ext name set." to enter into that option to change, press the sp-phone button. continue pressing the sp-phone button until you find the extension number you would like to change. once you find it, press the transfer button and spell the designated name using the dial pad. For example, Mike (press 6 and use the volume circle to browse the letter you need from that assigned key- to get M) to continue spelling the name, continue using the dial pad and repeat to assign the designated letter. to store the name, press the "Auto Dial/Store" button and it will beep to confirm.
hope this helps, deanna
Jun 28, 2010 | Panasonic KX-T7431 Corded Phone
Are there any instructions to add an answering system for a Panasonic KX-T7431
Here is the instruction manual in PDF format, Just download it and install accordingly
http://www.sonic.net/~phonetek/7400.pdf
Sep 03, 2009 | Panasonic KX-T7431 Corded Phone
No one can leave messages as my mailbox is full -
Call the voice mail system from your phone (usually ext 165), put your password in, and start retrieving messages. Use a lot of 3's (delete) and it will get it down. IIRC you are only allowed about 100 or so but it is set by VM class of service.
Carl
Aug 12, 2009 | Panasonic KX-T7431 Corded Phone
Problem with extension and voicemail
1. Can be done but you have to have installer access to the system. You could also move the extensions at the phone system.
2. Is his call forwarding set (720x 165 #)? 720 sets forwarding for both intercom and outside calls.
Jan 13, 2009 | Panasonic KX-T7431 Corded Phone
How do ichange the time on Panasonic KX-T7431??
MUST BE DONE FROM EXT.101
1.leave handset in the cradle
2.Press "Program" button
3.Dial *#1234 (star pound 1 2 3 4)
4.Press Sp-phone button 3 times
5.enter the correct hour on the dial (2 digits)
6.press the button (in the lcd window to advance to minutes)
7.enter the correct minutes
8.press auto dial/store button
9.pick up hand set/ hang up hand set.
Oct 29, 2007 | Panasonic KX-T7456 Corded Phone
Panasonic KX-T7431 Corded Phone Logo
272 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
