Question about Canon EOS 40D Digital Camera
Error 01-no communication between lens & camera
Communication error between lens and camera ( Error 01 ) what should i do, i m using canon 40d
Posted on Mar 25, 2011
How to fix error 001 in canon lens
The Canon Err 01 is called Lens communication.
The lens has lost communication with the camera, or vice versa. This can be caused by dirt or grease on the gold coated contacts. On the lens or in the camera.
Try cleaning the contacts, with a dry cloth or cotton swabs. Don't use any sharp tools or force. To pinpoint where the error is, you could try to place another lens. If the error disappears most likely the first lens caused the problem. If the error stays, you should suspect the camera.
If you only have the problem with one lens, and the contacts are clean, contact a certified Canon repair centre.
Jul 10, 2014 | Cameras
Busy and or Error 01
For error message 01 the manual says: Communications between the camera and lens is faulty. Clean lens contacts.
Solve: Clean the electrical contacts on the camera and lens and use a Canon lens.
SO if you are using a different lens or a non Canon lens this could be what is wrong.
If you never changed a lens, it still can be that something went wrong in the communication between the camera and lens. Just careful remove the lens and with a dry and lint free cloth, clean all contacts on the lens and in the camera. While working on the lens, close the camera with the camera cap, or put the camera face down.
Don't use anything sharp while working on a lens or a camera.
Dec 04, 2013 | Canon EOS 60D Digital Camera
Error 01 communication
Not that same lens..mine.a 35-80 but, I was able to take care of a problem error 01 by cleaning the contacts on the lens using a "Q" tip and alcohol. Did re-install till after it was dry.
Aug 02, 2013 | Canon EF 28-90mm f/4-5.6 II USM Lens
Err 01 Communication between the camera and lens is faulty
Most of the Time when this happens it's the curcuit board inside the lens that bad from use, Needs to be replace by a repair Tech! Try a different Lens to confirm that! TCCameraRepair.com
Jan 27, 2018 | Canon Digital Rebel XSi Digital Camera
Error 01 in canon eos 5d
Err 01: Lens to body communication error
1.The camera to lens communication is somehow being interfered with could be a problem within the lens itself, possibly the camera body, or something as simple as a smudged fingerprint on the lens mount contacts,
2. Check the lens and the contacts
3. Also check below link if you need a canon eos 5d service manual
http://goo.gl/1rXwuc
thanks
Apr 26, 2012 | Canon EOS 40D Digital Camera
I have the tamron 18-200 mm XR Di-II if macro lens. The camera displays the error Err 01 Communication between the camera & lens is faulty. Clean the lens contacts. This error...
So, have you cleaned the contacts as you were advised? You do this by removing the lens and cleaning the contacts on the camera body and on the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
May 19, 2011 | Cameras
Error 01
Error 01 is about the communication of the LENS with the camera. Please try to re-attach it and make sure it is correctly fitted. Also you can remove the lens, start cleaning the contacts, put it back in place again and then test.
Oct 24, 2010 | Canon EOS 30D 8.2MP Digital SLR Camera...
What does error 01 mean
Error 01: A communication problem between the lens and the body. Try cleaning the the area between the objective/Lens and the body. If that doesn't work, try another lens. If that doesn't work, try the first lense in another body, and if that works, it's most likely the body that's broken.
Jul 29, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Error 01 tamron lens 70-300 mm af 4-5.6 with canon dslr 450d
Error 01 means that communication between camera and lens is faulty. Try to clean lens contacts.
May 28, 2010 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
Canon err 01
This error means "Communication between the camera and lens is faulty. Clean the lens contacts." If you are using the same lens on both cameras, the problem is with the metal contacts on the rear of the lens where it communicates with the camera body. You can gently clean these contacts by using a clean pencil eraser. Make sure you hold the lens "bottom down" as you clean it so that the eraser debris falls to the table instead of inside the lens!
Nov 08, 2007 | Canon EOS-1D Mark II Digital Camera
Canon EOS 40D Digital Camera Logo
680 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
