Question about GE Dryers
The timer got stuck on my dryer and was on all night. now it will not get hot at all
    Sergeant:
    Champion:
  • 202 Answers
You have a bad element if the dryer timer was on all night and no heat
Posted on Mar 23, 2011
White knight tumble dryer cl847 not heating
-Possibly one of the heater element blow out.
-Timer switch assembly stuck in low position.
Good luck
Mai
Nov 21, 2013 | Dryers
Dryer control doesn't move on less dry more dry setting and will not shut off when clothes are dry.
If clothes are hot then try dryer on timed dry. If timer does not move then timer is most likely bad . Replace. If timer moves on timed dry it is not getting hot enough to click the cycling thermostat.(If clothes are overly hot above 160 then the cycling therm. is stuck Replace.
Oct 29, 2010 | Dryers
I started my dryer one night i figured it would shut off but when i woke up the next morning it was still running and appeared to still be warm. The timer apparently was stuck on 70 minutes. the following...
Kenmore is a Sears brand and there isnt too much info on the net as for tech support. Youre best option is to call sears and see if they can give you any over the phone advice, but if the timer switch is getting stuck, it sounds like it may need replacing.
Nov 06, 2009 | Cars & Trucks
My dryer got really hot one night and 3 nights later it stopped working. I checked all of the electrical and everything has power except for the timer.
Did you check the thermostats in the air tube going from the blower to the drum?
Sometimes a faulty thermostat will cause the over-heating problem you mentioned. This may also lead to heating coil failure.
A thermostat problem could lead to the dryer not running also.
Hope this helps
Sep 30, 2009 | Whirlpool LER4634J Electric Dryer
Dried some clothes the other night and when I went out to take the clothes out the next morning the dryer was hot on the top and in the back of the control panel. I unplugged the dryer and took the top...
More than likely, the motor centrifugal switch is stuck. You should be able to turn off the element with the timer control switch. If the timer switch is on and the dryer is not running, the element should be off, unless the motor contact is stuck closed. You will have to get to the motor and 'un stick' the contact.Its a bit tricky, you may need help.
Jul 21, 2009 | Kenmore 62802 Electric Dryer
Maytag model# LDE482 electric dryer won't blow hot air
Either the control panel is defective or the dryer heating element is defective.
Jun 28, 2017 | Maytag Dryers
Ge dryer staying hot even when it's off
This could be a stuck main timer control or thermostat. I recommend you un-plug the dryer until the problem is located. You don't want to start a fire or do more damage.
Mar 28, 2009 | GE DRSR483ED Electric Dryer
Timer on Insinkerator
if you install a timer. what kind? Hard-wired 24 hr or plug-in heavy duty like for an a/c. How much will you save. Instant hots use same power as 60w bulb. Add the cost of a timr ($20-$50) and the power it takes to run the timer, what will you save?
Jan 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
49 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
