Question about D-Link DSS-16+ Desktop 16-Port Switch (NEWITEM46640391)
How do you reset D-link dss 16+? - D-Link DSS-16+ Desktop 16-Port Switch (NEWITEM46640391)
  • 55 Answers
Two ways. Unplug it. OR
Go to it's ip address
Posted on Mar 23, 2011
When I plug a cable into the computer from the switch, I am getting ethernet cable unplug error. I know the cable is good and my router is set up correctly. I have 15 computers using this switch and only...
check individual IP of your computer..try to obtain each PC..let you router assign the ip.check your router maybe you need to add addition numbers of clients.
Jun 26, 2011 | D-Link DSS 16 Plus (DSS-16+) 16x10/100...
I have a D-Link DSS-16+ and I was wondering if I could plug the dsl modem in any port on it and will it work? Thanks
The DSS means that this is a switch, not a router. This means that you will need a router between your modem and the switch. Switches are usually used in workplaces where there are many machines connecting to the internet with wired connections. For home use, most things connect wirelessly. The reason why you need a router is because a switch cannot create internal IP addresses like a router can. It can only pass on the IP information.
Jun 17, 2011 | D-Link DSS-16+ (dsdldss16p) 16x10/100 Mbps...
How to reset a D-link dss-8+ router i cant connect to the router, it dosent want to give me an ip, subnet mask, and default gateway ip, i need to do a master reset.
There should be a small hole in the back you can stick a paper clip in. Make sure the power is on and press this button and hold it for 30 seconds. This should reset your router.
Mar 03, 2011 | D-Link DSS 8 Plus (DSS-8+) 8x10/100 Mbps...
Limited connectivity problem, same time i connect 16-port dlink switch but connect only 2or 3 system only ,other system showing limited connectivity on your system how to solve the problem pls,
I can't confirm but i believe that DSS-16+ has an actual internal hardware error.
I am having reoccurring errors with the same issue using my DSS-16+ the current solution i have for it, is to take the affected system plug it directly into the wall (or router or modem) and wait for it to get a solid connected then when i plug it back into the switch it stays connected without any error.
You can try other ports assuming that its possible one or many ports are damaged, but i have been plugging it back into the same port without trouble.
However, this is a stop-gap solution not a total fix, that would be to send the unit back to D-Link and have them replace it completely or even get a different switch from Cisco/Linksys or another company.
Jan 09, 2011 | Computers & Internet
How do I reset a d-link dss-16+ after restarting a cable modem?
Probably don't need to reset a switch, but just unplug it, wait 15 seconds and plug it back in. If anything, tho, your router would need to be reset more than a switch.
Dec 24, 2010 | D-Link DSS-16+ (dsdldss16p) 16x10/100 Mbps...
No lights at all. i confirm power to the unit. I cannot find a reset button
I recently had this exact problem and saw a solution by TJones99.
The power supply board has two capacitors that are probably bad and are swelled at the top. These are 10V 1000uf capacitors. 25 cents each! Replace the two capacitors and you'll have your switch back.
Oct 18, 2010 | D-Link DSS 16 Plus (DSS-16+) 16x10/100...
Internet will not open on computer. How do I configure the router page.
try linking to it directly with a network cable and on internet explorer go to address 192.168.2.1 or 192.168.1.1 (check DLINK manual) this might get you onto its setup page.
Mar 25, 2010 | D-Link DSS 16 Plus (DSS-16+) 16x10/100...
How to play .dss voice files in express scribe?
If you want to play .dss files first of all download latest version of express scribe form hare
http://www.nch.com.au/scribe/index.html. If you want to play .dss files and other files you need to download dss32.exe,dssdec.exe and then install them.
You can download all plug in then you can play various kinds of files. hare is link for plug i...
http://www.nch.com.au/components/index.html
http://www.nch.com.au/scribe/sony.html
Thanks
Jun 24, 2009 | Olympus DS-2 Digital Voice Recorder
I have the Olympus DS 71 which records in WAV. Is
The Olympus DS-71 has two recording format WMA & PCM WAV. The Software that comes with the recorder is Olympus DSS Player version 7 , you have to upgrade your software from Version 7 to Standard (free) after you upgrade to Standard version you can convert to DSS
go here for the update :
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1219&os=w
Now the link show olympus AS-2300 don't worry about it, just download the DSS Player V7 Upgrade to Standard
Hope this help .
Apr 04, 2009 | Olympus DS-2 Digital Voice Recorder
D-link dss-5 setup (please help!)
you need to make sure that DHCP is enabled in the router settings and that your network cards TCP/IP is set to obtain an ip address automatically.
Also check that your computers workgroup is the same as your friends eg, Home or Workgroup.
Nov 03, 2007 | D-Link Express EtherNetwork DSS-5+...
Computers & Internet Logo
604 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
