Question about Acer Aspire One PC Notebook
My battery was charged the whole night but it can only used for half an hour is that means that the battery is already loose?
    President:
  • 676 Answers
Could be. oNe thing to try is let the battery die completely. Then try an overnight charge. If it still works the same, then the battery has bad cells and will need to be replaced. Good Luck.
Posted on Mar 23, 2011
  • 112 Answers
Over time batteries lose their ability to retain a charge, and eventually need to be replaced, it's perfectly normal. You can try and boost the battery's ability to retain a charge by reconditioning it; basically you charge the battery until it's full, then use the battery until it's completely drained, then charge the battery until it's full, and repeat. This might help you get a little more use out of your battery, but it won't make it like new again. Consider buying a replacement battery soon.
  • 902 Answers
Yes the battery is already loosing its ability to hold a charge. lithium ion batteries are the common choice for batteries in laptops/ cellphones etc. they slowly (sometimes to fast in my opinion) loose there ability to hold a full charge. over chargering the battery also decreases its life. i picked up a new 9 cell (more lithium ion battery cells) on amazon for my toshiba laptop for 50 bucks (cheaper then from toshiba and toshiba only had a 6 cell) and jumped from 2 hrs run time on my old one (before it started to do what yours is doing) and went to over 4 hours.. now its dropping. the key here is to get a new battery. DRAIN IT. charge it all the way up. but dont over charge it (i.e keeping it plugged in all the time) Hope my info helped
Samsung d900 . battery run on half an hour during call and if it is sleep mode then till 4 hours only
Please check the adapter voltage and the charging of the battery when placed for full charging. Once the charging has confirmed to be full remove and try once again to see if the phone indicates. Now clean the terminals and connect. If the battery does not last , it is possible that it must be replaced. Please confirm with a battery from a friend and buy ONLY the original with warranty.
Apr 26, 2011 | Samsung SGH-D900 Cellular Phone
How long i have to charge my Euro-Pro Shark
mcdevito75 here, I believe a full charge would be 4--6 hours, but wait until battery needs the charge, to charge a battery with an already half charge or better could shorten battery life.
Jul 21, 2010 | Euro-Pro Shark SV800VX63 Stick Vacuum
Why i charge the baterry(GP2700) whole night when i snap the picture only 2 picture can use.many times already not only gp rechargeable baterry but (panasonic 2700) also.can someone solve my problem
If you have a friend who uses the same battery try one of yours in their camera to see if it works properly. Alternatively, try the opposite and borrow a known good battery from a friend and try it in your camera.
You either have a major problem in your camera, a coincidence of two dead batteries or a broken charger. Make sure all you connections are clean. Just a simple piece of printer paper rubbed over the battery contacts is enough to clean them. Ensure the charger connections are clean and even the connections in the camera. Check the lights on your charger. Is there any indication the battery is flat to start with and any indication of when it's charged? Usually a red light means the battery is charging and that light going out or turning green means it's charged. The battery shouldn't have to be on all night. Usually it should take maybe an hour or 2.
Finally, how long have you had your batteries and are they Li Ion or NIMH. Nicads are no good for digital cameras. They can develop memory problems. So if they are Li-ion or Nimh ensure you are using the correct type charger for those batteries
Apr 14, 2010 | Kodak EasyShare C653 Digital Camera
It only last for 1 hour and a half . according to the store this is normal because my processor is AMD athlon and 2 gig memory. i thought 6 cell batteries run for abt 3 hours. is there a compatible battery...
The lithium iron battery for this conputer is 4000 mA/hrs. or 4 Ampere hours. That means that with a draw of 1 Ampere the computer would be useable off the battery for 4 hours. Since you can't run off the battery below a certain voltage you can deduct 20% leaving a battery life of a little over three hours.
Apr 11, 2010 | Compaq Presario Notebook
Sony ericcson aino's battery consumption is low.. after charging for over night, just after an hour, my battery is already 80% without using my phone too much.
do not charge your phone overnight, it will reduce ur battary life, it need only 2 hours of charge, and it will work for two days only
Jan 05, 2010 | Cell Phones
When i charge my battery its all full bars i hold the phone in my pocket whole day (its still fully charge) when i got to bed at night and wake up in the morning the bettery is (half way) i hold the phone...
Depends on whats running and what you use it for during its use. Technically shutting it off to reset it once a day is good, but it being half dead a day and half later is pretty normal
Sep 26, 2009 | Samsung Eternity Cell Phone
I870 battery or phone problem???
you bought it off ebay --your battery probable at fault but also depending on what you have -running or downloaded apps-photos -music will drain battery in stand by mode even if you replace battery if your usage is high [dont have to be on phone ] from what you have on it battery drain can be the same
Apr 19, 2017 | Motorola Mobility i870 Cellular Phone
No problem, just ?
No issue. The charger is adapted to the battery. You can leave the battery over night in the charger without problem. The fact that the light goes off means that the charger surveys the voltage and switches off when the battery is charged.
If you leave it longer and the battery looses charge, it will be recharged automatically.
Cheers
Critter1965
Dec 27, 2008 | Olympus FE-340 Digital Camera
Sidekick 3 battery problems :(
what you do is get a new battery and if that does not help the situation then take the phone into a service center to have it check.
Jun 17, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Charge
hi your battery has created a memory because you didn't follow simple battery guidelines:
For a new phone with a new battery;
1)Use the phone the first time until the battery dies,
2)Do a full charge - 6-8hours for the first time
3)Use the phone until it dies the second time
4)recharge the battery for 3-5 hours
then your battery should be good, but now your battery needs to be changed, as it already has memory and can only be restored if completely discharged by a battery conditioner
Jan 30, 2008 | Motorola Mobility RAZR V3
Acer Aspire One  PC Notebook Logo
114 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
