Question about Savin Office Equipment & Supplies
Code SC401-00 on Ricoh 2400w - Savin Office Equipment & Supplies
  • 263 Answers
That is a code of bad reading in the ID sensor. This sensor reads the density of toner on the Drum.
Probably its dirty (on the worst case is broken).
I advise you to clean it to see if it works.
If doesn't work i advise to call your technical support (if you do not have technical skils)
Posted on Mar 24, 2011
Ricoh aficio MP2000 ERROR code SC302.
https://printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20200&code=SC302
Ricoh Aficio 200 Error Codes
Ricoh Aficio 200 Error Codes Code:
Code
SC302
Description
Charge roller current leak
A charge roller current leak signal is detected.
Causes
• Charge roller damaged • Charge high voltage supply board defective • Poor connection of the PCU
Apr 18, 2018 | Ricoh Computers & Internet
Hey I have konica minolta magicolour 2400w printer. When i turn it on, it start warming up but after 3 seconds it turns on the ERROR light & the printer doesn't work. Every time i turn it on same issue...
Hi
Usually these machines give you an error code on the control screen. You do not mention one but the webpage here:
Error Codes Konica Minolta Magicolor 2400W
gives most of the error codes for your model.
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 31, 2014 | Office Equipment & Supplies
Code error list
ERROR CODE ON RICOH 2400W SC 406
Jan 02, 2014 | Kitchen Ranges
Hi, I'd like to buy an Used Ricoh wide format copier models: 240w;2400w;480w;mpw5100;fw870...Please give me an offer if you could help. Thanks, Regards Vien Nguyen
This isn't the best place to shop copiers since we mostly offer help when they are sick.
The best place to start looking is here:
Asay Publishing
Their classified listings show several Ricoh units and one 240W (near the bottom):
Ricoh copier offers
Good luck-
Jul 05, 2011 | Ricoh Office Equipment & Supplies
The ERROR light of my Minolta magicolor 2400W Laser Printer stays on. I have inserted a new drum and all the cartridges are full. What do I do?
Try to open the blue cover and close it. Then press a few times the "rotate toner" button. After that powerswitch off and on, should run.
If it´s don´t worked, make sure you have every transport secure away from the cartridges.
The contact`s should be clean in Printer and on cartridges.
If still the same prob, start from first tip.
It´s worked by my 2400W feed new toner.
Nov 25, 2009 | Minolta magicolor 2400W Laser Printer
Magicolor 2400w prints page and then says jammed
It`s possible you`re using too heavy paper, same problem´s with thin sheet´s?
Oct 03, 2009 | Minolta magicolor 2400W Laser Printer
Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
QMS Minolta 2400W doesn't print
try lifting the drum assembly, at the back of the assembly there is a fuse. replace it. hope this helps
May 25, 2009 | Minolta magicolor 2400W Laser Printer
I have been given a 2400w. I did not get an installation dicc. can you help with the installation?
If you mean a Konica Minolta 2400w here youcan find the drivers:
http://printer.konicaminolta.com/support/current_printers/mc2400w_sup.htm#Drivers
Apr 22, 2008 | Office Equipment & Supplies
1,005 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
