Question about Williams 6508732 Gas Heater
Williams direct vent model1403612 I can"t keep the flame going on the pilot. I can ignite it, and it gets gas as long as you hold the button in on the gas valve. What part do you think isn't working? Where can I get parts on line if you do have a fix for this?
    Brigadier General:
  • 4,736 Answers
Sounds like the Thermocouple or Thermopile has failed and will need to be replaced. You may also need to clean the pilot orifice. If you still have your Owners Manual, you can look up the part number and order it according to the instructions in the Owners Manual.
Posted on Mar 23, 2011
How do I light a Williams gravity vented wall furnace model 5009622
they usually have a manual perazo ignitor simular to a gas barbeque.. put the gas valve on pilot, depend the knob and hold it, depends the igniter epeatly until the pilot litghs, hold the knob in when u see the pilot flame for about one m,inute , release the knob, the turn the knob to the "on" posistion
Oct 02, 2016 | Williams Heating & Cooling
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
I have a Williams direct vent wall furnace(LP) and something is wrong with the pilot. It wants to blow out when the furnace runs just a few minutes and appears the flame of the pilot is shooting out both...
You will need to remove the burner and then you can gain access to the pilot assembly, it sounds like the pilot is rusted and falling apart, it is recommended to replace the pilot assembly. These direct wall units need maintenance before the call season and after for them to work efficiently
Mar 01, 2018 | Williams 6508732 Gas Heater
My friend has a gas heater and the pilot lite keeps cutting off on. He thought it was the heater and replaced it. The next day the pilot lite went out again. The heater downstairs stays on, hasn't went...
somethings wong with the venting ether he is getting a down draft ore it is pluged up take a lighter and see if the stack sucks the flame up if it does you dont have a problem but does not pull the flame up you have to take the venting aparte and find whats blocking your draft. the other thing your gas line might be pluged up.
Jan 20, 2011 | Williams 1403622 Gas Compact Heater
Williams 3003622 Wall Mounted 30,000 BTU The pilot light goes out when the main flame shuts down. The pilot light will stay lit for days when heat is not called for but when heat is called for the furnace...
I'm having the same exact problem... At first we thought was the vent... but the way the flames goes out... it seems that there is "not enough oxygen" more than "blown out by the wind"... right after both main & pilot goes out, I can't even light any external flame inside the chamber... and it doesn't feel like the outside cold air coming in... it just feel like there is some sort of gas in the chamber that's so strong, it prevents flame... and the only thing I can think of is that it doesn't have enough oxygen, but too much natural gas, and flame can't sustain.
Nov 02, 2010 | Williams 3003622 Ceramic Wall Mounted...
The pilot light is going out intermittently for no reason. williams heater is model 6508732
There's either a problem with the gas controller, flame sensor, or gas flow. the flame sensor is a small metal probe that get hot from a flame. Turn the gas control completely off, unplug it if applicable, and gently clean the pilot nozzle with a toothpick or something. If the flame sensor bulb is on a bendy wire, make sure the probe is positioned so it'll get heated by the flame.
Nov 01, 2009 | Williams Heating & Cooling
Gas flows to long before igniting.
try cleaning the crossovers between the burners. Also look closely at the flame and make sure that the burner is firing all the way to the pilot. Sometimes its just a few little holes that vent a little gas to give the flame a path to follow will be stopped up and cause the condition you describe
Nov 18, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Pilot light on but heater won't come on when I turn up the thermostat
Williams heaters have a manual reset for the spill safety switch. If the heater is not venting properly it will trip this switch and shut off main burner function. The switch is on the left side of the cover inside the small vent. You can use a screwdriver to push the button back in. If the heater then works you will need to get the vent inspected to make sure it is connected properly and there is no blockage.
Nov 26, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Mar 04, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Williams 6508732 Gas Heater Logo
188 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
