Question about RCA R56WH76 Projection Television
Rca r52wh76 i have the 3d problem with my tv and i can not find the fuses.i have the back of the tv off and dont see them.
  • Anonymous Oct 23, 2008
    I have the 3D affect but I don't notice the bowing of the lines will replacing the fuse correct this also? If I need to get a repair man out about how much will it cost do you think?
    Not sure if I have the same problem or not I have the 3D affect but I did not notice the bowing of the lines. Will replacing the fuse still help?
    Genius:
  • 1,030 Answers
Check out the fl231 problem under the tips and tricks section under my profile willtab. the fuses are small rectangular next to big black part called the flyback
Posted on Oct 03, 2008
Does the rca 52950 have the fl231 fuse? If so where is it located? If not which fuse controls the convergence. I fixed my newer model tv with the fl231 fuse but I dont see it in this tv.
no the fl231 fuse is only for model itc222 rca's . these older set unfortunately do not have that fuse convergence is contolled by a sepreated cuircit board. also these set have no stk ics that are common for most set that control convergence. it uses a series off transistors.
Jan 03, 2011 | RCA P52950 52" Rear Projection Television
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
Won't turn on
il ne s'allume pas et il y a un regulateur dont je peux pas voir son numero
Apr 30, 2008 | RCA F19430 19" TV
Tv dont work
check fuse in back of tv behind lower panel right where power cord gose in to tv
Feb 28, 2008 | RCA P61930BL 61" Rear Projection...
Rca 27f630t
It takes a star driver if I am not mistaken to take the back off probably two different sizes one for the top bottom and sides and one size for where the rca jacks are.. I only recommend checking the fuse...if blown never put foil around it. Takes a 4 amp. 5 amp would be ok. Dont go over this. If the fuse is good you should take to a good tv repairman. If blown and blows the fuse you put in take to tv repairman. Anything past this is highly technical. Hope you have a blown fuse only.
Dec 30, 2007 | Televison & Video
P61940 RCA TV does not turn on.
Get a schematic and trouble shoot the main power supply if you have solid state experience. If you dont , PLEASE call a trained TV tech to assist you in this repair.
Sep 04, 2006 | RCA P61940 61" Rear Projection Television
Have sound but no picture
Do you know if the High Voltage comes on?? Sometimes a vert sweep falure will cause your complant. also a poor solder connection on the horizontal driver xformer is cold connections.. If you understand this then your quilifyed to troubleshoot this set. If you dont PLEASE dont open set as you could not only cause more damage to the set but to yourself as well!
Apr 06, 2006 | RCA P46924 46" Rear Projection Television
Open Questions:
RCA R56WH76 Projection Television Logo
137 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
