Question about Maytag Bravos MTW6600T Top Load Washer
Error of LID - But lid is closed, locked and will not open We have tried the unplug, press start and power button but still nothing.
    Sergeant:
    Champion:
  • 202 Answers
The washer needs a new lid lock and a new control board ... seen it before
Posted on Mar 23, 2011
Lid will not lock, Washer will not start: I press
There might be the issue of the lock as the control board tries to send signal to close the lock but it can not. This is common issue with the lock more than the control board.
Oct 11, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Aquasmart lid
Is the lid lock tang on lid broken.
2.9 Lid Lock
The Phase 7 Washer uses the same lid lock that is used on
the Phase 6 series 11 & 12 machines. The difference being is that the lid is now locked for the entire cycle. When the lid is locked the Lid Locked LED will illuminate. Once the spin
has completed, the lock will release and the lid can be
opened. To open the lid during the cycle the
START/PAUSE button must be pressed, the machine will
come to a halt, and the lid locked LED will extinguish.
If the lid is left open, the machine will be unable to lock the lid
and the cycle will be halted. The machine will play a tune
and the lid lock will flash until the lid is closed and START/PAUSE is pressed.
• If the lid-lock fails in the closed position, the locked lid can be forced upwards and out of the
lock. Note: This is the only time in which we would recommend doing this.
• If the harness is damaged, the complete lid lock assembly will need to be replaced.
If the power supply is cut during the spin cycle, the machine will keep the lid locked until the rotor has ceased to turn (3 to 10 secs). Only then will it release the lock. The motor is acting like a generator and allows the lock to stay energized under the bowls inertia.
Mar 16, 2013 | Fisher Paykel EcoSmart GWL15
The lid lock light won't stop blinking.
LID LOCK FAULT
Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
Lid is not closed completely due to interference.
Check for lock interference with lock striker.
Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
Main control detects open lid switch when attempting to lock.
Main control cannot determine if lid lock is in a locked state.
Perform the following checks if the washer does not lock (or unlock).
1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
Oct 20, 2012 | Whirlpool LSB6200KQ Top Load Washer
Wtw 4950 wont start
you need to get into diagnostic mode and check the error codes. This washer will give you couple of error codes but the first one is the latest. To check error codes
How to Read Vertical Modular Washer VMW Error Code Display
Calibrate/reset error
How to Calibrate Top Load Washer
After calibration/resetting the codes, check error code again that will give you correct error code. If there's no error possible problem is the actuator.
Nov 22, 2017 | Whirlpool WTW4950XW Washer
We have an LG top load model WF-T7012EN. All of a sudden it would stop and dE message will be displayed. If you try to start it again, the same scenario will happen. We had tried to level the load and...
dE indicates a door lock error. Turn off and then unplug the washer to reset the machine. Press and hold the Start/Pause button button for 5-10 seconds. Connect the power cord. Turn on the washer. Open and close the lid to see if it closes properly. Try to run the washer through a cycle.
On some LG top-loading machines, the error is simple to fix. These LG top loaders used a magnet in the front of the lid that to be in place to trigger the lock. When the magnet breaks off or is misplaced, the dE error will occur. If you find the magnet in the washer, replace it in the lid. If you don't see the magnet, get another one. Keep the magnet in place with duct tape.
On other LG washers, the problem is the door not being aligned with the lock, the lock assembly or the electronic control not getting the lock message. Make sure that the lid is closing properly. Bent hinges can cause the issue. Check the latch assembly and the wiring between the latch and the control board. To check the latch assembly, you may need to remove it from the washer. Check the circuit with a multi-meter to ensure that the switch gets power. Replace either if faulty. If the latch assembly and wiring are good, then the control board may need to be replaced.
I hope this helps.
Jan 12, 2018 | LG Washing Machines
Why does it say "op" when i press the start button?
The Service Manual for reference. Sears Parts Direct for reference.
I feel you have lost signaling from the Left Hand Lid Lock for Lid is Open/ Lid is Closed.
First check is to place a magnet over the Left Hand grey bumper and while watching the LED display see if the OP error code clears. If it does you have a lid magnet out of position. See the Service Manual for access to the Lid Magnet.
See Pic;
If an external magnet over the Left Hand grey bumper doesn’t clear the OP error code with the lid open then See this Link for troubleshooting Left Hand Lid Lock Troubleshooting. I discuss the OD error code but the OP error code troubleshooting is very similar. If the lid Magnet is not out of position then I feel you have a broken lead at the Magnetic Reed relay or severe corrosion issues with the Left Hand Lid Lock preventing Lid Open/Lid Closed status signaling to the Control Board in the Console.
