Cars & Trucks Logo
Posted on Mar 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i hav a 1990 toyota with the 3vze 3.0 v6 sohc 12 valve i need the rod bolt torque
Charles Huckeba
Level 2:
Genius:
  • Expert 1,114 Answers
  • Posted on Mar 23, 2011
Charles Huckeba
Expert
Level 2:
Genius:
Answers
1114
Questions
0
Helped
322355
Points
316
The connecting rod nuts for these engines use a combination torque, then turn method to achieve the proper clamping load. First the nut is torqued to 18 lbs.ft., then turned an additional 90°. It is possible for the rod bolt to slightly turn inside the connecting rod during this process, causing the final torque to be below specifications. The nut must be turned 90° relative to the bolt, not the connecting rod.
Torque specs on camshaft cap bolts on a 2010 ford ranger 4x4 sport 4.0 V-6
SOHC V6 Torque Specs Camshaft sprocket bolt: (E/MWM)
Left: 63 lb-ft
Right:LHT 63 lb-ft or 45 lb-ft if using 6485 socket extension
Camshaft bearing cap bolt: (E/MWM)
Step 1: 53 lb-in
Step 2: 12 lb-ft https://www.explorerforum.com/forums/index.php?threads/sohc-v6-torque-specifications.406687/
1helpful
I'll pan torque spec on 2002 rord ranger 4.0 sohc
SOHC V6 Torque Specifications - Ford Explorer and Ranger Forums ...
https://www.explorerforum.com/forums/showthread.php?t=406687
Apr 25, 2014 - SOHC V6 Torque Specifications Under the Hood. ... related to the Ford SOHC V6 4.0L engine used in Explorers, Mountaineers, Mustangs and Rangers. .... Oilpan (sheet metal) to crankcase reinforcement section bolts: 80 lb-in (E/MWM) ....Ranger Mountaineer - Sport thru '03 - 2nd Generation, 2002 - 2005 ... Transmission pan drop
May 7, 2012
SOHC V6 Timing Chain Inspection & Repair
Aug 10, 2010
Another transmission won't go after fluid change
Mar 14, 2009
Help with 4.0 SOHC timing
Mar 12, 2006
More results from www.explorerforum.com
[PDF]SPECIFICATIONS > TORQUE SPECIFICATIONS
www.askatech.com/askatechlive/forums/resourcehandler.ashx?a=5581
Jan 6, 2014 - TORQUE SPECIFICATIONS ... ENGINE - 4.0L SOHC. 2002 FordExplorer Sport Trac 4.0L Eng. (1). (2) ... Oil Pan Ladder Frame Bolts (Inside).
Torque Specifications - AutoZone
2helpful
Hi i was wanting to now if anyone knows the Torque Settings for the head of a 1992 Toyota Windom V6. Thank you.
Cylinder Head Torque Sequence
Tightening torque:
12 sided bolt
Step 1 ..... 34 Nm (25 ft lb)
Step 2 ..... Tighten an additional 90°
Step 3 ..... Tighten an additional 90°
Recessed head bolt ..... 18 Nm (13 ft lb)
1helpful
Hello, what are the torque specs on the conrod bearing caps for the 1990 toyota 4runner V6, 3VZ-FE engine? thanks
connecting rod cap torque specs is 18 ft. lb and tighten an additional 90 degree.
hope this can help
8helpful
3answers
Need to know the head bolts torch specs on 98 toyota v6
heres the torque specs and the way to tighten the head bolts for your 1998 toyota sienna, hope this helps,
12 point bolts step 1- 40 ft lbs
step 2- additional 90 degrees
3helpful
Whats the torque setting for big end bearing bolt and cylinder head bolt for toyota corolla 12 valve 2E,1990.
hi big end bearings are two stage, 25nm leave ten mins, then 49nm cylinder head bolts three stages 20nm leave ten mins, 40nm leave ten mins then 60nm check after 5,000miles hope this helps
2helpful
I need compression specs for my 91 p/u 3.0 l 2958 cc v6 3vze sohc with acceptable ranges for a bank loan
The compression values for this truck are 115 to 140 psi. The values can't be more than 14 % apart from one another or the engine will be imbalanced and in need of an overhaul.
3helpful
Need torque for a 2000 Toyota Celicia GT 1.8L
Crank Main caps Tightening Torque
For the 12 Pointed Head Bearing Cap Sub-Assembly Bolts
Start from center bolts and tighten in a clockwise rotation working out
Step 1 all bolts 22 Nm or 16 ft lb
Step 2 all bolts 44 Nm or 32 ft lb
Step 3 all bolts 45 degrees additional clockwise rotation using an angle indicator.
Step 4 all bolts 45 degrees additional clockwise rotation using an angle indicator.
Hexagon Head Bearing Cap Sub-Assembly Bolts
1ZZ-FE Engine 18.5 Nm (14 ft.lb)
2ZZ-GE Engine 18 Nm (13 ft.lb)
Connecting rod:
1. Apply a light coat of engine oil on the threads and under the heads of the connecting rod cap bolts.
2. Install and alternately tighten the 2 connecting rod cap bolts in several passes. Torque: 1ZZ-FE: 20 Nm (204 kgf-cm, 15 ft. lbs.) 2ZZ-GE: 30 Nm (306 kgf-cm, 22 ft. lbs.) If any of the connecting rod cap bolts does not meet the torque specification, replace the connecting rod cap bolts.
3. Retighten the cap bolts by 90° more
4. Check that the crankshaft turns smoothly.
Torque settings clio 1.5 dci big end shells
whats the torque setting for big end bearing bolt and cylinder head bolt for toyota corolla 12 valve 2E,1990.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
