FixYa.com
Tags:
Panasonic Home Theater System System
Panasonic Dvd Home Sound system SC-PT950 code f61
posted by llubrano on Aug 03, 2008
We've had this system since January, came home last night and Code F61 shows up on our system when we try to turn on. The manual states it could be a speaker issue, we checked the speakers and they're all working. Please give us another suggestion on what to check or what could actually be the problem, please.
Thank you
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 07, 2008
Not Rated (0)
Abrsvcs
Rank:Guru Guru
Rating: 86%, 654 votes
The F61 is the coded "protect mode" indication. The internal amp chip has failed. It sounds like this system should still be under warranty. Return it for warranty service. The amp chip will be replaced.
Sorry about hte delayed response. I was away in business for a few days.
Dan
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Home Theater Systems problems?
Panasonic SC-PT960
How do you change from FTC to... Answer This...
machine not play when press...
Whenever you press play it... Answer This...
panasonic sa-ht700 burned cd...
it only plays burnt cds that i... Answer This...
I have a CD STEREO SYSTEM...
When I power up I get F61 and... Answer This...
SCHT730 F61 ERROR
After a power failure, fuse on... Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
