Question about Cell Phones
My mobile phone won't connect with my charger, and I have tried it with about three other chargers, so it seems to be my phone that's broken. What is wrong with it? I found out it was broken as it just will no longer charge and its battery died. Please help. Thankyou.
  • 32 Answers
Its probably not the phone its self its the battery is worn down so replace the battery and it should work fine.
Posted on Mar 23, 2011
Meos dvd92b not charging
Hello:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 29, 2012 | Cell Phones
I have problem in china phones max475 odel "
Sir it is happening due to any of these three reasons: 1. voltage Fluctuation in your home.2. Charger pin is damaged3. Mobile pin is detoriated by bad insert of charger pins.
please check all these condition if continious please charge with its real charger..
Oct 01, 2011 | Cell Phones
My phone wont charge
there could be many reasons for such a problem, charger related , and device related, so you have to check the following:
-first, you should check the power socket, it might be the reason why the charger is not charging your mobile phone.. try to insert it to many several power supply sockets..
-second if you tested it and it did not work; the charger itself might be broken, try to attach it to another mobile phone and see if it will charge or not, and try another charger to be attached to your mobile phone so that you will figure out if the charger is broken or not..
-third, assuming the charger is perfectly functioning, it is more likely that the battery is dead, every rechargeable battery comes to an end someday not able to be recharged having its chemicals consumed or changed, so that the easier way is to be replaced.. BUT, if you put that battery in a similar compatible mobile phone then tried to recharge it and found out that it is been recharged successfully, that means one thing that the charging port (where you connect your device with charger) is malfunctioning or broken so that it does not joint the charger with the battery..
Mar 26, 2011 | Cell Phones
3315 not charging
First Option:
Secend Option:
Thanks
Sep 01, 2010 | Nokia 3315 Cellular Phone
When I connect my charger into the phone, an hour or so later it'll stop charging and say something like "accessory not for charging" or something like that. I have to unplug the charger and put it back...
Change your charger...And use the company charger....or genuine charger ...not the local one...!! Changing your charger may help you...Give a try
Or go to any mobile shop and tell your problem...Your problem will be solved in 10 min.:) Thanks in advance
Aug 14, 2010 | Cell Phones
China mobile,warning,bad contact charger when connected to the charger.
i have foreme f8 phone when i m charging it then it will say after some time bad content charger solve it
May 27, 2010 | Cell Phones
K550i charging problem
in sony k550i mobile phone battery will not charge through monile charger i will check the charger but it is ok. when charger is connect to mobile then show on charging box make a charge but achually charging is dcressing.
Oct 17, 2009 | Sony Ericsson K550i Cellular Phone
My charger is broken.
yes if your phone do not detect any charger than you need to buy a new charger. because whenever you connect a charger, than the mobile displays "battery charging0"
Sep 08, 2009 | Verizon Communications enV2 Cellular Phone
Sony walkman phone faulty charger connection so can't charge
you need to take the phone to a mobile service center and have them service the charger port
Nov 30, 2008 | Sony Ericsson W200i Cellular Phone
T-mobile phone Not Charging
to where are you connecting the charger?
how old is the charger? maybe the cable its broken in the inside... this usually happens at the ends of the cables or if there is a little bump somewhere..
try connecting them and play with them by moving them a little at the ends.... so there will be better a contact..
Dec 11, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Cell Phones Logo
73 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
