Question about Dishwashers
Magic chef dishwaser (old). White film on glassware after wash. The washer only takes powder. I use cascade. use
  • 55 Answers
Try running a white vinegar wash. Add 1 cup to the unit and run a normal cycle. Also rinse agent must be used to achieve spotless glass. Water hardness can affect this as well.
Appliance & Refrigerator Repair How To
Posted on Mar 23, 2011
How do you eliminate the film on glassware after washed in dishwasher ?
Your heater may not be working properly. It is used to heat the water during the main wash as well as dry the dishes at the end. But don't under-estimate the importance of using the right detergent. Some discount detergents (especially liguids or gels) don't work very good. Stick with Cascade or Finish powders or those All-In-One tablets by Finish corporation (the ones with the little red "power ball"), or the new tablets put out by Cascade called "Platinum". In our repair business and experience, we find those work best.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 30, 2014 | Kenmore Dishwashers
The white film on EVERYTHING!! Is it the dishwasher or detergent?? Stock # 16755 Model # 16755690 Serial # FB4911984. We use Cascade...phosphate-free....dishwasher soap.
It may be the detergent, I would try changing to "Finish Powerball Tabs" Hope that takes care of your problem. Also if the dishwaser has film on inside you can buy some "Tang" and run it through a cycle that will help clean off the film. We have really hard water and I run Tang through dishwasher about once every six months.
Mar 25, 2011 | Dishwashers
We have a Miele dishwasher that is less than one year old. We have lots of problems with cloudy/etched glassware with every dishwasher load. We are using Cascade soap. In our previous dishwasher (not...
There are several causes in dishwashers that make dishes come out with film on them or something of the sort. Here they are.
1 Water temperature should be 140 degrees. Your dishwasher should have a "sani" cycle that heats up the water into that range.
2 Most dishwashers were never engineered for liquid soap. So if you are using it, go to powder soap.
3 A rinse agent is definitely a big plus
4 In some parts of America, such as Florida, lime deposits build up in the machine and accumulate onto the dishes and glasses. It's a white film. It also accumulates in the parts of the machine and clogs them. If this is the case. Run white vinegar in the machine.
Empty the machine.
Turn it on.
While the machine is filling with water, (not at the very very beginning as it will drain out existing water when it is started) put a quart of vinegar in and run it. If it has lime deposits it will greatly reduce them.
5 The spray arms may be jammed with pieces of food or other debris. make sure the holes in the arms are not obstructed.
That should do it.
Best, Mark
Dec 31, 2010 | Miele G892SC SS Dishwasher
White powder residue left on dishes after washing. I run hot water before running dishwasher, use Cascade powder (fill dispenser less than 1/2 full per installer and do not use prewash detergent...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 10, 2010 | Whirlpool DU805DWG Dishwasher
This is a magic chef, only a few years old. I use cascade detergent powder. the washer runs, gets water & drys but the dishes come out with a cloudy flim all over them, like the detergent is baked on
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Sep 04, 2010 | Magic Chef CDB1500AW 24 in Builtin...
White film on dishes/not rinsing properly?
Buy a name brand powder (like Electrosol or Cascade) and use less than full in the dispenser cup.
Do not use gel or tablet, ever.
Final option: (the perfect fix, expensive, but worth it... install a whole house water softener and cut the use amount of detergent in half that you use in both your dishwasher and clothes washer. You will love it.
If problems continue, have the heating element checked/replaced. When it fails, you will always get film/residue on dishes, especially your glassware, even if your water heater is set to the proper temp of 120 degrees.
Good Luck!
Apr 01, 2009 | Dishwashers
Model GU2700XTS81 purchased a few months ago. Dishes come out with chalky white film on them. I am currently using Palmolive Eco liquid and Cascade Crystal clear rinse. At first I thought I might be...
Switch your detergent to Cascade powder. Then use Dishwasher Magic (or something similar) to remove the lime/scale build up and to clean out your pump.
SG
Mar 27, 2009 | Whirlpool Dishwashers
Dishes have a white film on them when cycle is over
If you have hard water then you might want to get a water softner.And get cascade powder soap,tablespoon to a teaspoon of powder soap is all you need for a whole cycle.
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
65 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
