Question about Emission System for Nissan 240SX Fastback
Can't pass the emission test what could be the problem
  • 176 Answers
Could be many things. Bad timing, vacuum leak, bad catalytic converter, oxygen sensors, fuel injectors, etc etc.
If you are interested in further diagnosing the issue, I would be happy to further assist you. Goodluck
Posted on Mar 27, 2011
Pass smog test
change your oil and oil filter. Add a bottle of octane boost to the fuel tank then top off with fuel. Drive vehicle for about twenty minutes then have emissions tested. Unless you have a bad catalytic converter, you should pass emissions.
Apr 15, 2014 | 2001 Mitsubishi Eclipse Spyder
I have a check engine light with a code P0013: cam shaft circut. Will this pass an emissions test?
Most probably the system will not pass the emission test as it is related to air and fuel supply system. The problem relates high and low voltage supply to cam circuit. If high voltage is supplied the light will come on and you may not be able to pass the emission test.
Jul 11, 2013 | Cars & Trucks
Engine Check light
Take it to autozone or another place like it and have them read the codes and tell us what they are.
Jun 19, 2013 | 2011 Jeep Wrangler Sport
I live in Ohio and cant seem to pass an aims emission test and the truck is a 1992 Jeep Wrangler the NO emissions keeps failing what can i do to pass the test?
have the obd codes checked, once they get checked, post the results here, and we will be able to better help you in a solution, I can assist you in defining what the codes mean, and how to repair your vehicle so that your emissions will drop below the required amounts so that you will pass the test
Aug 10, 2011 | Jeep Wrangler Cars & Trucks
Does the 89 lincoln requirer emissions testing?
Hi and welcome to FixYa!
Every vehicle is required for emissions testing. I strongly suggest that you have the car conditioned before proceeding. By doing so you'll surely pass it.
Hope this helps and thank you for using FixYa! Have a good one!
Feb 19, 2011 | 1989 Lincoln Town Car
2000 nissan maxima, pass Connecticut Emissions test
catalytic converter is the way to fix your problem because they do an emissions test and the code want go away even if you get the light off before you take it in they will no the computer has just been reset so which means all the sensors want have enough info to give the computer because of being reset sorry to break it to you.
Jul 30, 2009 | 2000 Nissan Maxima
Emissions failure due to an evap code
Your emission sensors seem to be just a 'spec' out of normal (I would not call them defective!), but it could also be tainted fuel. Just to pass test I would buy the gas treatment at your local auto parts specifically for emission testing. Ask them at the counter. It will get you passed.
Jun 30, 2009 | 2003 Dodge Ram Maxi
Will not pass emissions test
the light is an emissions code in there sometimes its a oxygen sensor or the egr valve gets clogged in hondas...you need to retrieve the code to narrow the problem down
May 11, 2009 | 1998 Honda Civic
Wont complete scan to pass emission test
When you rest your codes there is a series of tests your ECU has to go through before you can pass emissions. this is done some people can reset the code and go before its sets the code again. on the 96 you can have 2 tests not complete for it to pass. basicly you have to drive the car a couple days for the tests to pass.
check the readiness tests wait until only 2 have not passed. then you should be good.so drive and check.
Michael
ASE certified
PLZ rate.
Feb 09, 2009 | 1996 Chevrolet Blazer
Emission System for Nissan 240SX Fastback Logo
89 people viewed this question
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
woodzowl307
ray gallant
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
