Have all hooked up but it will not run a back up USB
  • 4 Answers
Noserialno work
Posted on Mar 23, 2011
Can u hook up the rabbit TV to your TV using USB
I don't think you can plug it into the back of your TV. It runs off your computer and I do know there is a way to connect your computer to your TV wirelessly, and watch that way. The second option is getting an HDMI cord (theyre cheap and can be found at Walmart) and hooking the two up. Should work this way. You can visit RabbitTVSupport.com for more info on setup and installation.
Oct 12, 2014 | Televison & Video
Infocus lp770, trying to hook up to apple computer using the usb port? will this connection work to run the 770?
Hi!
You need to hook it up using VGA or HDMI for it to transmit information from your Apple computer to projector. You can check the Ports available at the back of your projector and you can Purchase cable needed from either Apple or Infocus or any computer store.
Hope this helps.
Sep 05, 2011 | InFocus LP 770 Multimedia Projector
I USE TO HAVE A LAPTOP AND WAS ABLE TO DOWNLOAD MY PICTURES WITHOUT PROBLEMS. NOW I AM BACK USING A TABLE TOP COMPUTER, I HAVE THIS OTHER CABLE WITH A YELLOW & WHITE MALE IN-PUT AND THE OTHER END FITS...
Yellow and white pins cable is called AV Cable, it is to hook camera with TV. It wont hook camera with computer.
You need USB cable to connect camera with computer. Required USB cable is available in Sony Accessories Store under following part number..
319698101 .... CODE (USB 5P) CONNECTION
Thanks.
Jun 22, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
I recently installed CAT6 cable to run between my computer and main stereo. The run is 50' so I also purchased a USB extender. My issue is that once I hook the network up to my computer, it can no...
Yes- don't use USB as an extender- Network spec for Cat 6 without a repeater ranges from about 165 feet to 75... You should be able to run the cable straight through.
Jun 15, 2011 | IOGear USB Booster Cable G2LUB16 USB...
I wanted to make 10 copies of a document using the glass. The printer froze at 3 of 10. I pressed cancel, the display showed canceled for almost an hour. I then pressed the power button now the display...
It is my pleasure to guide you.
Is it hooked up via USB or parallel?
If parallel, then the computer must be turned off to hook it up. If USB, it does not matter if the pc is running to hook up.
One thing that you can count on, it rarey hurts to shut down/unplug a printer. Sometimes that is the only way to reset the software and trouble shooting software in the printer. I use to take care of pcs/printers and sometimes did just that.
Leave the printer unplugged (if USB) and reboot the pc. Then plug it back in again, letting the OS cycle the addition of the printer.
If parallel, shut down the pc. Unplug the printer and reboot and shut down completely. Plug the printer in again and reboot.
Good luck and please post back that you are successful, giving thumbs up, or so I can be more help.
Jun 10, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
"usb device not recognized" Trying to
what device
what OS, opr. system?
Mar 24, 2017 | HP Mini 1035NR Notebook
My pc doesn't recognize magellan . need usb driver
hi joshnvince
you need to have it hooked up to XP service pack 2 or above or the computer
wont see it. if your running XP or better, try a different USB port, preferably one on the
back of the computer.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Dec 25, 2010 | Magellan RoadMate 2200T GPS Receiver
My Compaq nx5000 notebook doesn't recognize an add on keyboard
Try other usb devices to make sure that your usb ports are working. If you try other usb devices and they work then you know the usb ports are working properly.
Now hook up the keyboard again to the usb port, see if the laptop recognizes it at all. if its recognizing it but not installing the drivers for it, then go ahead and put the disc in and run the setup off of the disk to install the drivers, then at that point it should work.
If that doesn't work, go to there website and download the latest software and install that.
If you hook up the usb device and the laptop isn't seeing it at all then that means the usb device is bad and your best bet at that point is to bring it back to the store and get another one.
Also make sure if the motherboard and mouse require batteries that you have good ones in there before trying to hook up the usb device to the laptop.
If it still doesn't work then you know its bad and you need to get another keyboard and mouse and usb device or go with another brand and model of keyboard and mouse.
Jan 26, 2010 | Logitech Labtec Media 800 Mouse
Hi, im using windows xp pro sp2 and hooking up a piano to usb. the piano comes with a special driver, but as soon as i hook it usb it installs a generic driver automatic. Then it doesnt let me "pick from a...
as for any usb device, the general rule is run/install first the driver program via the cd installation disk before plugging in the USB device. Try removing the Piano usb, restart the pc, install the cd driver, and plug in the piano.
Jul 14, 2009 | Microsoft Windows XP Professional With...
Cannot Hook up Dell 926 Printer
Heres a picture of a usb slot:
Plug it into there
Dec 10, 2008 | Dell 926 All-In-One InkJet Printer
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
