My laptop screen used to flicker sometime and yesterday the screen got white but just for few sec and today totally white... no display... wat to do..????
  • 158 Answers
Do you have an external monitor that you can try, if you can hook up an external monitor. maybe reinstalling the video card driver will help. if not try to go to BIOS if you experience the same thing in BIOS its not a software it could be your LCD or GPU (video chip) you may need a service technician with your laptop
Posted on Mar 23, 2011
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
My acer aspire 7535-5020 screen flickers sometimes the screen will go completly white
First you will need to determine if there is a problem with the laptop screen or the video card.
Plug in an external monitor to your laptop and use your laptop, if the screen on the external monitor flickers the same way your laptop screen flickered then there is a problem with the video card and you will need to repair your laptop. This is considered a major repair because the video card on the laptop is usually embedded into the motherboard and will be expensive to replace.
If the screen does not flicker then the connection from your laptop to your laptop LCD display might be loose. You will need to remove the cover of your laptop and make sure the connection is firm, as well as make sure there is no damage on the connector or wires.
Hope this helps.
Mar 16, 2011 | Acer Computers & Internet
Compaq Presario CQ40 Laptop screen flicker in every 2/3 sec Screen appears like a negative copy. During the fluctuations mouse and keyboard stop working..and zig-zag lines appears at the top of the...
the laptop has some loose connections with display or CFL may gone bad, need replacement.
it is purely technical fault and need an expert to handle, you may contact an expert for assistance..
Nov 08, 2010 | Compaq Presario Notebook
I have an ASUS model X83V and my screen has been flickering (not in brightness, but actually going fuzzy and "jumping"). The flicker can take upwards of 1 hour or more before it goes away, but usually...
my son has this same machine and after a year of almost daily use it developed this same flicker you describe, about every 4 secs, then it got much worse, almost like an old tv rolling. i took it all apart and inspected it all. didn't see anything really troubling.
yesterday it worked fine all day while i installed a bunch of updates for another problem. i left it on all night doing some other things. this morn when i got up it was still ok. then after a while it started in again, every 4 secs.
so i've been troubleshooting the damn thing all evening and have come to the conclusion its from over heating, probably cause of the crappy heat sink connection. i noticed if i take it outside in 40 degree weather and leave it a couple mins on the hood of my truck, it goes away. bring it back in and after 5 mins it comes back. take it back out and its fine again in a few mins. also, yesterday my house as much cooler. my fire was out and it was in the upper 60's in here, today as soon as it got to 76 in here, and it was above that all day, it started acting up
so i think my next step will be to try and make a better union between the chips and the heat sink itself. you should try a test with yours. start it up, make sure its flickering, put it in a cold space for a few mins. just be caustious of condensation.
Oct 23, 2010 | Computers & Internet
My screen is going totally white while I am using my laptop
You do not mention the brand or model which would be very helpful. It sounds like one of two things. 1. the inverter attached to the lcd is bad or 2. the lcd cable is lose on the screen. Send me the model and I will get you a better answer pmgibs1@verizon.net
Feb 20, 2010 | Computers & Internet
Screen is all white
the display screen is faulty have an expert change it for you
Nov 07, 2009 | Computers & Internet
Satellite A25-S279 screen flickers and goes blank after 5-10 secs
are you getting image on your LCD while booting up in the bios and windows loading screen ?
if yes, then perform a windows installation.
Aug 24, 2009 | Computers & Internet
White lines and fade desktop icons on screen
The LCD screen is at fault. If your lappy is in warranty try replacing it. It would cost araound $50-$80
Thank you!
Sabharish
Jun 01, 2009 | Toshiba Satellite M30X-S181ST Laptop
Flickering screen on startup
Sounds like hardware. Several possibilities come immediately to mind:
1) Backlight is going bad. (It's a fluorescent light).
2) Bad inverter
3) Loose or bad cable in laptop hinge
If the picture is OK using an external monitor, it's probably one of those three.
I've used these guys before for screen repair: Unknown document title.
http://www.notebookmechanix.com/
Feb 06, 2009 | Acer Aspire 3003LCi Notebook
LG viewty Touchscreen problems
I have the same problem. But i had solved it. I use a lighter to burn on my viewty's touch screen, and it is working properly again within 30 secs. And ofcourse, do not burn the touch screen without a screen protector. Hope this solution would help.
Aug 12, 2008 | LG KU990 Viewty
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
