My washing maching wont heat up the water - Washing Machines
  • 4,350 Answers
The washing machine has zero ability to heat up water, it uses hot water from the hot water tank.
Posted on Mar 23, 2011
Why is my Kenmore elite three speed top loader washing maching model number 110.23022101 only washing on HOT water? The cold will not work. We recently had workers remodeling that room and the washing...
Make sure the cold water supply is on and not blocked.
If the machine fills but does not wash try to find a thermal switch that is supposed to come on when the cold water has heated up.
Jul 20, 2014 | Kenmore Washing Machines
WashMachine wont wash and wont stop filling
There is a rubber tube that goes from the outside of the outer plastic bowl up to the pressure switch in the top panel. It is on the left rear corner. It may have been pulled off the pressure switch. Look under on that corner and locate where it is attached to the plastic bowl. if that is OK then follow the tube up and check top connection.
Hope this will help you.
Feb 07, 2012 | Simpson Washing Machines
Washing maching wont fill
You need to get it out of your Saturn, then hook up the plumbing.
May 20, 2010 | 1997 Saturn SL
The washing maching wont go thru spin cycle or empty water. Smells hot.
most likely your dial timer switch is bad ...can be costly to replace. if its a older washer junk it and buy a new one! Sorry!
Dec 05, 2009 | Washing Machines
Fills up with water and wont stop
if it still fills , with power off, the valve is letting by water and has become faulty,if water stops with power off,check for smudged powder at the lower part of the pressure switch pipe giving a false read to pressure switch,other than that the pressure switch has become faulty,look at the pressure switch pipe first for blockage,hope this helps
May 07, 2009 | Whirlpool WTW5200S Top Load Washer
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Neptune-is water supposed to remain, after wash is finished, between tub and outer shell
if you hear water when you spin the basket,that is the front tub balance ring.it is filled halfway with water in order to assist mach in balancing load.that is a normal sound.the mach may also leave some water between the basket and outer shell depending on lengh of drain hose.as long as the clothes do not come in contact with the water it is fine.
Sep 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing machine
HOT WATER VALVE IS FAULTY
Nov 29, 2006 | Indesit W 123 Front Load Washer
Tub will not fill with water
That's Great Man. Thank you for letting us know!
Apr 29, 2006 | Kenmore 23822 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
