Question about Gateway Keyboard/Mouse
I have a Gateway keyboard and mouse (Model 7010715R) which is connected to an IBM computer which I've just hooked up for the first time. After following all the instructions and changing batteries for the second time, the mouse does not move. ???
  • sbrechner Mar 23, 2011
    Joe, I did all you suggested and still the mouse does not move. The monitor is on, and when I touch the 'enter' key on the keyboard, it's clear it's connected to monitor. I touched the three 'buttons' as you suggested, and as a result, a bright yellow light flashes on the underside of the mouse as if it's functioning. But for some reason, the mouse arrow does not budge. It seems everything is working except the most important thing. Am I doing something wrong?
    This is the first time I'm hooking up the computer. I bought the computer and wireless keyboard and mouse refurbished but never connected anything till today. Everything as I said, at least on the surface, is working except the mouse and the arrow.
    President:
  • 2,080 Answers
Assuming the batteries in the mouse and keyboard are fully charged, next make sure all your cables are inserted correctly.
Check that the data cables leading from the base unit to the computer are securely inserted into the proper connectors at the rear of the case.
Next make sure the power cord for the base unit is plugged into a live power outlet and that the other end is securely plugged into the back of the base unit. Often times this plug will come out halfway and so will look plugged in but will cause intermittent problems.
Next make sure your mouse is not too far away from the base unit when you try to use it. Normally 8 or 10 feet is the maximum distance these units will function properly at. Also make sure there are no obstructions between the mouse and the base unit. You can also clean any dust or debris from the small LED bulb on the underside of the mouse with a dry QTip to ensure that is not the problem.
Now depress the CONNECT button on the base unit, then while the light is flashing depress the small CONNECT button on the bottom of the mouse.
Next, press the CONNECT button on the base unit again, then while the light is flashing depress the CONNECT button on the underside of the keyboard.
Now try using the mouse and keyboard.
If the units still do not function after that, then leave them plugged in and RESTART your computer.
Repeat the CONNECT procedure for the mouse and keyboard after your computer restarts if necessary.
Please comment back here to this page if you have any questions, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
Posted on Mar 23, 2011
  • Joe2
    Joe2 Mar 23, 2011
    If you are using Windows VISTA on your computer, then you may need to install the driver software for it to work properly.
    If you are not using VISTA, then just keep trying the connect process until it works. You may have to do it 3 or 4 times before it connects properly. Make sure you have the mouse right right beside the receiver when you do the connect procedure. Also make sure you use a mouse pad under the mouse, some surfaces do not work well with certain mice. Also make sure there are no other wireless mice in the same room when you do this. Also make sure you don't have a regular mouse plugged into the computer at the same time. Try switching the receiver to a different USB port on your computer just in case the one you are currently using is faulty.
    If you still can't get that wireless mouse to work, then just plug in a regular corded mouse so you can at least work on your computer for the next steps.
    Here is the main Gateway Support page for your product:
    http://support.gateway.com/s/KBDMouse/70...
    And here is the direct link to the USER'S MANUAL:
    http://support.gateway.com/s/Manuals/Des...
    Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
    You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
    And finally, here is the VISTA DRIVER download page for the wireless keyboard and mouse:
    http://support.gateway.com/support/drive...
    If you do need to install the VISTA driver, just go to the above link and click on the D20037-001-001.EXE DOWNLOAD NOW button that you see on that page and then follow the on screen instructions.
    If you need additional help you can always click on the blue HOW TO DOWNLOAD or HOW TO INSTALL links right beside it on the same page, and little information windows will open up automatically with step by step instructions.
    Good luck, comment back with how you make out.
    Joe.
My gateway wireless mouse won't sync
- Have you tried the steps mentioned in the link to connect a wireless keyboard and mouse to the Gateway computer? http://support.gateway.com/s/desktop/2009/gateway/zx/zx4800/ZX4800faq3.shtml
http://www.support.gateway.com/s/Manuals/Profile/WirelessKb_MouseGuide.pdf
Also follow the generic troubleshooting steps mentioned in the link to connect a wireless keyboard and mouse to a computer.
http://support.microsoft.com/kb/838398
Note: The steps provided in the link mainly works for Microsoft hardware but the steps can be applied to any wireless keyboard and mouse. Do not install any software given in the link as it will not help you if you do not have a Microsoft Hardware.
It would be helpful if you could provide us the exact computer model number and also the make and model number of the keyboard and mouse.
Feb 14, 2015 | Gateway GM5664 Desktop PC
Lenovo R60 freezes and no response from mouse or keyboard
1) try to RESTORE to some point where the computer was working.
2) Update the BIOS +CHIPSET and RUN it.
2a) see if working. If NOT working go the step #3
3) update the USB driver from the supplier company.
4) updae the driver for keyboard +mouse , uninstall and reinstall.
