Question about Linksys WRT160N Wireless Router
GdayI am trying to connect my PSP via WRT160N without success, any suggestions please?? Thanks
    Guru:
  • 868 Answers
I see that you are having difficulties connecting your PS to your wireless Router, Inorder for your PSP to get connected to your Router wirelessly make sure that your remove your Network Key from the Router this will let cell phones and other mobile devices connect to your Router without any errors, to protect your Network having a disable security you can enable MAC Address filtering in your router this should let you get your PS and other mobile devices connect to your Router and at the same time give security to your personal Network.
Posted on Mar 24, 2011
Wireless was connecting without issue.. used wpa encryption (passkey), mutiple computers connected well. router had orginal firmware 1.x on it so downloaded firmware from this website, made sure it was...
Hello there Sir/Madam! My name is Alex and I work under FixYa.com expert team surveillance.
Solution for your problem you can still find at this adress.
Well, its noticeable that a lot of people complain about exactly that type of router "Linksys WRT160N Wireless Router". There is definitely problem with firmware upgrade, so I suggest you to press and hold reset button for 30 sec, to put back your x1 firmware, or if that doesn't help, contact your Linksys WRT160N Wireless Router contractor and/or your ISP, and ask them to downgrade your Router. Just to notify, encryption can't defect your connection at all, since all ports on router are always opened if wired for your host pc's :)
Hope this helped and/or advised you on your next move.Please rate my solution, thanks in advance. Wish you good day
Adzic A.
May 09, 2011 | Linksys WRT160N Wireless Router
My Linksys WRT160N router is only partially functional. After working fine for several months, it now connects only maybe 1 time in 10 - and most of those connects are very slow and unstable. Occasionally,...
Please be sure your router is not too close to your cordless phone.
They both works on similar frequencies and the router can become unstable.
regards
Mar 19, 2011 | Linksys WRT160N Wireless Router
PSP internal error 80410a0b when trying to connect to internet via wifi on all three of my PSP's. I have 8 computers and 2 smart phones that connect just fine
  1. Take out the UMD disc from the back of the PSP if one is inserted.
  2. Take out your memory card from the memory card reader if one is inserted.
  3. Turn on your PSP.
  4. Go to the "Settings" tab in the Cross Media Bar and select "System Settings."
  5. Select "Restore Default Settings" and confirm that you wish to restore all settings to the factory defaults.
  6. Restart your PSP.
  7. Try connecting to the Internet again. If you still get the 80410A0b error, try connecting to another network. If you successfully establish a connection to another network, your router is at fault. If you cannot connect to the second network, your PSP's Wi-Fi card could be damaged and may need repairs.
Jan 12, 2011 | Sony PlayStation Portable (PSP) Console
I have a Linksys WRT160N router that I am using with a MacBook Pro laptop running Snow Leopard. I used my computer (with some difficulty) to set up the wireless access by way of a wired connection. The...
My Friend ,
Login the router setup page .
And under router security settings uncheck the option (block anonymous internet request).
Set the wireless channel as 6 or 9.
And then use wep security key.
this will surely work.
Regards :-
Amit
Jan 07, 2011 | Linksys WRT160N Wireless Router
Linksys wrt160n router. wireless xbox won't connect
I made it an unsecured connection and everything worked. Not ideal solution, but it worked.
Feb 07, 2010 | Linksys WRT160N Wireless Router
Linksys wrt160n will not broadcast the internet wireless or ethernet it will however broadcast a connection to the router not the internet. I have tried to re-set it, power down, nothing works. I have not...
Your Linksys WRT160N is a router that can be accessed via CAT-5 cables and wirelessly. You must configure the router though, for wireless use. If this is not configured or not configured correctly, then you may have problems using it wirelessly. Laptop computers usually use the 802.11g mode, not the 802.11n, at 54MB or with the right NIC in a desktop you can get 108MB. If it was working then quit without your doing anything, you may have to replace the router, but I doubt it.
Nov 08, 2009 | Linksys WRT160N Wireless Router
I have a Bell DSL modem Speed Streem 6520,linksys Wrt160n &16port
How to Set up the Bell DSL modem: http://www.digitalhome.ca/forum/showthread.php?t=97732
Setting up a Linksys WRT160N Wireless Router: http://www.linksysbycisco.com/US/en/support/WRT160N
(Download the Manual from this site)
Setting up a Linksys 16 port switch: There are many different switch models, however if it just your basic switch, you should be able to just plug it in and plug in your computers via RJ45 cables.
If you need any further assistance let me know....
Serge
Apr 09, 2009 | Linksys WRT160N Wireless Router
VPN connection problems!
I am not real versed on VPN connections but the only way I was able to connect to my company's Cisco VPN using my Ipaq was with this program. http://www.apani.com/vpnclients.html The whole thing went very easily.
Sep 08, 2005 | HP iPAQ hw6515 Pocket PC
Linksys WRT160N Wireless Router  Logo
59 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
