Question about Dishwashers
The water will not drain from my dishwasher..the cycle was finished and we even tried the drain button but no luck. We were trying to take the filter at the bottom off but we can't figure out how to take it off.
  • 55 Answers
You would need to remove the drain pump to clean the debris out. Depending on the model number this would require you to remove the lower access panel.
Appliance & Refrigerator Repair
Posted on Mar 23, 2011
Not finishing cycle
Is it draining out the water?? Dishwashers fill, spray, and drain more than several times during a cycle. After starting a cycle, let the unit fill, start spraying, and then cancel the cycle--listen for the drain pump activating and pumping out the water. If water is not being drained properly(within a certain time limit), the unit will error code out and stop. Also, make sure the filter is clear--if it gets clogged with "muck", enough water won't be sprayed onto the dishes properly, the pump will require too much energy to try to pump water, the control will sense this and shut down the unit to protect it.
Jul 25, 2015 | KitchenAid KDHE704DSS 24 6-Cycle/7-Option...
Hi I have a problem with my Bosch SHU43CO6UC/22 dishwasher. using "power scrub plus" and "regular" cycles it will continue to fill and overflow the door, after the cycle has run even...
The bosch dishwashers use a fill valve that is attatched to the inlet hose. yours is stuck in the open position. this usually happens when you have hard water, as the minerals build up on the sealing surface of the water valve. there is no easy fix. the fill hose will have to be replaced. It requires removing the machine, removing the bottom pan, and changing the hose connections.
the valve uses water pressure to stay closed. if the water pressure is very low coming in, it may not be enough to close the valve. there is a filter screen between the fill hose, and where it connects to your water valve. try cleaning the filter out and see if that makes a difference. If not, you will have to get the hose changed.
Nov 19, 2010 | Dishwashers
Dishwasher not draining after a power cut
I would run the heated dry cycle a few times to try and get rid of that residual water, then restart the cycle and see if it work now. If it still is a problem try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Water left in bottom of dishwasher after cleaning
I suggest checking the drain and screen. There is most likely a little clog in there. If there is even the slightest amount of clog, the washer will not finish the drain cycle.
May 23, 2009 | Dishwashers
Won't drain
Make sure the garbage disposal is clear so the water can exit. After that, you may have something caught in the drain hose or check valve. It would require removing the bottom kick plate to gain access to check.
Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher flooding
When you say that you tried other solutions.. it's hard to know which you've tried and which you haven't so I will suggest some basics first.. ( if you've tried them, then disregard)...
Have you checked or addressed the following:
  1. Cleaned the drain filter
  2. Checked the drain hose for crimps or restrictions
  3. Sure the drain system ( such as your feed thru the garbage disposal isn't clogged or restricting flow)
  4. Checked your water pump for an obstruction or you can determinbe if it is actually pumping
  5. The feed and returm hose ..to anf from the pump are not clogged, pinched or restricting flow.
These are the basics that you should have examined or confirmed aren't causing the problems you are seeing. One other as well.. are you sure your water inlet valve is completely shutting water from leaking in and over-filling the system? Check these items and you should be able to diagnose where the problem is.. Hope this helps you,
Sep 21, 2008 | Asko D1716 Built-in Dishwasher
Kenmore dishwasher not draining when finished full cleaning cycle
sounds like a cycle timer problem. Look for a loose wire on the cycle timer. If yours is a digital timer, it is a board issue. Sorry.
Aug 03, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Oct 28, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
