Question about Nokia 1661 Cell Phone
Turn phone on and phone lights up (screen & keypad) but no LCD display (just a white screen). To turn off have to remove battery.
  • 32 Answers
It sounds like you might have gotten something in your phone or something broke inside the phone so you're going to have to replace it.
Posted on Mar 23, 2011
All i have is white screen
No, replacing the battery will have no effect. Even if the battery was dead and even removed from the unit, plugging the unit into a charger or wall adapter effectively bypasses the battery. You will see that the problem will remain. A white screen can be caused by several things:
1. A defective LCD display.
2. A boot-up issue.
3. A partially disconnected LCD display where the backlight is still connected, lighting up just the background.
Please see this site for more info on LCD & boot-up issues.
SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Mar 09, 2014 | Garmin Nuvi 40
I put my phone on the charger & the screen went white & displayed the hour glass & has been stuck like that ever since. I even bought a new battery & it's still like that. It won't do...
try doing a battery pull if that doesnt work you'll want to run the application loader. i found steps on www.tmobile.com/forumsIf the LCD screen is white, blank or empty, a soft reset may need to be performed, or there may be an error with the display drivers and the OS will need to be re-loaded onto the device. Please follow these steps:
  1. Remove the battery from the device.
  2. Wait 15 seconds, then replace the battery in the device.
  3. Turn the phone back on.
  4. If the screen is no longer white and functions correctly, the issue is resolved.
  5. If the screen is still white, continue troubleshooting.
  6. Confirm BlackBerry Desktop Manager has been downloaded to the computer.
If BlackBerry Destop Manger is installed, skip to step 2. If not,
  1. Install Desktop Manager
  2. Backup your information using the BlackBerry Desktop Manager (recommended).
  3. Download and install the blackberry handheld software to your computer.
Note: Running the Application Loader will take approximately 15-60 minutes to complete.
***ALTHOUGH THESE STEPS ARE FOR THE BLACKBERRY 9700 BOLD BY TMOBILE, THE PHONE MODEL IS THE EXACT SAME AS THE BLACKBERRY 9000 TOUR, OR BOLD THROUGH AT&T****
thank you!!!
p.s. please also provide feedback that reflects the solution provided i.e. 3 or 4 thumbs! thank you!!!!
Jan 10, 2011 | RIM BlackBerry Bold 9000 Smartphone
Display screen unreadable. Removing battery
You have an (unfixable) LCD screen problem - the Liquid Crystal Display is dying (or broken by impact).
The best you can do (without a spare LCD screen and soldering/electronic repair skills) is hope that
there's a workaround that lets you use the phone without the LCD screen working.
Exploring a workaround: call the cordless from your cell phone, and see if you can answer by just using the keypad - if so, then the cordless works and it can be used until the whole phone dies (rather than just the LCD screen).
Most consumers just end up buying a new cordless about every year since these units take too much accidental abuse to last long.
If you decide to scrap the unit, save the battery for recycling at your nearest Home Depot.
They accept
old rechargeable batteries of any type - NiCad types used in cordless phones are especially toxic
(the (heavy metal) cadmium poisons spermatogenesis). Even better, save the battery for your
other GE 25932 5.8 GHz cordless phone - if you have a pair, then its mate's battery is old too.
Jan 02, 2011 | GE 25932 Cordless Phone
My motorola razor v3 has a white screen?
Hi, White screen on motorola razor phones can be caused by either the LCD or the flex of the screen.
First, you will need to check for the flex by replacing the flex of the phone. the flex controls the display of the phone and the keys on the keypads of the phone.
The LCD also can cause a white screen display. After replacing the flex and if it's still has white display,you will need to replace the screen.
Have a nice day.
Sep 16, 2010 | Motorola Mobility RAZR V3
White display
The reason your phone is showing white display is because the flex of the phone is faulty.
  1. get the appropriate screwdriver (Torx 6 screwdriver),
  2. First remove the battery cover & battery. Remove the two screws you see.
  3. Run your fingernail around the join of the front cover and then remove the front cover.
  4. Now remove the four screws you can see.
  5. The top part of the phone (PCB and LCD screen) can now be removed from the middle chassis,
  6. A metal frame surrounds the LCD screen. It's held on with clips around the edge of the PCB. Unclip and remove.
  7. You can now remove the LCD screen. It's attached by a ribbon which connects like a plug and socket. Simply lift it upwards and it'll unplug.
  8. The ribbon which connects the screen to the panel you just removed is what needs replacement, it is attached to the screen so you have to replace the screen, if there is a way you can replace only the ribbon, that would do just fine,
  9. You can now replace the LCD.
  10. Reverse the whole procedure for reassembly.
Take care
Jun 24, 2010 | Nokia 6300 Cellular Phone
My phone is a samsung u700. its screen is blank and its not displaying anything. backlight on . what could the problem be.only light from the
first remove the battery just 5minites .................then display is out try change dis play .......
May 30, 2009 | Samsung Cell Phones
Phone keypad lights up but no screen on
when i press some keys display will off keypad lights up but the screen does not show
Oct 14, 2008 | Sony Ericsson K850i Mobile Phone
Blank or White screen on new Motorola Krzr k1 cell phone
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
Sep 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Nokia1600 repairing
hi there sir must go to your nearest service center to replace your LCD it must be damage already. the light of that phone was built-in to the LCD display. and that is why also your keypad doesn't have light cuz' it is series to the display light.
ok!
peace!
Mar 30, 2008 | Nokia 1600 Cellular Phone
Only displays white screen
Hi, Its a strip problem,when u change your mobile strip then screen willbe ok! By: M.Qasim Butt
Apr 13, 2007 | Motorola Mobility RAZR V3
Nokia 1661 Cell Phone Logo
109 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
