Question about Intel Motherboard
No Display sometimes
I start my computer very often
but sometimes when i power on the computer
the display does'nt come.
and while working machine display goes off
    Problem Solver:
MAKE SURE THAT THE VIDEO CABLE IS TIDE AND CHECK IF THE MOBO IS NOT GROUNDED I SUGEST TO RESET THE MOBO AND TRY TO PUT SME ISOLATION IN THE SCREWS
Posted on Aug 03, 2008
Foxconn nt-a3700 does not power up
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
hope this helps
Jun 20, 2012 | Foxconn nt-A3700-0H0WBANA Black Mini /...
My LG washing machine has power but no light display and doesn't work. I washed a bathrug and when I returned the machine had power (makes a tone when the on button is pushed), but none of the...
I have a LG WM2016CW and after I washed a med. rug none of the lights on panel wwould not work but it did ding when I pushed the start button. so after reading other solutions one said something about checking the door switch so I tried washer n woulnd'nt work so I opened the door and pushed on the door switch and it started. thank you I hope this works for u...
Oct 11, 2011 | LG WM2016C
Some time no display, normaly server work fine,...
I have same problem with my previous DELL and now with my new (1550) onr too.
Sometimes when starting up the laptop with own display (not remote one, which this problem has never occured) the display just keep to be black. Sometimes it helps to close dislpay (to make laptop to go "sleep" mode and then open it up again, but this does not help always).
Maybe this is normal behaviour for DELL laptops ... This is last DELL that I bought.
May 21, 2010 | IBM x3400 Server
Power on cpu starts but display does not come on
check volt of cmos battery with multimeter..it should be 1.5v
also check for RAM module get one working RAM from working system then check for SMPS....do reply
Nov 09, 2009 | Quadrant Celeron A , 466 MHz...
Computer beeps on sart up no display
Try another display or display cable.
Jul 07, 2008 | Computers & Internet
Monitor keeps blank even the power lLED is on green
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
HCL Monitor type HCM580M display problem
Information about the Linux / UNIX less command. Thus, various display problems may result, such as long lines being split in the wrong place. -R --RAW-CONTROL-CHARS, Like -r
Device Manager information and help This section will also display what COM ports are detected; for example, ... CODE 13 - System Failure - Possible problem in Device Driver or Windows 95 Code.
Good Luck, Please dont for get to Vote, Thank You.
Dec 19, 2007 | Computers & Internet
Intel Motherboard Logo
51 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
