Question about Proxim ORiNOCO AP-4000M (8670MUS2) 802.11a/b/g Wireless Access Point
I have a AP-4000 MR-LR unit. It currently has old setting on it that I have no idea what the ip address or passwords for it are. I need to reset to factory setting. However there is no reset button on my Power injector nor my unit itself. Please help!
5 Suggested Answers
SOURCE: Default IP address for symbol spectrum24 ap-4131
Try 10.1.1.1
Posted on Apr 23, 2009
  • 17 Answers
SOURCE: usr5450 robotics default ip address
See review at http://www.wi-fiplanet.com/reviews/article.php/3088971
which says that the unit defaults to an "automatic" address (i.e., it's a DHCP client).If that's true, then you would have to set up the AP on a network that already has a DHCP server, such as on the LAN side of a wireless router. Apparently there is also a configuration utility that doesn't depend on the IP address, and can be downloaded from USR. See the product page at http://www.usr.com/support/product-template.asp?prod=5450
  • 1566 Answers
SOURCE: noy finding ip address senao wireless AP
Hi. Here is the manual.
http://www.senao.com/images/www.senao.com_English/NL-2611CB3-PlusDelx-Manual-V1-0.pdf?CATNO0=D&CATNO1=D3&CNT=1
Set your PC to use the static IP 192.168.1.10, netmask 255.255.255.0.
To login to the web manager, go to http://192.168.1.1. Leave the username and password blank. You can now configure the device and assign IP address etc.
Posted on Jul 21, 2009
puertobori
  • 7733 Answers
SOURCE: Hello have 2 Proxim ap
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
There a great article at General Router Setup.
Posted on Feb 01, 2011
Pin
1) reset your browser (internet explorer).
2) connect your access point (AP) to your pc directly using LAN port and CAT5 cable
3) type in default IP address of AP->192.168.0.50 (Or Current IP address of Ap) in browsers address bar.
4) username = Admin and blank password (i.e. password is no text)
5) Click on Advance Button then click on Wi-Fi Protected Setup button on left menu pan.
6) See the image below record your current pin, if you wish to change it just press generate new pin button.
7) Don't forget to say thanks :)
Apr 13, 2013 | D-Link DAP1360 IEEE 80211n (draft)...
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
Im using a tenda wireless broadband..my problem is i cant get the right pre-shared key pls help
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | TP-LINK Tenda W311R WirelessN Router AP...
Hello have 2 Proxim ap orinoco 4000MR-LR Outdoor and i forgot all password and disable hardware reset how can I reset device to factory default
Jan 31, 2011 | Proxim ORiNOCO AP-4000 (8670MUS)...
The router was reset. So, our AP does not work with it anymore. I reset the AP to restore it to its factory default settings and tried to follow the steps I made before in configuring the AP. but i can't...
Before you configure this device, note that when the AP is configured through an Ethernet connection, (via RJ45 Network Cable) make sure the manager PC must be set on same the IP network. For example, when the default network address of the default IP address of the AP is 192.168.1.1, then the manager PC should be set at 192.168.1.x (where x is a number between 2 and 254), and the default subnet mask is 255.255.255.0.
Open Internet Explorer 5.0 or above Web browser.
Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the address location. Please refer here to the Latest User Manual for Encore ENRWI-G Page 9 onwards describes the login details.
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Encore WIRELESS LAN EXTENDER
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Computers & Internet
@annj2...... How to do full factory setting on wap-1001,level-1 products 11g outdoor wireless AP/bridge hence to remove administrator password?
  1. Start the web browser (make sure you disable the proxy) and type 192.168.1.20 (The default IP of outdoor AP ip Address) in the Address field. Press Enter.
In Management section, you can Backup/Restore Setting, Firmware Upgrade and Reboot the system in following pages.
  1. Backup the current settings to a file - Click on the "Backup" button, system will prompt you where to save the backup file. You can choose the directory to save your configuration file.
  2. Restore settings from a backup file - Here you can restore the configuration file from where you previous saved.
  3. Restore factory default setting - Be very carefully before restore system back to default since you will lose all current settings immediately.
If you act the function, the ip address will restore the establishing value situation.
192.168.1.20 in the IP Address field and 255.255.255.0 in the Subnet Mask field.
Hope this helps!
Dec 19, 2010 | Computers & Internet
Default Password for Proxim AP 4000 MRLR
The default password is should be "public" if it was factory defaulted.
Dec 04, 2010 | Proxim ORiNOCO AP-4000MR (8670-MR-LR)...
Can't connect to configure password through web address 192.168.0.50
When you reset the AP, how long did you press the reset button? To reset the AP to factory defaults, the reset button should be pressed and held for at least 15 seconds. Also, once reset, the AP should have the following settings:
IP address: 192.168.0.50
Subnet Mask: 255.255.255.0
Default admin username: admin
Default admin password: <blank>
When connecting your PC, either set an IP address within the same subnet (192.168.0.51 255.255.255.0) or choose "Obtain address automatically".
I hope this helps.
Dave Grannas
Jan 25, 2009 | D-Link AirPremier DWL-8200AP 802.11a,...
Change the ip address
If your AP password erros, you can't enter the setup page of your AP in you browser. Do hard reset. Press little button behind your AP about 30 seconds. Will reset your AP to factory default, IP 192.168.0.50 subnet 255.255.255.0 user name: admin password: leave it blank.
May 24, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Proxim ORiNOCO AP-4000M (8670MUS2) 802.11a/b/g Wireless Access Point Logo
102 people viewed this question
Top Proxim Computers & Internet Experts
Prashant M
Prashant M
kj henriksen
kj henriksen
Are you a Proxim Computer and Internet Expert? Answer questions, earn points and help others
