Question about Kurzweil SP3X 88-Key Stage Piano
I brought my kurzweil sp 3X to a store to have them installed a new board on it, but after they installed the new board in, the character displayed on the screen are all in a weird organize and messed up. For example: wrkng scnn instead of saying working on scanning. I just don't know what the characters are for each of the functions, name of the sounds that are currently displayed on the screen Can you please send me an email at thienus20@yahoo.com thanks
  • Kurzweil Master
  • 5,603 Answers
It sounds like the new board and firmware has gone to abbreviations instead of fully spelling it out.
I would complain to the store since they should warrant it if it is a problem... but be prepared to accept that the firmware has been changed and displays differently now.
Posted on Mar 23, 2011
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure
1. Turn the Kurzweil off
2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release
3. Select RUN DIAGS
4. Press the UP arrow until the display reads RAM TEST
5. Press the START/STOP button to run the test
6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset.
If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
Apr 14, 2016 | Kurzweil Music
Tell me some tips and tricks about using the Kurzweil sp3x stage piano
The place to get the best help for Kurzweil gear is Sweetwater Sound.
Other than that, always use it in stereo mode with a decent sound system. Always use speakers with at least a 15" woofer and a horn to get the full range of sound it's capable of.
May 18, 2014 | Kurzweil Music Systems Kurzweil SP3X...
Replacing battery in kurzweil mark 12
As per the manual it says it is located near the power switch. You will need(as per the manual instructions): a screwdriver(Phillips head), a knife, a pair of scissors, and a pair of front end wire cutters as, when shipped from the factory, the three AA batteries were taped or cable tied as a shipping precaution(to keep them from falling out). ***WARNING: MAKE 100% SURE YOU HAVE BACKED UP ALL OF YOUR SOUND PATCHES ON A FLOPPY DISK BEFORE BEGINNING THIS PROCEDURE!!! ONCE YOU START THE REPLACEMENT PROCESS, YOU HAVE ABOUT 30 SECONDS BEFORE THE BOARD LOSES ITS CHARGE AND YOUR SOUND PATCHES GET ERASED FROM THE ROM CHIP.***
Make sure you have all of the needed batteries and tools before beginning.
Hope this helps.
Nov 23, 2012 | Kurzweil Music Systems Kurzweil MARK152I...
Kurzweil Sp2x
It may be the line current at those venues.
If you have a lightweight switchmode supply, you can try adding some ferrites to the power cord from the wall. but you almost need to switch to an older style heavy transformer supply for reliablity. It is my guess there is a great deal of noise on the supply current at those vehues you have had problems at. That noise does not play well with switchmode.
Feb 04, 2012 | Kurzweil Music
Hello, My KURZWEIL start but it only blinking a rectangel on display to the left. There is no other lights, all other is dead Morten Lauritz
It could be your internal battery. Do a search on keyboardforums.com for additional support or Kurzwil website. good luck!
Sep 15, 2011 | Kurzweil SP3X 88-Key Stage Piano
I have a Mark V Kurzweil piano - the electrical ''box'' - not a technical term - just my description - in the back of the piano in which the plug attaches to go to the wall is disconnected in the piano -...
Your are likely talking about the input power connector. They are usually a three blade connector in a well.
If the connection is soldered to a circuit board, it has likely gotten bashed in. The circuit board MAY be cracked, but is likely repairable.
Take it to a local electronics repair shop or find one through a music equipment store that deals with pro audio gear.
USUALLY these connectors have "ears" that attach to the case for strength and if the connector has been pushed in the ears likely have broken off. The parts are USUALLY readily available from several sources including Digikey and Mouser.
Sep 24, 2009 | Music
Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
Sep 17, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Replacement Battery Problems Kurzweil Mk 152
Check the voltage provided by the cells. Each cell should be above 3 volts. Make sure they are installed with correct polarity and the contacts are making. Brand new cells CAN be bad and some holders may not contact properly.
Jul 23, 2009 | Music
Kurzweil SP3X 88-Key Stage Piano Logo
191 people viewed this question
Top Kurzweil Music Experts
drivealot
john cordey
john cordey
rhodesworks
Are you a Kurzweil Music Expert? Answer questions, earn points and help others