FAV6800A/FAV9800A replacement Left Hand Washing Machine Lid Lock - 25001048
Let me know if you have any questions or concerns…….Rich
May 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
"OP" ERROR CODE
Take a look at this post, it’s for troubleshooting an OD alarm but you can follow the same troubleshooting path to see if you have a lid magnet out of position or a broken lead on the magnetic reed relay located in the left lid lock. The lid magnet operates the magnetic reed relay to signal the lid is closed/the lid is open. Try an external magnet on the left bumper and see if that clears the OP error code with the lid open. If it doesn’t I would try reseating the left lid lock plug (possible corrosion issues). If that doesn’t clear the OP alarm it would be time to pull the life lid lock out of the machine and inspect for a broken lead on the magnetic reed relay or other corrosion issues with the left lid lock. The left lid lock is in a location near the bleach dispenser. Links to the SM are in that post and a link for parts look up. Post back if you have questions
Jun 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
DU is flashing and when I press the Pause/Cancel button this does not clear the problem
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer starts and stops a few seconds later with a FL code
Hello donaldwoulla,
I’m an owner of a FAV6800AWW not a GURU, this forum automated rating system is way too generous, I will try to help. Do you feel OK to try some troubleshooting? The following troubleshooting assumes you want try a possible DIY fix.
“FL” code is Failed to lock, we will try a few troubleshooting steps. The following test will be done by selecting the Spin Only cycle. First test will be done in service mode.
1. This is from SM; Press Enviro Plus and Spin Only keys for 3 seconds to activate Service Mode. Access Board Output Test by pressing the Delicates key. Display shows “ot” and the lid locks should actuate locking the lid. Does this happen, do you take the “FL” fail code in this process? Hit OFF button to cancel this test.
2. I want to make sure you signal an “OP” alarm to the display. Can you select Spin Only cycle with the lid open press start. Do you signal the “OP” alarm, lid open to the display? If it does close the lid and the “OP” alarm should clear, does it? I’m checking that the lid magnet is in place and the signaling connections are working thru the left lid lock back to the control board.
3. With spin only cycle selected and the lid closed press the Start Button do both lid locks try to close and lock the lid? From your initial post I believe you throw a “FL” to the display very quickly, that is the left and right lid locks do not actuate several times before the control board displays the “FL” fail code. Is that correct?
4. This step requires you to raise the top off the washer you will need to the move the washer out several inches and you should have a helper available to hold the lid up for you. Unplug the washer from the 120VAC outlet. Use this info and the FAV6800A/9800A Service Manual to assist you. To raise the top of the machine, insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point. We are going to reseat the Left Lid Lock plug a couple of times into the Left Lid Lock. We are checking to see if there might be some corrosion on the plug contacts. Take a look at page 34 of the SM. Top right of the page Lid Lock/Reed Switch Removal where the persons thumb is. This is the plug we want to remove and reseat a few times. It may be difficult to do remove so be careful. Mine was very difficult to remove the first time. This lid lock is near the bleach dispenser and other owners have had corrosion issues with this left lock causing issues. After doing this and you have reseated the plug into the left lid lock a few times power up the washer and give it a try.
Just to let you know don’t worry about the right lid lock, it’s signaling and control functions are in parallel with the left lid lock. I’ve had mine disconnected since mid Dec. The left lid lock is the important lid lock. It has the dual functions of signaling the control board that the lid is open/closed by the magnetic reed relay in that lid lock and the lid is locked by contact closure back to the control board in that lid lock. If this doesn’t help resolve the issue we will try removing the left lid lock to inspect if you feel OK to continue. Good luck. Rich
Mar 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune TL error code op
This forum member’s solution is going in the right direction I’m going to give you a bit more info to troubleshoot the issue if you want to DIY the repair. You have lost signaling from the left lid lock to the control board. The lid magnet could be out of position here is a quick check to try. Raise the lid then press Spin Only key, press on and you should throw the OP alarm to the console. With the lid open place a magnet on the left bumper as shown in this pic. If the OP alarm fails to clear we rule out the lid magnet as out of position.
Next step is to raise the washer top as shown on page 34 of the Service Manual
To raise the top of the machine insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
Disconnect the washer power cord. We can try to reseat the Left Lid Lock a couple of times to see there is there is corrosion causing a issue. Removing the plug is difficult so be careful. See page 34 of the SM, the plug you are going to reseat is shown in the pic on page 34 next to the tech’s thumb in that pic. After reseating a few times power up the machine try a Spin Only cycle, close the lid and hit the on button and see if the left lid lock is signaling the control board that the lid is closed. If you still take the OP alarm then it’s time to remove the left lid lock and inspect for corrosion or a broken wire on the magnetic reed relay. Some owners have found that corrosion has caused the soldered lead ends on the on the magnetic reed relay to break off. They can be soldered back on. See pic’s for corrosion issues and the lead that has broken off the magnetic reed relay.
Follow the SM to remove the left lid lock be careful when you release the tabs on the left lid lock case halves for inspection they break of very easy. Post back if you still need help. If you need to replace the left lid lock here is the part number 25001048 and a link, another. Good luck.
Sep 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
601 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
