Question about Pioneer VSX-D704S Receiver
I have a Pioneer VSX-D704S receiver and I can not remember how to get it hooked up right to get the GUI to display on the screen. I recently moved and obviously did not pay close enough attention as to how it was hooked up before because it used to work just fine??? Any ideas? Thanks
  • dwc252 Mar 24, 2011
    Thanks, I will mark helpful but the manual does not specify how to resolve the problem as I have the manual. Manuals can be so vague.
    I sent an e-mail to Pioneer US and they DID reply with the fix. I had not swithed the TV / Video mode to the video setting. Once I did that the GUI worked perfectly.
    Any thoughts about a manual for Pioneer PD-F1007 by chance?
    Thanks again!!
  • 336 Answers
Posted on Mar 23, 2011
Testimonial: "Thanks, the manual link provided does have the manual for my stereo but it does not specify how to resolve the problem as I have the manual. Manuals can be so vague. I sent an e-mail to Pioneer US and they DID reply with the fix. I had not swithed the TV / Video mode to the video setting. Once I changed the TV / Video mode to the video setting the GUI works perfectly. "
How do I hook up pioneer stereo receiver VSX-D704S to laptop
Use a headphone jack to rca adapter. Plug headphone into laptop headphone jack and connect rca ends to whichever input you want to use on the pioneer.
Oct 08, 2016 | Pioneer Audio Players & Recorders
How to hook up laptop to pioneer VSX-D704S
just go audio out from laptop,prob use headphone jack with a splitter (so you can do both left and right audio plugs,then into amp say cd in on back of amp,then set amp to cd....
I can't get my tuner to work, but everything else works fine. All I get is static went I turn to the radio stations on both FM/AM
If you are in a fringe area you might need an external antenna to work with your tuner. Happens.
Oct 15, 2015 | Pioneer VSX-D704S Receiver
Radio tuning
PIONEER VSX-D903S - A/V Receiver
PIONEER CU-VSX079 - Remote
Here's the basics: Make sure your receiver is in the Tuner mode, by selecting Tuner on either the remote (grey button), on the receiver, or from the GUI menu. (The display will also show TUNER.) There are a couple of different ways to tune a station. One method is with the remote. Use the Band button on the remote (or via the GUI display), or the FM/AM button on the receiver, to select the frequency type. Use the Freq/Ch buttons on the remote to tune, the number buttons for presets (30 presets total. Examples: Preset 5, simply press 5; Preset 15, enter 5-5; Preset 25, enter 5-5-5). You can also use the on-screen GUI menu and the remote to tune stations, using the lower grey buttons. If you want to tune directly, via the receiver, press Select, to switch between frequency tuning and presets (displays ST CALL) mode. Use the Multi-Jog dial to make your selection in either mode. The easiest way to program a station into a preset is to use the onscreen GUI menu. [NOTE: The GUI mode (TV Monitor Video Out, composite video) is active when an amber (orange) ring glows around the Multi-Jog dial (the GUI button on the receiver will also glow simultaneously). Use the remote lower grey buttons, or use the Multi-Jog dial and Select, to move the cursor and select commands on the TV. This A/V Receiver handles composite video/S-video, and Stereo/Dolby 3-Channel/Dolby Pro-Logic audio only. (Pre-ATSC/HD video, Pre-Dolby Digital/DTS multi-channel surround audio)]
Feb 07, 2014 | Pioneer VSX-D903S Receiver
Pioneer VSX D903S ...HOW do i adjust the rear speaker volume....it is currently much too low
You make surround channel adjustments using the on-screen GUI interface. This can be done either by using the remote (recommended), or by using the appropriate controls on the receiver. [The GUI mode is active when the GUI button and the ring surrounding the Multi-Jog dial is glowing amber.]
Nov 07, 2011 | Pioneer VSX-D903S Receiver
How do I change the radio station on my pioneer vsx-d903s
Welcome to FixYa.
You need to use the remote control to access the radio station frequencies.
Follow the instructions below:
Thank you for using Fixya. Have a great day!
Jas247
Jul 23, 2011 | Audio Players & Recorders
I have a pioneer vsx-d704s reciever and when it is at a very low to 0 volume i get a low level scratching only on the left side. im not sure if it goes away when i turn it up or not but i dont think so
The volume knob is dirty. Behind the face of receiver the "pot", (as they are called) needs sprayed with contact cleaner. I use CRC QD contact cleaner. If the volume is a slider your can use the straw type devise for pin point spraying in the slider slot with receiver off and unplugged. After spraying work the slider back and forth to distribute the cleaner inside. If you have to remove the cover for a rotary "pot"spray while working the dial. Hope that helps..
Jul 16, 2011 | Pioneer VSX-D704S Receiver
My Pioneer VSX-D704S WILL NOT POWER ON. WHEN I PUSH THE POWER BUTTON NOTHING HAPPENS. THEN THE STANDBY LIGHT COMES ON.
It is in protection and will need to be serviced. Find a local AUTHORIZED pioneer service center.
Jun 10, 2009 | Pioneer VSX-D704S Receiver
VSX-D704S
Have the speakers disconnected and turn on unit. If it still shuts down due to thermal protection the amplifier IC pack is damaged. Amplifier IC is tied to one side of the power supply by design. The left channel is probably shorted at the MOSFET on the pack. Nothing you can do but have it serviced. This is a common PIONEER failure.
Apr 08, 2007 | Pioneer VSX-D704S Receiver
Vsx-d704s
there is a problem with the apeakers, the speaker feed wires or worse case is a blown audio output stage circuit in the amp. Good Luck
414 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