God bless you
Oct 18, 2012 | IBM Lenovo ThinkPad R60 Notebook
I have the crayola keyboard hooked up to my computer but it wont work the power light is on but when i try to type nothing happens
Two things come to mind right off. One did you hook them up right, They both look like PS/2 connections and to look at them they are the same, but to the computer they are different. If they are hooked up right the problem could be in your bios setting where they keyboard and mouse are set to usb only so the PS/2 connection could be in fact dead.
Hope this helps
Apr 13, 2011 | Crayola Keyboard w Mouse and Mouse Pad...
I bought a gateway zx series computer 3 weeks ago. the wireless keyboard and mouse that came with it has stopped working for no apparent reason. the computer says that it doesn't recognize the device. i...
hi Karnarc.
How do I troubleshoot my Gateway wireless keyboard and mouse? How do I troubleshoot my wireless keyboard and mouse?
If you are experiencing issues with your wireless keyboard and mouse not working properly, perform the following steps to troubleshoot the wireless keyboard and mouse.
  1. Make sure the USB connector from the receiver is properly plugged into a USB port on the computer. Some systems ship with the receiver already preinstalled in the unit itself. Please check your mouse to see if there is a receiver inside of the battery compartment door.
  2. Make sure wireless keyboard is not on a metallic surface.
  3. Ensure that the receiver is 8-inches from other electrical devices.
  4. Try plugging the receiver into a different USB port to ensure that the USB port is working properly.
  5. Check the batteries in the keyboard and mouse to make sure they are installed correctly.
  6. Test the batteries to ensure that they still have a charge.
  7. Verify the On/Off switch on the keyboard and mouse are switched to On.
  8. Some receivers, keyboards, and mice may have a connect button. If so, follow the steps below:
    1. Plug the USB receiver into a USB port on your computer.
    2. Press the connect button on top of the receiver and the button will blink.
    3. Press the connect button on the bottom of the keyboard to activate the wireless connection.
    4. Press the connect button on top of the receiver and the button will blink.
    5. Press the connect button on the bottom of the mouse to activate the wireless connection.
Dec 03, 2017 | Gateway Computers & Internet
Hello, i currently use a IBM desktop with IBM keyboard and mouse but i just bought a microsoft wireless keyboard and mouse which i just installed into my desktop using the installation CD. They are both...
Hi Tony,
It appears that you have an IBM desktop whose BIOS isn't capable of booting off of a USB keyboard and mouse device. Older computers used to require that a PS2 mouse and keyboard be attached before booting, to prevent you from booting a machine without any way of controlling it. You have 3 options:
1. leave the corded mouse and keyboard attached and never use them
2. update the BIOS for your desktop to the newest one in hopes that the updated BIOS will allow for USB mouse and keyboard operation
3. go to a computer store and get a PS2 to USB converter/adapter. They're small and relatively inexpensive. It plugs into the PS2 port, and makes your computer think that there's a PS2 device connected, when it's actually a USB device.
Mar 03, 2010 | Microsoft Wireless Laser Mouse 6000 v2.0
Every time I'm using the mouse and click a button on the keyboard, the mouse will not move for about 5 seconds.How can I change it so that I can use the two at the same time?
Your USB connection is incorrect. Instead of plugging the wireless receiver in the front of your computer, plug it into the back USB ports. These ports are way faster and more responsive.
Jan 23, 2010 | Gateway 2520915 Keyboard
I have a Gateway 7010715R (KR-0532) HID keyboard. I have lost my on-screen display for lock key indicators because the keyboard does not have indicator lights like a wired keyboard. What controls this...
This OSD is controlled by your keyboard driver. If you were previously getting On Screen Display and you are not getting it now, it is possible that you might have disabled the startup items from mscofig. In that case enabling the startup items will resolve this issue. Or else re-install the driver and software of keyboard to resolve this issue.
Sep 05, 2009 | Computers & Internet
The usb do not work at all. ibm t42 23731WU many thanks !
If none of the usb ports are recognizing anything you hook up to them then that means the motherboard is bad. Easiest way to know, hook up a usb mouse or usb keyboard, those it should detect and install.
If it can't do that then you know for sure the motherboard is bad. If it does detect the keyboard and mouse then you know its the other devices that your hooking up that are faulty.
Aug 21, 2009 | IBM ThinkPad T42 Notebook
Gateway cordless mouse intermittent connection model MR-0610T ,,, came as a set with keyboard. keyboard connects fine, no problems, but mouse has to continually be reset after a few commands/minutes.
I was having the same problem then I ran across something on the Gateway sight saying to hold the connect button on the transmitter for 5 seconds, then the connect button on the mouse for 5 seconds. I just did this about 5 minutes ago but it seems to have fixed the problem.
Feb 23, 2009 | Computers & Internet
Gateway Keyboard/Mouse Logo
115 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
